Old 12-08-2006, 06:37 PM   #1
stoney98
Member#: 65888
2010 FXT
Default Upgrading Rear Brankes '03 TS - Drum to Disc
I searched but couldn't find anything related to upgrading the stock rear drum brakes on the 2003 TS to disc, even in the stickies. I have read all the braking stickies thoruoughly, but I still have noob questions so forgive my ignorance. I do understand most wrench talk, but I apologize if I ask for more info on commonly known iinfo.
I am looking at upgrading my rear drums to a set of stock WRX 2-piston discs. When I do make the change, I will be doing the fronts, upgrading to SS braided lines f/r, and most likely running Stoptech high friction street pads f/r. This car is my daily driver, but I am slowly working my way into AutoX, so I have a longterm goal of improved handling and braking. Additional power is on the list, but only after I have the car setup handling and brake-wise and my skill levels are at a level to be able to appropriately drive with additional power.
I am currently running 16" Stock WRX wheels, and I have already upgraded my rubber to ContiExtreme Contact, so I will not be doing any changes to the wheels. The conti's, new rotors [same as stock] and stoptech pads for my 2-pots were just installed with dramatic effect, but I am now starting to notice a more 'mushy' feeling from the brakes that I want to correct. I'm assuming the switch to rear disc will improve both feel and performance notably.
I have lots of questions so please be nice, I assume answers to these questions will lead to more questions. Thank you in advance.
1. Will my current 2-pot fronts fit on the rear with adapters, or are fronts and rear incompatible?
2. Since I am most likely going to upgrade to stock WRX 2-pots in the rear with slotted rotors. What am I going to need?
So far I note: WRX caliper, Slotted rotor, SS brakelines, new fluid (any particular reccomendations?), and new pads.
3. I have access to a power bleeder, as well as most of the necessary tools, those I do not have I will acquire. Any notes to what tools will make it easier to do the job properly would be greatly appreciated as well. I do have and use a torque wrench.
4. I saw the notes on diagonal vs f-r bleeding and will bleed the brakes accoringly (diagonal).
As mentioned, I will also be doing my fronts, but I am still deciding which way to go, as I currently have the stock 2-pots. I am looking for both better feel and performance, so I need to research more as to what brakes provide both without breaking the bank. Any suggestions are welcome.
One question I have regarding the WRX front 4-pots, is do they have a greater braking contact than the TS 2 pots? I saw in one of the stickies that some subie 2-pots have the same braking power and some subie 4-pots.
Thanks in advance!
-Mark
stoney98 is offline   Reply With Quote
Old 12-09-2006, 03:58 AM   #2
ten80
Member#: 53625
00 EJ205 LGT LTD
I have the exact same car and did the conversion two years ago. To answer your questions:
1. no, front rotors will not fit in the rear because the rear rotors have a deeper hat to accomodate the parking brake. nor will front calipers fit on the rear because the brake caliper bracket mounting holes are way closer together in the rear.
2. You need disc rear hubs! Converting drum hubs to disc requires 80% of the parts off a disc hub, plus pressing out the wheel bearings. bad idea. Make sure you find hubs with parking brake cables installed, since its a PITA to swap them from the drum to disc hubs. To recap, you need: calipers, pads, caliper brackets, rotors, hubs, e-brake cables, wrx brake lines.
3. powerbleeder is not necessary. You can bleed by pumping the brake pedal since you are only introducing air into the very end of the system (brake caliper and line) and not the master cylinder. 2-3 brake beeds will flush all the air out.
4. yes, the diagonal method is preferred
lastly, if you want a cheap and effective front brake upgrade, get some 03+ wrx caliper brackets and 11.4" rotors. These will give you a nice power boost from the stock 10.7" rotors and the cost will be very reasonable. Subaru 4-pots do have a larger pad contact surface, however, it is debatable whether or not they have more power since they are driven by the same master cylinder. It is certain that they have less fade since there is more piston surface area to absorb and dissipate heat.
oh, I should mention that you can search for "disc conversion" and you'll find some threads of interest. the drum to disc conversion is the same for all years of imprezas.
ten80 is offline   Reply With Quote
Old 12-09-2006, 11:00 PM   #3
stoney98
Member#: 65888
2010 FXT
thank you VERY much!
Old 01-26-2008, 10:24 PM   #4
mattbesquare
Member#: 169360
Thumbs up Thank you..I am starting to get an idea of what I am in for
But I have an 08, so I am going to have to wait for a few wrecks on ebay to get the rear hubs.
ALL 2008+'s! Get the premium upgrade! it will be cheaper in the long run!
mattbesquare is offline   Reply With Quote
Old 06-11-2009, 10:20 PM   #5
skiley22
Member#: 188750
2008 Impreza 2.5i
Lightning Red
https://www.trademotion.com/partloca...28&catalogID=2
Your welcome haha
I'll be doing this upgrade...soon enough.
I also agree with getting the premium upgrade..it is worth it.
skiley22 is offline   Reply With Quote
Old 06-11-2009, 10:47 PM   #6
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
increasing gain will improve pedal feel. increasing/decreasing brake system gain can be achieved several ways:
for more gain...
increase brake pedal ratio
increase brake booster gain
decrease master cylinder piston diameter
increase caliper piston diameter
increase brake pad coefficient of friction
increase rotor effective radius
decrease tire rolling radius
reducing compliance can also improve pedal feel. stainless steel hoses reduce compliance and improve pedal feel.
motul rbf 600 brake fluid, or any other major brand name you trust that has a high dry/wet boiling point fluid. look for a dry boiling point of around 600 and a wet boiling point of around 500 degrees F. do NOT use a DOT 5 brake fluid which contains silicone... never use old or opened brake fluid. always use a new, sealed container as the fluid rapidly becomes "wet" over time once opened.
size and shape of brake pad do not contribute to gain because a brake pad material's coefficient of friction is independent of the size of the brake pad itself. however, a larger pad will have a longer life span and provide more thermal mass to absorb heat.
switching from drum to disc will improve pedal feel, dramatically increase thermal mass, and increase cooling (drums are closed and don't cool well via convection).
um, that's all i can think of off hand.
bcware is offline   Reply With Quote
Old 10-29-2010, 06:53 PM   #7
04wrexsti
Member#: 225937
'10 SE STI '04 FXT
'00 RS race car
im planning on building a 02 2.5ts wagon rally car, it would be nice to get rid of the rear drums and swap for disks because well brakes are very important in rallying
so basically you need the rear hubs and everything of a car with disks in the rear? does it matter if they are from a sedan, wagon, bugeye, hawkeye, etc ?you get what im talking about.
04wrexsti is offline   Reply With Quote
Old 10-29-2010, 08:24 PM   #8
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
high five good stuff
feint05 is offline   Reply With Quote
Old 12-01-2010, 12:53 PM   #9
tethy
Member#: 262794
Would the same apply to a drum to disc conversion on a 98 L sedan?? The new hubs and cables are my main concern. I so want to ditch the drums.....
tethy is offline   Reply With Quote
Anyone doing rear drum to disc upgrade soon? p2adan North West Impreza Club Forum -- NWIC 15 06-17-2009 04:20 AM
Drums to Discs in an 02 TS Falkonite Interior & Exterior Modification 1 10-07-2008 12:28 AM
$325; Rear drum to Disc JDM VENTED 10.5" disc brake for WRX or GC8 complete KIT supermoose Private 'For Sale' Classifieds 10 02-25-2006 02:50 PM
2002 OS rear drum to disc upgrade IAmNoChode2 Brakes, Steering & Suspension 0 05-13-2002 05:49 PM
Upgrade 02 outback brakes from drum to disc? Marty S Brakes, Steering & Suspension 2 10-21-2001 05:26 PM
