Notices
Old 12-11-2006, 01:53 AM   #1
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
OMGHi2U Fuel line T for NX kits.
hey guys i have a 2006 wrx 20G'ed and im installing a nitrous kit to help my spool out anyways this is my problem i have a nitrous express stage 1 EFI kit, and i want to tap into fuel line i chose to cut and place the T fitting it comes with into i beleave it was the "green" fuel line as the connecter to the fuel rail was green and it had a tiny metal cylinder looked like a miny fuel filter/ strainer of sorts on it well i cut my fuel line and place the T which doesnt fit very tight in the fuel line but i hose clamped it anyways and i went to leak test it and it spilled gas everywhere so this leads me to my question does NX sell a t fitting that better fits or is there anywhere i can get a fitting that would be much tighter maybe one size larger with the same a/n threading? links would help very much and anysort of suggestions on where else to tap for fuel? i couldent find any fuel pressure tester port like the intrustions said pictures are nice also! and one more question is it ok to place the nozzel about 4 inches from the throttle body? thank you everybody
-dennis
Rexxyou is offline   Reply With Quote
Old 12-12-2006, 04:31 AM   #2
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
guess no one can help me out
Old 12-12-2006, 08:45 AM   #3
hippy
Member#: 36528
2002 Impreza Wrx
The fuel filter is on the drivers side of the car near the shock tower. Fuel goes in one tube, and out another. Tap the tube that's coming off the fuel filter. If you want, you can get a second hose as to not have to cut a fuel line.
peace
APS inlet fuel line mods for 02 WRX? tobylazur Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-27-2009 10:12 PM
Fuel Line Diamter for 04 N/A BrysImpreza Normally Aspirated Powertrain 0 02-19-2008 01:03 PM
anyone have a nitrous Intercooler wiring diagram for NX kit perrin247 Water/Methanol Injection, Nitrous & Intercooler Cooling 2 08-04-2007 10:23 AM
would the series to parallel fuel line conversion for RS work on WRX? whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-22-2004 01:16 AM
fuel line for zex kit? jasona Normally Aspirated Powertrain 9 04-25-2002 07:30 PM
