Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 12-10-2006, 04:14 PM   #1
Chi_San
Member#: 53558
2002 WRX Wagon
Default Upgrade fuel tank?
My gas tank is dented, and the level senders aren't working anymore. Plus, I need a new fuel pump (again).
would it be possible to pull my 14 or whatever gallon tank and replace it with a 20 gallon tank from a WRX or other car?
It's a 2000 Legacy Sedan.
Chi_San is offline   Reply With Quote
Old 12-10-2006, 04:49 PM   #2
ten80
Member#: 53625
00 EJ205 LGT LTD
wrx gas tank is not the same because our legacies (2000+) have a different tank to accomodate the multi-link rear suspension. You should be able to fit any 00+ Legacy, outback, or baja tank. WRX tank si far from 20gal... try 14.8gal!
ten80 is offline   Reply With Quote
Old 12-10-2006, 05:03 PM   #3
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I thought the WRX tank was 15.9 gallons same as my Legacy?
Wiscon_Mark is offline   Reply With Quote
Old 12-10-2006, 10:54 PM   #4
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
either way, I can't imagine the wrx had a 20 gallon tank! It's not an F-250 for cryin' out loud!!!
janikphoto is offline   Reply With Quote
Old 12-10-2006, 11:53 PM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
No, AFAIK no Subaru had a 20Gallon tank.
SVX maybe???
Old 12-11-2006, 11:04 AM   #6
GotTurbo
Member#: 64186
1998 A MONSTER
SOON BMW STEEL GREY
I have my gas tank off my 98 legacy sitting in my garage taking up room.
-Matt
GotTurbo is offline   Reply With Quote
Old 12-11-2006, 04:09 PM   #7
ten80
Member#: 53625
00 EJ205 LGT LTD
I stand corrected, WRX capacity is 15.9gal, though I've never ever put fit more than 14.5 in my fiancee's. I think that the 98 legacy tank is the same as on GC imprezas. No matter, though, it won't fit a 2000+ legacy because of the change in rear suspension.
Old 12-11-2006, 05:34 PM   #8
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
My tank is 15.9 gallons, I don't think that any other BD/BK/BG is different.
Old 12-11-2006, 05:58 PM   #9
Chi_San
Member#: 53558
2002 WRX Wagon
-Matt
If you were closer, I'd offer to buy it from you. My tank needs replacing so bad.
Well, thanks for the replies. I thought my mom's 2003 Outback had a 20 gallon tank, maybe I'm thinking of something else.
Old 12-11-2006, 05:59 PM   #10
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
You could go with a custom dual 55-gallon drum setup.
KD7000 is offline   Reply With Quote
Old 12-11-2006, 07:19 PM   #11
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Am I the only one wondering why/how your current tank is damaged?
xcntrk75 is offline   Reply With Quote
Old 12-12-2006, 12:53 PM   #12
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Originally Posted by Crazy Australian Police Mechanic
It's the last of the H-4's!! BRRRRM!!! BRRRM!!!!
I give the dual drums a hearty +1. Now cut your leg off with this hacksaw.
LetItSnow is offline   Reply With Quote
Old 12-12-2006, 06:26 PM   #13
Dobes
Member#: 164
2008 Exige S240
FYI, I've got a WRX tank in my '97 Legacy GT and as far as I know it's a direct fit. You may need lots of clips and stuff depending on how similar all the emissions equipment is but it at least fits in the BD cars. You may want to start soaking all the bolts for your old tank in PB Blaster now.....
JD
Dobes is offline   Reply With Quote
Old 12-12-2006, 08:29 PM   #14
ten80
Member#: 53625
00 EJ205 LGT LTD
I'm confused. everyone keeps mentioning pre 99 gas tanks, but that doesn't seem to be what he needs!
Old 12-14-2006, 12:52 PM   #15
LetItSnow
Member#: 38222
'10 &'12 Foresters
What did you get out of that swap, or was it just a sweet deal on a matching part?
Old 12-14-2006, 04:17 PM   #16
nyyankees003
Member#: 71877
2003 Legacy L SE
Mystic Blue Pearl
yeah but the 2000-04 is a different style than pre-00, so im guessing thats why it wouldnt fit the 2000. im definately no expert tho, just guessing seeing as just about nothing fits both pre and post 00's
nyyankees003 is offline   Reply With Quote
Old 12-14-2006, 06:17 PM   #17
ten80
Member#: 53625
00 EJ205 LGT LTD
^ your guess is correct.
I know this first hand, since I have a wrx and an 00 legacy in my garage and have spent extensive time under both.
Old 12-15-2006, 02:04 AM   #18
Chi_San
Member#: 53558
2002 WRX Wagon
Well, as to why it was damaged, I don't know.
I sold the BE three days ago, and have a GT Wagon now, 1998.
Old 12-15-2006, 02:13 AM   #19
ten80
Member#: 53625
00 EJ205 LGT LTD
ah, that makes sense. i have an 03 WRX tank sitting in my driveway if you are looking for one
2006 Impreza gas tank fill - fuel tank filler neck problems. Psybin Warranty Issues & SOA Problems 11 01-08-2007 10:48 PM
Are WRX fuel tanks interchangable with STi tanks? Amazake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-09-2006 03:57 AM
Fuel Tank Leaking After Fuel Pump Upgrade TheShadowWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-28-2004 09:36 AM
Oil and fuel starvation in tight turns? Are there baffled oil pans and fuel tanks? Digital_Boy Normally Aspirated Powertrain 6 01-17-2001 09:01 PM
Removing fuel tank & Fuel cell foam dbrown Technical Forum Archive 3 08-13-2000 09:16 AM
