Old 12-06-2006, 07:19 PM   #1
TexRex2002
Member#: 36303
06 Evo IX
Default anyone run 255's on 8" wheel?
just curious. I am thinking of putting some 255 RT615's on, but I have 8" wheels. does this tire get somehat sloppy on a 8" wheel?
thanks...
TexRex2002 is offline   Reply With Quote
Old 12-06-2006, 08:16 PM   #2
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Its not great but it should work fine. Quite a few people put those tires on the stock 05+ STi wheels and I havent seen any complaints.
afpdl is offline   Reply With Quote
Old 12-06-2006, 09:14 PM   #3
adhowe70
Member#: 3363
1982 Reynard
Blue, Red, and White
I've run 265's on a 7.5" wheel, but I'm not sure I'd go anywhere near this on a true street tire. I'd suggest not more than a 245 on a 8" wheel if you're talking about street tires. I'd suggest 255's on a 9" wheel.
adhowe70 is offline   Reply With Quote
Old 12-07-2006, 12:09 PM   #4
TexRex2002
Member#: 36303
06 Evo IX
thanks...
I don't think they make RT-615's in 235's (stock width for me).
I'm sorta trying to not spend the extra $ for new wheels...
Old 12-07-2006, 12:11 PM   #5
TexRex2002
Member#: 36303
06 Evo IX
so is it better or worse than a 225? (from a turn-in and cornering perspective)?
Old 12-07-2006, 12:11 PM   #6
2superblus
Member#: 33526
2013 WRB W/Gold BRZ
08 STI WRB w/Gold, 02 WRX
225's on an 8 inch are fine that is what come factory on an STI, now if this is for a WRX Azenis has a 235-40-17 that is very nice.
2superblus is offline   Reply With Quote
Old 12-07-2006, 01:14 PM   #7
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
they do make a 235/40/17 615. There is a thread on here about putting the 255s on stock bbs's with reviews and pictures somwhere on this forum. I think nuhlur or however you spell it started it.
Old 12-07-2006, 03:00 PM   #8
jamesohoh7
Member#: 39070
GTF off my lawn!
thanks...
Is there a reason you're not considering 245/45's? ... a bunch of us have run 245 615's on 8" rims and had reasonably good performance.
If you're talking about doing it for autox, the extra grip from width makes up for the slightly sloppier turn-in due to the taller sidewall.
I mean, if you're worried a 255 will be too pinched, but want more than 235, then 245's are right there for ya
(Evo? ... it's o.k., you can say it )
jamesohoh7 is offline   Reply With Quote
Old 12-07-2006, 04:37 PM   #9
tora
Member#: 5851
09 Forester XT
+ NA Miata
I've run 255 on 8" Enkeis (17's). Worked no problem. I would prefer to have them on 8.5"'s but didn't have that wide a wheel at the time. I tracked them and they were fine.
tora is offline   Reply With Quote
Old 12-07-2006, 05:32 PM   #10
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
255's RT615's on a stock 17x8 wheel were fine. Actually there was no real bulging at all.
rankink is offline   Reply With Quote
Old 12-07-2006, 05:40 PM   #11
shemoves
Member#: 80663
2005 STi
Strictly from a performance perspective, would a 245/45 or a 245/40 be better for the 8" rim?
shemoves is offline   Reply With Quote
Old 12-07-2006, 05:59 PM   #12
Draken
Member#: 16
1968 Saab
Sonett II V4
I tracked a set of 255/40-17 Pirelli corsas on 8" wheels with no issues.
Draken is offline   Reply With Quote
Old 12-07-2006, 06:14 PM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The '94/95 Cobras came from the factory with 255s on 17x8" wheels, and I don't believe that's the only OEM case of that fitment.
Strictly from a performance perspective, the 245/40 is going to have a slight gearing advantage over a 245/45, and it's got a shorter sidewall for (theoretically) better turn-in response. 245/40 is also closer to the original 225/45 sidewall, so the ole speedo/odo won't be off as much.
Old 12-07-2006, 10:35 PM   #14
remowgn
Member#: 41149
09 FXT
SSM
The width of the tire is not enough by itself to determine whether a tire will properly fit on a wheel. The cobra takes 255/45-17's. For example, take the Kumho MX's (for which there are both 255/40-17 and 255/45-17 available). The recommended rim width for the 45-series tires is 8.5" - 9.5", whereas for the 40-series tire it is 9.0" - 10.0".
For the 255/40-17 RT615, the recommended rim width is 8.5" - 10.0". Going a half inch under that is not going to kill you.
And on top of all of that- my buddy has 17x8 Team Dynamics with 255 RT615's on his evo and it works (and looks) just fine. It ought to work on yours too!
remowgn is offline   Reply With Quote
Old 12-07-2006, 10:45 PM   #15
rally_on
Member#: 86849
2005 GMC Savana
white
they'll lack in response. or so i've heard.
you wouldnt want them for cornering. but they do look good. no doubt. i love the look of beefy tires myself.
rally_on is offline   Reply With Quote
Old 12-07-2006, 10:54 PM   #16
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
you wouldn't want them for cornering. but they do look good. no doubt. i love the look of beefy tires myself.
I doubt they would be any worse than 245/45/17 615s. I would just go for the 255s Tim, unless you are planing a triumphant return to autox .
Old 12-07-2006, 11:16 PM   #17
01G_WRX_02
Member#: 89746
2002 WRX Stage 4
PSM w/Gold RPF1's on 255s
245/45/17 are pretty much the same as 255/40/17
I have 255/40/17 on my 8" wheels. no problem
01G_WRX_02 is offline   Reply With Quote
Old 12-07-2006, 11:30 PM   #18
555ideways
Member#: 36652
yes .
555ideways is offline   Reply With Quote
Old 12-07-2006, 11:39 PM   #19
import111
Member#: 24447
2016 Mustang GT w/PP
Red
Ummmmm, not even close. 225/45/17 is stock STi size and is 25" diamiter. 255/40/17 is also 25" diamiter. 245/40/17 is common to use, and I am gonna get this size in the near future, is 24.7" which is only 0.3" off, not too bad. 245/45/17 is 25.7", which is 0.7" bigger around than a 255/40/17. That is almost 1 inch bigger diamiter. IMO that is wayyyy different than a 255/40/17, and not as good performance wise either (i.e. taller sidewall is easier flexed/rolled over, and more diamiter = less acceleration).
import111 is offline   Reply With Quote
Old 12-07-2006, 11:40 PM   #20
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
I think he means turn in is about the same on both tires. The 245 has more sidewall but fits the rim better, 255 has less sidewall but is squeezed on the rim.
Old 12-08-2006, 09:26 PM   #21
TexRex2002
Member#: 36303
06 Evo IX
LOL. it would take more than the perfect tire to be triumphant at autox... (driving skillz upgrade is what I'm getting at here)
It may be moot now, since I just crashed the damn thing (sleeping in a traffic jam on interstate), but lets see. I should have it back in a coupla weeks.
300C is looking better and better now. Maybe a big ol' pig/boat can reduce my obsessive need constantly to push the limits... freaking pocket rockets are just too tempting to drive hard...
Old 12-08-2006, 10:40 PM   #22
InfamousDX
Member#: 25413
I run 255/40's on my volk 17x8 +44. Falken fk451's... I love em. It's not as "bubbled" as people think it's going to be.
Old 12-09-2006, 09:35 PM   #23
01G_WRX_02
Member#: 89746
2002 WRX Stage 4
I can feel mine roll if I do solom, but then a I have Direzza DZ101 which are a cheap tire only $92. If I had gotten a better tire then this wouldnt have been a a prob.
wheel spacer on 8" wheel cdogg240 Tire & Wheel 4 02-21-2007 05:46 PM
Anyone running 205's on 7" wheels? Donzo Tire & Wheel 6 01-05-2007 05:46 PM
is anyone running spacers on their wheels kcook Tire & Wheel 3 07-20-2005 05:23 PM
Anyone Running 17 x 8" Wheels? JRS Tire & Wheel 9 05-06-2003 07:11 AM
Anyone running/plan on running a VF29? CatchME Bay Area Impreza Club Forum -- BAIC 1 01-27-2003 09:17 PM
