Old 12-10-2006, 03:37 PM   #1
zumspdrx7
Member#: 113535
2012 OB3.6R/RX-7/E92
Question Check Engine / Cruise Control Flashing?
i was driving my '04 LGT back from my girlfriend's, when all of a sudden i see out of my periph that i have some new lights on. My 'check engine' light came on in the cluster and my 'cruise control button' started flashing, and i couldnt use my cruise control. my car had @65,000 miles and i havent had my 60k service done yet. i had my mechanic friend take a look at it at his dealership, and we checked for codes and i think (forgive me for not fully remembering) all that came up was emmissions (Which can be 1 of a myriad of things.) it has since shut itself off, came back on for a lil while, then shut itself off. i figured i should ask around just to make sure im not doing anything detrimental to my car's health by driving it. its driving fine, so im not fully worried. i put a K&N Drop-In Filter in a couple days before it started doing this. think it could be interrelated? thanks in advance.
i did a search on NASIOC, LGI, and Scooby Mods and couldnt find anything similar to this. anyone else have anything like this happen?
zumspdrx7 is offline   Reply With Quote
Old 12-10-2006, 04:03 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I have heard of this. Did you search all of Nasioc, or just the legacy forums?
Wiscon_Mark is offline   Reply With Quote
Old 12-10-2006, 04:19 PM   #3
zumspdrx7
Member#: 113535
i found informatin on people who have had the same problem, but no definite answers on what it is or what to do
Old 12-10-2006, 05:40 PM   #4
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
I have had that happen once on my 04 STi swapped Leg. I used ECU Explorer and found it to be an emissions code in the tank for the pressure switch. I cleared it with the Access Port and it hasn't returned.
It may be your O2 sensor going bad (though it should have it's own code), or a sensor in the fuel tank (pressure, drain, and one other I believe). I think they disable the cruise so you get those pesky emissions codes looked at. I don't think it is causing any damage to your car, but if it repeats, you may want to have the code pulled to see which sensor is triggering the code and start from there.
UTCiv is offline   Reply With Quote
Old 12-10-2006, 11:03 PM   #5
zumspdrx7
Member#: 113535
thanks a lot UTCiv. it hasnt come back since, but if it does, ill bring it in and have it fully checked out.
Old 12-11-2006, 04:05 PM   #6
zumspdrx7
Member#: 113535
it came back on again today.
i set up an appointment to get it checked out tomorrow at Long Subaru in Webster.
ill let you guys know what it turns out to be.
Old 12-29-2006, 07:59 PM   #7
zumspdrx7
Member#: 113535
for archiving purposes, it turned out to be my Catalytic Converter.
Subaru paid to fix it due to emissions.
Old 12-30-2006, 09:57 AM   #8
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
<linky>
Lucky you, that you didn't get a struggle like the other guy.
LetItSnow is offline   Reply With Quote
Check Engine light W/ flashing cruise control? parad0x Newbies & FAQs 6 05-24-2008 01:18 AM
check engine and cruise control flashing AWD0425 Electrical & Lighting 2 03-04-2008 07:09 AM
Check Engine light W/ flashing cruise control? LiDrummer Newbies & FAQs 39 07-09-2007 12:56 PM
check engine light w/ flashing cruise control STi in ur face Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 08-22-2006 09:34 PM
Check Engine/Cruise Control light Bluewrxsti05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 08-18-2006 01:21 AM
