Old 12-05-2006, 08:33 PM   #1
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Default Hydramist installed - up to 27 psi on 93 oct right after install
Just finished installing the Element Tunning Hydramist and although it takes about 8 hours to install, it seems its going to pay off.
Things amazing, with safeguards to switch off the water injection fuel and timing map when the sensor hits empty or too much flow (prob a busted line) or too little flow (probably clogged line or pump inactive). The Hydra also controls the activation of the system and includes a flow sensor and high speed valve.
I have the Perrin Gt35R kit with stock long block and supporting mods (txs fmic, 850 pe's, hydra of course, header..) Before this kit I was having problems running 25 psi on 93 octane unless I ran really low timing. Right after I installed it, took it for a spin, cranked it to 27 psi and with the additional 3 degrees of timing of the water aux map I get no knock at all. The car is running about 10.9 afr's (should be 12.0 wit mist) and EGT's are about 790C, and the car feels great and smooth AND powerful. It shows its still allows leaner AFR's and I think more timing can be tacked on.
I mixed 50% methanol and 50% distilled water for the injection, using the I/C sprayer reservoir for storage. Cost = 5 gal of meth + 5 gal of water = 10 gal of fuel for $31 or $3.10 a gallon. About 1.5 gallons I think lasts a full tank, prob 2 fillups. Phil says I should be getting about 110 octane grade with this mix so I think it saves a bunch on race fuel.
Will update soon on power bragging with pics, dyno plots and of course track times.
Great product and very complete. The only thing you need is a 40amp fuse and a 8 guage wire for pump power and four bolts for the pump. Guys with beginners skills at wiring beware, you want to do this right the first time and route the connections well. All wires, plugs, cables are included and its no brain surgery, but patience is key.
El Gato is offline   Reply With Quote
Old 12-05-2006, 08:59 PM   #2
benw
Member#: 103320
1998 swapped
Forester L
great write-up! imagine your power when you lean out your A:F a bit more!
benw is offline   Reply With Quote
Old 12-05-2006, 09:49 PM   #3
El Gato
Member#: 110648
93oct 479whp 456tq
Its hard to explain, right of the bat I just boosted 27 psi on 93 oct and the car feels so smooths and powerful, and its still untuned!! No knock, I just ran the car from 1st to 2nd and when I shifted the car felt like it wanted to explode, it tilted so much upwards that it felt like it almost wheelied. Element Tunning's Phil Grabow and Aquamist really impressed me with this. And the interface with the Hydra its amazing. Feels like I'm cheating!
Old 12-07-2006, 08:57 AM   #4
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
awesome. Cant wait for mine
ImprezaRSfan! is offline   Reply With Quote
Old 12-07-2006, 04:37 PM   #5
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Thank you very much for the very nice post.
Aquamist is offline   Reply With Quote
Old 12-07-2006, 10:22 PM   #6
El Gato
Member#: 110648
93oct 479whp 456tq
Its not nice, its fair and earned. The technology involved with the DD3 and its junction box, and the connection with the hydra plus all the fail safes and map switching...how about 479whp and 453tq on stock long block tuned by me, an accountant (I am a USA CPA) on 93 octane and 50%water and 50%metahnol?
Old 12-16-2006, 05:16 PM   #7
Element Tech
Member#: 125971
Originally Posted by El Gato View Post
I.
I cant imagine anyone that is into building a performance engine, not wanting a Hydramist. With the costs and hassle(supply) of race fuel these days, its a no brainer.
The std OEM pistons cant stand up to detonation very well at all. Besides loosing oil, nothing tears apart an engine faster than Det. With the help of the Hydramist Phil has been able to push the limits farther than ever before without failure.
Element Tech is offline   Reply With Quote
What size turbo is needed to hold ~22 psi up to 6k rpm's on a 2.5L? sburck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 51 03-19-2009 02:02 AM
I am Impresses High HP STI! 500+on 93 oct fuel the ringer Proven Power Bragging 14 07-02-2007 11:32 PM
Hydramist installed - up to 27 psi on 93 oct right after install El Gato Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 12-07-2006 10:56 PM
Our 500 hp on 93 oct STI visited the Dyno for C-16 Tuning.(SEE VIDEO) TOMASCS Proven Power Bragging 78 09-06-2006 09:52 PM
500.85 hp STI on 93 oct GAS (BOOST ONLY) From P.R. TOMASCS Proven Power Bragging 59 05-31-2006 10:51 AM
