Old 11-17-2001, 02:03 PM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Default Anyone use an HKS Fuel computer in their car?
I'm in the Market for a air / fuel computer to optimize my cars performance, I know Apex-i is the highest recommended out there, but I was hoping someone had an HKS, it's has an manual adjustment rather then digital.
Could anyone be of any help?
Thanx!
Bry.
BrysImpreza is online now   Reply With Quote
Old 11-17-2001, 11:04 PM   #2
scubaracer
Member#: 4909
1992 legacy 2.2Turbo
silver sports sedan
Default sounds interesting........
I have not heard much on the products from HKS. I think i would be safe to say it would probably work pretty good. sorry, i know much about the air fuel computer.
check out these notes i had:
-HKS AFR is a simple fuel adjusting device that adjusts the Air/Fuel ratio by changing the
airflow voltage output to the vehicles factory stock computer. The AFR was designed for
vehicles that are lightly tuned (air filter, exhaust system, etc.) and that need only slight fuel
adjustment. The 10 setting adjustment indicator allows the user to richen or lean the stock
settings by approximately 0.2 of an A/R point. Both the lean side and rich side have five
notches. This enables the user to search for the best possible set up for your vehicle! The
D-Type and L-Type are the two types of AFR available.
-HKS AFR (Air Fuel Ratio Regulator)
The AFR is designed for lightly tuned vehicles (intake, exhaust) to allow for mild
adjustments in the a/f mixtures through sensors. The AFR allows up to 1 A/R point; rich
or lean, for the best possible power gains. - $ 120 approx.
does that help?
seeya
scubaracer is offline   Reply With Quote
anyone using an AVO fuel pump on their 08 STI/WRX? zmw Texas Impreza Club Forum -- TXIC 33 01-27-2009 11:56 PM
Anyone used the HKS Fan controller on our cars yet? Davenow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-09-2006 05:09 PM
Anyone is using an Apexi turbo timer in their STi? Does it work with the stock alarm? JDM addict Electrical & Lighting 6 09-17-2003 01:48 PM
Anyone using a Quaife front diff in their auto-x/open track beastie? Patrick Olsen Motorsports 10 01-25-2003 07:35 PM
Anyone have a computer in their car? 8Complex Car Audio, Video & Security 13 01-13-2001 05:23 PM
