Welcome to the North American Subaru Impreza Owners Club Friday October 31, 2014
Old 12-06-2006, 02:27 PM   #1
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
Default Question about carputers
I have a question about carputers. Will it hurt a carputer to be left in a vehicle in sub zero temperatures. I know some of you guys here have them in your cars and I did a search and can't find anything specific to my question. I'm wondering if it's ok to leave in the vehicle or should it be taken out at night during the cold winter months. I know the touch screen should be fine but I'm more focused on the CPU. If you guys could shed some advice I would appreciate it.
Thanks,
Michael
mike_b49431 is offline   Reply With Quote
Old 12-06-2006, 08:10 PM   #2
ZenerDiode
Member#: 37888
2003 WRX
Pearl Blue
nope, not at all. in fact it's preferable to really hot weather actually.
I take my subie up to tahoe all the time and leave out in freezing weather...nary a glitch with the carputer
UNTIL...I switched over to a fluid-bearing 2.5" hard drive. then the fluid would freeze up and I'd have to warm up the car for a little while before the hd would start. I switched back to a standard 3.5" and that problem went away.
ZenerDiode is offline   Reply With Quote
Old 12-06-2006, 09:16 PM   #3
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
Check out mp3car.com for all your carputer questions.
The major problem with computers and cold is the HD as ZenerDiode mentioned. But it also can take a long time for a cold lcd display to warm up.
blkwrx02 is offline   Reply With Quote
Old 12-07-2006, 04:30 AM   #4
wrx614
Member#: 71848
2003 WRX
As far as the cpu, you could mount it under the seat where the vents are to heat it up (and cool down in the summer).
wrx614 is offline   Reply With Quote
Old 12-07-2006, 08:21 AM   #5
stu1811
Member#: 124651
2011 LGT
I've seen extreme PC overclockers get their CPU way below 0. One guy even used liquid nitrogen to cool the CPU. They overclocked a P4 to over 5 GHz.
http://www.tomshardware.com/2003/12/30/5_ghz_project/
The only components I would worry about is the HD or the lcd. Get a HD with an operating temp below zero. Laptop HDs sometimes come with this spec. Also get one that can withstand higher vibration. I don't know much about LCDs at low temps, but it will prob be fine. It may take a couple min to warm up. While it is cold it may "ghost". That is what my iPod does. I've left it in the car by accident and it takes a couple min to warm up, then its as good as new.
Cliffs: You will be fine. Get laptop hd. Check opertating temp of HD and LCD.
stu1811 is offline   Reply With Quote
Old 12-07-2006, 09:06 AM   #6
rkramer
Member#: 118209
2015 WRX Limitec
I've run my omnifi (mobile HD based mp3 player) for 2 winters now without any problems. Once it gets cold (below zero or so), the HD won't spin up anymore, but other then that, computers like cold.
Old 12-07-2006, 10:20 AM   #7
stu1811
Member#: 124651
2011 LGT
Try to get a hd with ball bearings instead of fluid bearings. Your balls may freeze but the ball bearings will not
questions about carputer, specifically the screen. Spy Car Audio, Video & Security 2 03-31-2009 08:18 PM
Carputer Project - A few questions about Audio. Teh Legacy Car Audio, Video & Security 32 08-15-2005 08:44 PM
Few questions about the Perrin Turbo Inlet and about the Samco MAF arm???? BLUETURBOWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 08-21-2003 03:53 PM
question about what i should do about these 2 girls skylineR34 Off-Topic 28 07-23-2003 07:44 AM
About to buy STi, question about Subaru's fit & finish... JT-KGY STi Forum Archive 19 01-27-2003 02:39 PM
