Old 12-08-2006, 12:43 PM   #1
spdracr00
Member#: 65823
1996 Impreza L
Red
Default 92 legacy L wont start
Ok, so this has been going on for the last month or so, but its random so that makes this suck. I go to start the car and I turn the key and nothing happens, I have full power all the lights come on and the seatbelt moves, but nothing from the engine, no clicking no nothing. In the past i've opened the hood checked all the wires and shut the hood and it starts up, now when i do that it doesnt work. i'm thinking loose wire maybe? any ideas before I start tearing into her?
-ben
spdracr00 is offline   Reply With Quote
Old 12-08-2006, 12:51 PM   #2
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
-ben
Bad ground?
Bad starter?
Bad ignition?
I had the same issue and mine turned out to be a bad starter ground. Pull off the starter and hook a hot and cold lead to it while out of the car. Hold on to it and see if she spins.
Sub_Speed_Guy is offline   Reply With Quote
Old 12-08-2006, 12:55 PM   #3
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
probably your starter is on its way out
bugeye829 is offline   Reply With Quote
Old 12-08-2006, 01:14 PM   #4
spdracr00
Member#: 65823
1996 Impreza L
Red
so far i've checked the wires to the starter, checked the battery terminal wires(my pos cable needs to be cleaned ) nothing.. started tapping on the starter and it tried to turn over which is more life than i've seen in a while, so i'm gonna have my friend come over and we'll try and jump it and see if it starts. the car is suposed to have a new starter and it looks new. might do the battery stuff first and see if that helps. maybe try a different battery. worked fine all summer long til it started to get cold.. so maybe its just a weak battery.
Old 12-08-2006, 05:18 PM   #5
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
is it manual transmission? maybe your clutch-in sensor is on the way out?
TRH_legacy2k is offline   Reply With Quote
Old 12-08-2006, 09:32 PM   #6
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Clean the wires. I've read far too many threads on here with "starter" problems and its the battery terminals being dirty.
If it's not that, then diagnose further. I agree with possibly being a clutch pedal sensor, or the automatic park sensor (make sure it's seated all the way).
Plays_With_toys is offline   Reply With Quote
Old 12-09-2006, 01:37 AM   #7
tysn
Member#: 79735
i had the same problem with my corolla for a few months , one day i was looking at the battery and noticed the wire on the positive post, the wing nut where all the wires join on was loose, i tightened it up and it has never had that problem since.
tysn is offline   Reply With Quote
Old 12-09-2006, 03:12 PM   #8
ivwarrior
Member#: 100610
MBP
Is it an aftermarket starter? I've seen those dead in the box.
ivwarrior is offline   Reply With Quote
Old 12-09-2006, 04:09 PM   #9
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
check the battery terminals.- no seriously.
legacydreamz is offline   Reply With Quote
92 Legacy No Start (got fuel, got 1/2 spark) Calamity Jesus Normally Aspirated Powertrain 8 06-30-2006 10:13 AM
trouble starting 92 legacy legacy4049 Normally Aspirated Powertrain 16 04-24-2006 01:52 AM
My 1997 Legacy GT wont start! Project84 Normally Aspirated Powertrain 17 03-06-2006 06:09 PM
92 legacy turbo wont start damonmlime Pre-2002 Factory Turbo Powertrain 6 11-05-2004 11:42 AM
92 Legacy Studdering on starts TheShadowWRX Normally Aspirated Powertrain 2 07-09-2003 06:34 PM
