Old 11-17-2001, 09:13 AM   #1
jeffsnyder
Member#: 10039
Default rallispec intake for 99
hey i have a question for ppl about this
how do i modify the intake that was for a 99 to work on a 98.
i have it all installed but there is still on hose that isn't connected that will not allow the car to run, it just stalls.
the hose that i'm talking about it the one that is about 1.5 around and on the factory intake it connects right after the sensor.
~JEff
jeffsnyder is offline   Reply With Quote
Old 11-17-2001, 11:45 AM   #2
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
From your description, I think you are implying that there is a breather hose that is still not hooked up. This should NOT make your car stall. The breather hoses (3) should be plugged into the supplied catch can. The Rallispec intake is one tube from filter to throttle, go back and make sure there are no leaks at the silicon tube at the throttle and at the MAF sensor. Make sure the connector at the MAF sensor is plugged tightly and that you havn't plugged any vaccume hoses near the MAF sensor.
Also check this link for install pics.
http://8complex.mwsoc.org/rallispec_intake/
Revision is offline   Reply With Quote
Old 11-17-2001, 01:26 PM   #3
elemental
Member#: 2701
'00 obs
98s have 4 hoses, 1 to each head, and 2 (1 huge, one normal size) go somewhere else =P so i guess you'd have to get another nipple on the pipe somehow or you could do like the stock airbox does and T the nipple into two to use 4 hoses on only 3 nipples, which would probably be easier than putting in a new nipple.
elemental is offline   Reply With Quote
Old 11-18-2001, 02:13 AM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
That hose is the idle control line - do NOT "T" it into the other lines or you will suck oil into the Throttle Body and smoke like a cigar!
It needs to be connected to the intake tubing behind the MAF to work properly.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 11-18-2001, 04:27 AM   #5
elemental
Member#: 2701
'00 obs
didnt know that, just recommended it because the airbox does it for the two that go to the heads, maybe you can tee one nipple into two for those two hoses and leave the idle control hose a nipple for itself?
Old 11-18-2001, 08:30 AM   #6
jeffsnyder
Member#: 10039
so that means i have to tap the tube after the maf sensor then and plug it in there
~JEff
Old 11-18-2001, 11:49 AM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
Yeah, the idle control nipple needs to have air flowing past it at high velocity - the airbox behind the motor is supposedly big enough to be almost at atmospheric pressure so the nipples in the airbox would not be good enough for that line to connect there if you were using one of them.
Since the Rallispec has high velocity air throughout, it would be possible to slide a small hose on the small 99 size nipple closest to the MAF to make it fatter, so the big idle control line will fit on it and hose clamp it in place. Then T- the other oil fume vent lines together.
Or, he will need to tap into the pipe with a hole and a liquid nails or JB Weld a small pipe in the hole to make a vacuum nipple.
Larry
Old 11-18-2001, 11:54 AM   #8
jeffsnyder
Member#: 10039
Thumbs up ImprezaRS dot com
hey thanks for the info
i'll get a elbow fitting and tap that into that the pipe and conncet that hose to it and it should work.
i'll try it again later this week and c if it works.
~JEff
PS
does that line blow oil out
Old 11-18-2001, 02:17 PM   #9
elemental
Member#: 2701
'00 obs
it's not really a matter of blowing oil out i dont think.
the reason he said that seems to be because the idle control hose would suck oil up through the venting hoses if they were t-ed. it seems that under normal operation they just vent the oil fumes, not oil, into the intake tract.
Old 11-18-2001, 02:35 PM   #10
jeffsnyder
Member#: 10039
okay so all i have to do is tap ahole into the pipe after the sensor and plug that hose into it then
~JEff
Old 11-18-2001, 05:29 PM   #11
elemental
Member#: 2701
'00 obs
im not sure why you guys keep referring to after the sensor, all the hoses on my car at least (98) are after the sensor, before the throttle body. there are no hoses before the sensor at all.
meaning... yes, after the sensor, where all the rest are.
Old 11-19-2001, 02:48 PM   #12
ImprezaRS dot com
over boosted again
Member#: 1458
"After" or "Behind" the MAF are referring to the direction of air flow from filter to MAF to tubing to air plenum to throttle body.
The idle control line for the MY 98 connects to the intake just after or behind the MAF where the air velocty is high, yet before the other vacuum nipples so there are no fumes from the crank and valve cover breathers to get sucked into it.
Larry
www.ImprezaRS.com
Old 11-19-2001, 04:06 PM   #13
elemental
Member#: 2701
'00 obs
oh, i gotcha, just didnt recognize that you meant before the rest of the lines, thanks for clearing it up
Rallispec intake for 99 2.5 RS Limey Private 'For Sale' Classifieds 7 03-26-2004 09:58 PM
Rallispec Intake For RS milla Private 'For Sale' Classifieds 6 01-28-2004 04:52 PM
Rallispec Intake for sale BobWRC Private 'For Sale' Classifieds 0 08-27-2003 11:08 PM
RALLISPEC intake for 2000 RS up for grabs AzNStiImpreza Mid Atlantic Impreza Club -- MAIC 9 07-11-2002 03:21 PM
Rallispec Intake for MY99RS tmaler13 Normally Aspirated Powertrain 2 06-13-2001 08:53 PM
