Old 11-17-2001, 12:03 AM   #1
cruzito
Member#: 11159
2000 ImprezaRS
Question Z-max
Hi guys,
Have some of you guys use this Z-MAX stuff on your Subies? I'm just wondering?
cruzito is offline   Reply With Quote
Old 11-17-2001, 12:15 AM   #2
NotoriousWRX
Member#: 9026
Snake oil
NotoriousWRX is offline   Reply With Quote
Old 11-17-2001, 12:53 AM   #3
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
I would not put anything besides normal oil in my crankcase. Sometimes an aftermarket oil additive or supplement can do more harm than good.
Richard
http://www.whitetyphoon.com/impreza/
Richard L. is offline   Reply With Quote
Old 11-17-2001, 01:15 AM   #4
shogunate83
Member#: 6006
I wouldnt put that crap in a new car... if it was a old car it would be a different case... Just do regular oil changes and your engine will be fine..
shogunate83 is offline   Reply With Quote
Old 11-17-2001, 10:25 PM   #5
txrex
Member#: 12426
Here's an interesting link about Z-max. Supports the snake oil comment. The trade commission is suing them for deceptive trade practices.
http://www.ftc.gov/opa/2001/02/zmax1.htm
txrex is offline   Reply With Quote
Old 11-17-2001, 11:55 PM   #6
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
If zMax is anything like Slick 50, then I wouldn't touch it, not even with a 10-foot pole. The original owner of my Typhoon put Slick 50 in it when it had 5,000 miles. All my main bearings were hosed when the truck reached 38,000 miles. Here is a picture of my front main bearing: http://www.whitetyphoon.com/bearing01.jpg
I will never put any oil additive in my crankcase again.
Richard
Old 11-18-2001, 01:45 AM   #7
cruzito
Member#: 11159
2000 ImprezaRS
Smile
Hi guys,
I'm wondering, if you're using synthetic oil, would that still double the bearing corrosion after Z-max is added? Ain't motor oil and synthetic oil different?
Old 11-18-2001, 10:22 AM   #8
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
You are still going to get bearing corrosion after zMax is added to synthetic oil. Look at what Slick 50 did to my main bearings after it was added to Mobil 1 synthetic oil. Synthetic oil already does an excellent job at lubricating moving parts. Why take the risk and add zMax to it?
Richard
Old 11-18-2001, 11:28 AM   #9
NotoriousWRX
Member#: 9026
Forget about Zmax, Slick50, Snakeoil, etc. The motor oil that you put in your car already has all the additives, detergents, etc., that your motor needs. Just don't get a race oil formulation, as that is not adequate for everyday use.
Old 11-19-2001, 06:12 PM   #10
psaeko
Member#: 7057
Default what about others
since this topic interests me....
what about those stuff like prolong and motor-up
are they same sxxt?
psaeko is offline   Reply With Quote
Old 11-19-2001, 06:22 PM   #11
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Yes, Prolong and Motor-Up are also Snake Oils. You don't need them.
Richard
Old 11-19-2001, 08:02 PM   #12
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
Anyone used Lucas Oil Stablizer? I added 1 qt while doing oil change and engine does seen to be much noise and vibration free.
I looked around, there hasn't been any complians for Lucas stuff yet.
Jason is offline   Reply With Quote
Old 11-19-2001, 08:12 PM   #13
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Originally quoted by Jason
You are probably experiencing the "placebo" effect. You are taking a risk everytime you add something to your motor oil.
Richard
Old 12-02-2001, 05:18 AM   #14
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
ZMax is nothing but colored mineral oil. I have heard a lot about cars having major problems a few thousand miles after it is added. Also transmission additives are the worst, what happens is that they get into the seals and soften them up and for about 2000 - 3000 miles they are great, the transmission is smoother and faster etc. But after that the seals start to expand because they keep absorbing these chemicals and pretty soon they expand to the point where they dont fit right and leak and then your in for a major overhaul. I would assume that the same would apply to engine additives.
If you really want to put something in an engine to improve it a little bit you can put a tablespoon of graphite. This tip was given to me by a F1 race mechanic, supposedly it does wonders for engine lubrication. I tried it in a 90's Tbird and it made quite a difference in engine noise and gas mileage. I have not done it to my WRX as I am not sure what its effects may be in a high compression engine. Dont want to do anything that may risk hurting my baby, I stick to regular oil changes, synthetic oil and the highest octane gas I can find.
Evaider is offline   Reply With Quote
