Old 06-13-2007, 02:12 PM   #26
Psychopat
Member#: 34536
2008 Impreza WRX STI
What should someone do if the brake system was flushed with DOT 5 fluid ?
Psychopat is offline   Reply With Quote
Old 06-13-2007, 02:45 PM   #27
ESmooth
Member#: 118082
Originally Posted by ButtDyno View Post
I'm sure ESmooth will check in tho, now that the StopTech bat-signal has been fired into the sky.
john
It must heve been cloudy when the signal wnet up because I never saw it...I hope my bat senses arent fading
You nailed it with your explanation though.
ESmooth is offline   Reply With Quote
Old 06-22-2007, 07:43 PM   #28
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
great info! every time I read a thread on this site, I realise how bad it could be to just go out and buy something. research is key!
ButtDyno
Obviously you're not a golfer
haha! "he peed on your ****ing rug."
2point0 is offline   Reply With Quote
Old 11-21-2007, 04:11 PM   #29
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Mental note to borrow some stuff from here:
http://www.stealth316.com/2-brakeupgrade.htm
Old 12-27-2007, 07:10 PM   #30
SubaruV7
Member#: 167631
I got a 2000 STI wagon V7, the chassis model number is GGBA5EH, I was wondering if I can upgrade my brake kits to brembo or other racing kits? Thanks!
SubaruV7 is offline   Reply With Quote
Old 12-27-2007, 07:14 PM   #31
keirnna
Member#: 50167
1996 Subaru STI RA
Did you read the FAQ? If you had an STI wagon you should have the Subaru 4-pots. I would stick with those.
keirnna is offline   Reply With Quote
Old 01-23-2008, 10:41 AM   #32
Butt Dyno
Member#: 17301
is the "dark side"
Update: Added "do I need to buy new pads when I buy new rotors / do I need to buy new rotors when I buy new pads" to post #3.
Old 02-23-2008, 11:37 AM   #33
hanzo918
Member#: 82148
1992 Daihatsu
Charade
Question:
Is it possible to bed in brakes on a dyno or simply have them on a jack/rack and do the process?
It is quite difficult for people (especially in southern California) to find a place to bed in brakes properly (without getting busted by a cop).
hanzo918 is offline   Reply With Quote
Old 02-23-2008, 11:57 AM   #34
BIGSKYWRX
Member#: 7958
09 GH B+
I don't think so. No remote areas where a guy can go- your not talking reckless speeds for most bed ins- most only need to get up to 60ish
Old 02-23-2008, 05:45 PM   #35
hanzo918
Member#: 82148
1992 Daihatsu
Charade
Yes and no. 60ish is high speed for local streets, and it's definitely not very doable on freeways...
Why isn't it possible to bed in on a dyno?
Old 02-23-2008, 06:12 PM   #36
Todd TCE
Member#: 90575
You could put the car on stands off the ground and achieve the same results. It's only heat cycles you're looking at. (I was going to say a jack but I see some problems there...) Just don't over do it as you won't have a ton of air flow. Unless you fan it.
Todd TCE is offline   Reply With Quote
Old 02-28-2008, 03:12 AM   #37
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
Thanks, great job! Saved me some money sitting and reading all of this.
RallyIt07 is offline   Reply With Quote
Old 03-23-2008, 09:42 PM   #38
Butt Dyno
Member#: 17301
is the "dark side"
Added drum to disc stuff to 4th post. Thanks mechanizedmedic!
Old 03-27-2008, 11:25 AM   #39
Butt Dyno
Member#: 17301
is the "dark side"
Good StopTech stainless line FAQ here:
http://www.stoptech.com/products/sta...al_lines.shtml
Old 04-30-2008, 11:06 PM   #40
Butt Dyno
Member#: 17301
is the "dark side"
Added the 2002 pad shape stuff to post #4.
http://www.stoptech.com/tech_info/faq_wrxcalipers.shtml
Old 07-28-2008, 09:35 AM   #41
Viperguy324
Member#: 121108
2006 06 Spec C
Ok after reading all this I feel like the title should be "StopTech ..why there the Best" ... Not BBK FAQ.
How about reviewing some Kits?
And I would love to hear why STOPTECH would put DNF for AP Racing? ..what the hell is that for? Did the car fail? There is life outside Stoptech.
Viperguy324 is offline   Reply With Quote
Old 07-28-2008, 09:59 AM   #42
BIGSKYWRX
Member#: 7958
09 GH B+
I wouldn't hesitate a second to purchase a Brembo (grand turismo) or AP kit
Old 07-28-2008, 08:53 PM   #43
Butt Dyno
Member#: 17301
is the "dark side"
This is for general tech, not for reviews. We have a whole forum for reviews.
The DNF was for a given team running AP Racing. It doesn't mean anything about ALL AP Racing calipers or that the company sucks. It probably means that the team that chose them just happened to break their car for some reason.
Yes there is life outside of Stoptech. I even say
"Now - admittedly this is StopTech's website. But StopTech doesn't make any outrageous claims. The stock RSX in that comparison was on Michelin Pilot MXM4's - an all season tire. It did 60-0 in 132 feet. Of the two StopTech shod cars, one was on Hoosiers (very sticky) and one was on Advan A032R's (also very sticky). So you'd expect them to stop noticeably shorter than the stock car on all seasons."
The fact is, some cars on race tires with BBK's lost to a stock RSX on stock tires. The implication is, braking faster is not as simple as throwing on the biggest calipers you can find. Someone buying AP's probably knows that, but you never know.
Old 08-17-2008, 02:41 PM   #44
El Capitan
Member#: 121261
06 STG 2+ STi
CGM
Anybody have dependable data on the benifits of brake ducts? Something like the RCE kit or similar? Do they really work? List of known benifits? Other options?
El Capitan is offline   Reply With Quote
Old 08-17-2008, 04:13 PM   #45
hanzo918
Member#: 82148
1992 Daihatsu
Charade
What I do want to know is what pads they were running for each kit during those tests, though.
Old 08-17-2008, 06:25 PM   #46
BIGSKYWRX
Member#: 7958
09 GH B+
I wouldn't run track days w/o them personally. No empirical data to provide (wish I had laser pyrometer to document it), but they clearly reduce brake temps.
Old 01-22-2009, 06:05 PM   #47
Butt Dyno
Member#: 17301
is the "dark side"
Added two new FAQ's
Drilled rotors *must* be good for track use! Porsche/BMW/Lamborghini use them on their cars!
But if you cast the holes in place, it should be better than drilling them, right?
Old 01-22-2009, 06:21 PM   #48
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I find this hard to believe because when you're on stands, you're only stopping wheels, which weigh what, like 40 pounds a pop with a tire? You're not stopping the car which weighs 3000ish.
chazly413 is offline   Reply With Quote
Old 04-07-2009, 10:02 PM   #49
yo vanilla
Member#: 71903
11 Audi A4 6MTQ
13 Mazda CX-5
I've been looking for a good how-to on replacing the 4-pot pads and rotors, and the 2 pot rear pads but haven't found it. Anyone got a link?
yo vanilla is offline   Reply With Quote
Old 04-07-2009, 10:08 PM   #50
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
This is a complete 4-pot caliper install but it includes fitting the pads
http://www.scoobymods.com/forums/sub...rake-t349.html
UkNuck is offline   Reply With Quote
The problem with changeing Big Brake Kit in the front and leaving the stock ChAi Brakes, Steering & Suspension 5 03-19-2006 10:34 PM
Anyone installed the AEB Front O.E. Caliper Big Rotor Brake Upgrade Kit? WhiteWRoX Brakes, Steering & Suspension 2 06-02-2002 11:05 PM
Big Brake Upgrade Kit in the Works bsquare Brakes, Steering & Suspension 50 05-20-2001 04:13 PM
