Old 12-10-2006, 07:09 PM   #1
wagonman138
Member#: 89697
Default SVX to rwd? tranny diagram?
Does anyone know of a way to convert a SVX to RWD? I've heard of people welding the planetary's but i was wondering if there was an easier way? maybe electronically? Also does anyone have a diagram of the trans that they can send me to study before i start disecting it?
wagonman138 is offline   Reply With Quote
Old 12-11-2006, 01:02 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
With keeping the trans as automatic.....there's really not a way of doing it without the trans killing itself extremely quickly.
The rear extension housing/clutch packs are not designed to handle that much power. You'll nuke them in a heartbeat.
Here's some various scans that may help you to understand the auto trans
Look for the stuff labeled AT.
http://www.main.experiencetherave.co...ans/FSM_Scans/
These three specifically talk about the AWD system for the autos
http://www.main.experiencetherave.co...er_system1.jpg
http://www.main.experiencetherave.co...er_system2.jpg
http://www.main.experiencetherave.co...er_system3.jpg
Alternatively, if you swap in a 5spd, you can weld the center diff, remove the drive pinion shaft or some other combo, and have a RWD car.
I'd also suggest checking out www.subaru-svx.net/forum
Legacy777 is offline   Reply With Quote
Old 12-11-2006, 08:41 PM   #3
wagonman138
Member#: 89697
Thanks for the good info. And since that is the case...does anyone know of someone who makes a bellhousing adapter to run a SBC tansmission? Or another auto that will work? I can probably make the adapter plate but buying things that i know will work is so much easier. I picked up the car for real cheap with a half busted trans and bent front CV shafts and decided to turn it into a dragster for ****s and giggles. I'd rather keep it an auto cause its gonna be used almost completly on the strip. Any info will help. thanks
Old 12-12-2006, 12:55 PM   #4
Legacy777
Member#: 4800
Your best resource will probably be the SVX network.
The project sounds like a pretty good project though
RWD Information needed. to conver 02 to RWD quikcobra Transmission (AT/MT) & Driveline 1 02-27-2010 10:08 PM
RWD Tranny for Hot Rod LowFast Subaru Conversions 19 12-15-2008 11:53 AM
RWD tranny for EJ257? dl337j00 Transmission (AT/MT) & Driveline 1 08-28-2006 10:15 AM
wrx motor to a t-5 or t56 rwd tranny? Bonjo2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-25-2006 05:04 PM
5spd tranny diagram svx_commuter Transmission (AT/MT) & Driveline 0 08-12-2003 09:01 AM
