Old 12-07-2006, 12:47 PM   #1
goixiz
Member#: 99128
2005 SAAB 92x
Default close to open loop
can someone please educate me on the table format and what all those numbers in each column mean and how to optimize it
thanks in advance
goixiz is offline   Reply With Quote
Old 12-07-2006, 02:42 PM   #2
Gethin
Member#: 2998
eh?...
elaborate on your question please
Gethin is offline   Reply With Quote
Old 12-07-2006, 03:15 PM   #3
goixiz
Member#: 99128
2005 SAAB 92x
Under the closed loop tree - closed loop delays (enginuity) - ROM
16 columns with group of 4s
what does those numbers change / mean
Old 12-07-2006, 05:38 PM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
They are some value the ECU uses for the delay calculation. I don't think anyone knows exactly what they mean. You'd accomplish alot more by changing the closed loop rpm exit and enter AND the closed loop throttle percentage.
If you do adjust those numbers, adjust them all by the same percentage.
Old 12-07-2006, 05:40 PM   #5
Gethin
Member#: 2998
the time delay taken to transition from closed loop to open loop at that RPM, in miliseconds I believe.
Old 12-08-2006, 01:47 PM   #6
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
There are several theories as to what those numbers mean. Generally, it has been reported that the numbers dictate when the ECU transitions between closed and open loop. It is also believed that they control the transition in the other direction. This seems to be the heart of the infamous closed/open loop delay issue that +04 WRXs have. Most people have lowered those values to 10% of what the stock ROM has. This seems to improve the transition delay. Some also suggested that zeroing out the last column in each section (1,2,3,4) also helps things a lot. You may say, hell, I'll just zero out all cells!!! Not so fast my friend!!! Doing so will most likely effect your MPGs and I heard that it may make the transition even slower. My theory is that the ECU might not like all 0s and could enter a safe mode which will 'feel' even worse.
I know Cobb uses a single value across most cells and 0s for a few of them. I am actually experimenting with this table myself right now so stay tuned for results.
Ziggyrama is offline   Reply With Quote
Old 12-08-2006, 02:21 PM   #7
goixiz
Member#: 99128
2005 SAAB 92x
>>--^^ i will be keeping my eye out
thanks zig
Old 12-08-2006, 02:34 PM   #8
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
Check your PM....
gaby is offline   Reply With Quote
Old 12-24-2006, 03:55 AM   #9
cbarth3
Member#: 67249
2004 WRX
ziggy any more info on this? I have an 04 and this is something that I am really trying to study about. I have looked at a couple roms and they all reduced by 10% like you said here is a pic of them
http://forcedinductionlv.com/attachm...tachmentid=533
cbarth3 is offline   Reply With Quote
Old 12-29-2006, 09:22 PM   #10
cbarth3
Member#: 67249
2004 WRX
any ideas ziggy?
Close loop to Open loop and vice versa Walker Lam Open Source Reflashes 8 01-30-2009 10:51 AM
Closed Loop to Open Loop Transition, when? NavyBlueSubaru UTEC 19 03-03-2006 10:30 PM
UTEC Closed and Open Loop Fueling manman99 Engine Management & Tuning 8 05-09-2005 10:45 AM
Closed versus open loop - UTEC chrislehr Engine Management & Tuning 1 05-14-2003 01:14 PM
My thoughts for closed-loop to open-loop with link. Chav Normally Aspirated with bolt-on Forced Induction Powertrain 0 06-28-2002 02:10 PM
