Old 12-09-2006, 06:55 PM   #1
GlenCastleberry
Member#: 63067
2002 Impreza WRX
World Rally Blue
Default Problem with switching maps
I currently have an AP installed on my 02 WRX. I am running the stage2 p1 octane map that came with the AP. However, I have tried to switch to stage 2 93 octane several times. It says its sending map....... and then "ok", but when I check current map it's running it still says its stage 2 91 octane. Is there something I'm forgetting to do here that might be preventing me from switching maps?
Any help would be appreciate! Thanks!
-Glen
GlenCastleberry is offline   Reply With Quote
Old 12-09-2006, 07:10 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
The AP doesn't show rt maps, it only shows your base map.
wrxdrvr is offline   Reply With Quote
Old 12-09-2006, 07:12 PM   #3
GlenCastleberry
Member#: 63067
2002 Impreza WRX
World Rally Blue
Does this mean that once the map has flashed it will be active only until I restart the car? Or is the newly flashed RT map active until I select a new RT map?
Thanks
-Glen
Old 12-09-2006, 08:24 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
The rt map you put on over the base map will stay on until you change it or until the battry gets disconnected, then it will revert back to the base map. You have to remember what rt map you flashed on and if you aren't shure which rt map is on... just re-flash it again.
Problem with any map other than stock. SubiSam Commercial ECU Reflashes 0 11-26-2008 11:06 PM
STI UTEC with TXS map sensor and map switch bgod Engine/Power/Exhaust 3 09-06-2007 10:22 PM
how to switch maps w/o map selector switch warpspeedwrx UTEC 5 04-01-2007 03:25 AM
Problem with my maps. 01G_WRX_02 UTEC 0 03-18-2006 02:46 PM
problem with utec remote map switch bluespeed Engine Management & Tuning 4 03-24-2003 04:02 PM
