Old 12-06-2006, 02:07 AM   #1
killa996
Member#: 98812
Default 02 wrx - knock
hey i have a 02 wrx and at low rpm i se - knock. is this normal?
killa996 is offline   Reply With Quote
Old 12-06-2006, 10:12 AM   #2
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
How low?
If cruising it's somewhat ok. <- (and this may just be phantom knock)
Also, how do you know it's knock?
akira02rex is offline   Reply With Quote
Old 12-06-2006, 10:20 AM   #3
killa996
Member#: 98812
at idle when i throttle bleep sometimes it goes all the way down to -5 -3
i logged yesterday with ecuexplorer and at part throttle at 30mph at low rpm is saw -1 nock
Old 12-06-2006, 10:47 AM   #4
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
That is knock correction it sounds like. That is perfectly fine.
Knock correction is the amount of ignition timing the ecu is pulling. Doesn't necessarily mean you're knocking.
It is genuinely most useful to look at knock correction when you are at WOT to check for knock.
Old 12-06-2006, 11:03 AM   #5
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
so per the logging with ecu explorer - how do you know you are knocking? ie, values, etc....
anthonyrb98 is offline   Reply With Quote
Old 12-06-2006, 11:17 AM   #6
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
^^^ Well first you'll see a constant negative correction through the rpms that you are knocking. it is doubtful that you would knock at part throttle at low rpms. Depending on how low of rpms we are talking about it could be that you are lugging the engine alittle and the shake is causing the knock sensor to detect false knock.
I think alot of people see the tip-in negative knock correction values and freak out thinking they are knocking. But every car I've logged has had -3 or -5 values on throttle blips so I think it may actually be programmed in the ECU to pull timing on tip-in.
killa96, what kind of rpms are you talking about? Just a description of "low rpms" doesn't cut it. My idea of low rpms is anything below 2200, and I don't drive in low rpms (if it falls under 2200 I will downshift).
Old 12-06-2006, 12:14 PM   #7
killa996
Member#: 98812
by low rpms its under 2200. hey guys what fields should i be logging?
04 STI Harness - 02 WRX Cluster Does anything need to be switched? Maverick7531 Subaru Conversions 9 08-11-2010 11:30 AM
Feeler 02 wrx 77,+ mi Los Angeles grey306 Private Vehicle 'For Sale' Classifieds 1 06-03-2010 07:05 PM
02 wrx knock sensor mysticalss4 Private 'Wanted' Classifieds 4 04-21-2009 11:48 PM
My 02 WRX knocks like crazy when its cold. Help anyone? Travis Graham Service & Maintenance 50 03-19-2006 08:59 PM
WTB: Knock Sensor for KnockLink in 02 WRX parid Private 'Wanted' Classifieds 1 12-17-2003 01:06 PM
