Old 12-07-2006, 01:25 PM   #1
StillBoostin
Member#: 46177
2002 WRB WRX
99 RSTi Coupe
Default 2001 2.5 RS wiring problems
I have the ECU pin out from North Ursulia. My pin out you read from the back of the plugs. What is:
B135 pin #12
B134 pin #12
B135 pin # 11
I have wires but the Diagram doesn't say any wires belong there. A little help please.
Thanks in advance
James
StillBoostin is offline   Reply With Quote
Old 12-10-2006, 10:33 PM   #2
Aus_RS
Member#: 35441
02 RST
GT2540R
I've got a set of diagrams sourced by a shop here in Aus.
The only one of those 3 that is in my diagrams is:
B134 #12 : Radiator fan relay 2 control : A/C vehicles only.
Mark.
Aus_RS is offline   Reply With Quote
Old 12-11-2006, 11:37 AM   #3
redwagon
Member#: 2181
2008 SpecB
On that generation of ECU it should be:
B135 #11 and #12: Select monitor signal
You could check and see if the colors are the same as at the diagnostic plugs under the dash to be sure.
I also have B134 #12 as the 2nd fan on a/c models.
redwagon is offline   Reply With Quote
2001 2.5 RS AT Oil Temp problems HELP!! Evman08 Newbies & FAQs 3 12-21-2008 06:50 PM
Swap 1999 2.5 RS engine for 2001 2.5 RS engine c0mrade Subaru Conversions 5 06-15-2006 10:19 PM
1998-2001 2.5 RS and 2.2 L models ralli-tart Newbies & FAQs 0 01-30-2006 12:19 AM
ROAD TEST: 2001 2.5 RS VS 2002 2.5 RS WantaSubaru Normally Aspirated Powertrain 4 06-11-2001 10:05 AM
2001 2.5 RS Sedan Mileage Problem Im'Pat'za General Forum Archive 9 11-12-2000 05:37 PM
