Old 12-05-2006, 04:37 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default Need help: CV joint boot install on an '83 Datsun pickup
This thing is a pile of crap.
I'm trying to get the boot on, and I have the whole 'axle' free from the hub...but I can't get the cv bearing apart...
In the destructions it talks about a tool, basically a tapered tube, that the cv boot is slid over, and then just sort of flops over the cv joint, allowing the boot to be put on without removing the axle.
I really don't want to remove the axle (theres no room under here)
Anyone have any tips?
Thanks
Alex
Old 12-05-2006, 04:38 PM   #2
Danny5
The Emperor Protects
Member#: 13
2014 Chevy Cruze
Diesel
New Axle - $100
CV Boot - $25
Asking OT for help?
PRICELESS
Danny5 is online now   Reply With Quote
Old 12-05-2006, 04:40 PM   #3
beachbum
Member#: 457
---- Smells like
weed and rampage
Everybody I know will just replace the axle with a reman unit rather than **** around with a CV boot. Easier, cleaner, faster, more reliable, and only slightly more expensive.
beachbum is offline   Reply With Quote
Old 12-05-2006, 04:41 PM   #4
big_mac314
Member#: 38251
12345
big_mac314 is offline   Reply With Quote
Old 12-05-2006, 04:41 PM   #5
svx'ed
Member#: 79005
74 Miles Northwest
of Skell.
svx'ed is offline   Reply With Quote
Old 12-05-2006, 04:42 PM   #6
fliz
Member#: 30342
I've never seen a CV boot that could be replaced w/o disassembling the CV joint first. Well, except for split boots...but those are worthless.
fliz is online now   Reply With Quote
Old 12-05-2006, 04:44 PM   #7
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
normally there is a C cilp that holds the CV on the axle - removing the CV is typically the only way to get da booty on
MrMcCrackin is offline   Reply With Quote
Old 12-05-2006, 04:54 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
I can't seem to find that C clip...I've been looking at the bearing, its some sort of single row ball bearing type setup...its got like 8 large balls housed in a circular metal housing
Old 12-05-2006, 04:57 PM   #9
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
x1000 on just buying the entire axle and swapping them out. Soon you will figure out that you would have paid the extra money plus more to not have to deal with it.
bhall is offline   Reply With Quote
Old 12-05-2006, 04:57 PM   #10
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
you may have to completely clean the muther trucker to find it - its not really a big clip - oddly enough
Old 12-05-2006, 05:03 PM   #11
fliz
Member#: 30342
Do you have a service manual at all?
On my VW, the inside CV's are held on by a c-clip, but the outer CV has an internal washer. You have to hit the cup with a BFH to remove the CV.
Old 12-05-2006, 05:07 PM   #12
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Thanks mcCrackin, I'll spray it out w/ cleaner or paint thinner
I have a Chiltons, but it is a pile of ****...none of the diagrams match up in the slightest....things that are for a 2wd pickup of a different year match up to my truck...and the truck is factory 4wd...
Old 12-05-2006, 05:18 PM   #13
andypress
Member#: 106921
1989 Toyota MR2 S/C
Does this truck have straight-cut gears?
andypress is offline   Reply With Quote
Old 12-05-2006, 05:18 PM   #14
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
also - if you have the axle out - note, there were some funky axle's out there that one side is pressed on and the other is C-clip and you have ot take the one side apart to get to the boot on the other side - its a real PITA!
Old 12-05-2006, 05:21 PM   #15
LateApex
Member#: 7593
96 Miata
12345
This is your answer.
LateApex is offline   Reply With Quote
Old 12-05-2006, 05:24 PM   #16
markman
Member#: 93623
install a bridgeport 13b in it, then the CV boot will glide right on.
markman is offline   Reply With Quote
WRX CV Joint Boots and Grease From Subaru JoNzWRX Private 'For Sale' Classifieds 21 09-21-2004 07:24 PM
CV Joint Boots The Amish Outlaw Tire & Wheel 0 02-03-2004 05:11 PM
Cv Joint/boot Needed!!! CRAZY KEN Mid Atlantic Impreza Club -- MAIC 16 11-12-2003 05:16 PM
Help! fixing CV joint boot...need some advice! GooseMan Transmission (AT/MT) & Driveline 2 07-19-2002 07:20 PM
HELP! Fixing CV joint boots....need a special tool? GooseMan Brakes, Steering & Suspension 3 07-16-2002 05:50 PM
