Old 12-11-2006, 03:38 AM   #1
xtian
Member#: 93248
95 20g powered gc8
PPG'd yO! & is250 AWD
Default valve-to-piston clearance?(ej20g+v7block)
just a quick rundown.. ej20g went. tore it up. to see what was goin on and was planning on swapping a v7 sti 2.0 shortblock with wrx 2.0 wiseco pistons.. i noticed that the valve relief on the ej20g pistons are quite difrent(deeper) from the wisecos. i was just wondering if theres a way for me to check the clearance. am i overthinking this? since this is an interferance motor.... if timing is right.. i shouldnt worry about anything right??!?
xtian is offline   Reply With Quote
Old 12-11-2006, 08:31 AM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Right. And as far as I know, valve angle (between intake and exhaust valves) has not changed from EJ20G to EJ205/207 and since the EJ20G has much less lift than the EJ207, this should not be a problem.
Marnix is offline   Reply With Quote
Old 12-11-2006, 10:29 AM   #3
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Compression ratio will determine valve reliefing (lift being equal). so what was the CR of the EJ20G and whats the CR of the new pistons?
def
dug-e-fresh is offline   Reply With Quote
Old 12-11-2006, 12:18 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
No one knows the stock value. I asked the Aussie Tech and he didn't know. I can tell you it's no greater than 0.1 inch, or 2.5 mm, and it's probably more like 0.080. When in doubt measure with clay and deliberately advance the timing belt to check. AVCS complicates things enormously--I can tell you from experience.
Old 12-12-2006, 12:25 AM   #5
xtian
Member#: 93248
95 20g powered gc8
i think stock ej20g comp ration is 8:1 and the wisecos it says 8.35:1
and for the pre-ej20's not even wisecos have a value on their chart.. but yeah.. everything should be fine.
Old 12-12-2006, 01:11 AM   #6
gumby647
Member#: 2532
2001 2.5RS-T
BRP
The way I check P-V clearance is to assemble one intake and one exhaust valve in the head with really light springs so it's easy to push the valve off the cam. Then put the head on and time the cams. The pistons and valves are closest together between 5-15deg before (EX) and after (IN) TDC on overlap. So you can use a dial indicator to measure piston to valve clearance just push the valve down till it touches the piston. I check every 2 degrees between 5 and 15.
You can increase P-V clearance (if needed) by going to bigger lobe center numbers. Depending on the profile you can get around .004" from a 1 degree change in cam timing.
gumby647 is offline   Reply With Quote
Minimum piston to head clearance?? graphtricks Built Motor Discussion 12 01-11-2009 12:56 AM
Piston to Bore clearances? 187 Built Motor Discussion 5 02-18-2008 04:16 PM
Can you Grind Pistons down to make clearance? Mike1967 Built Motor Discussion 34 05-27-2007 08:16 AM
valve-to-piston + valve-valve clearance specs? HamFist Built Motor Discussion 9 08-13-2006 05:04 AM
JDM V8 piston to deck clearance? Anybody? ebeck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-28-2004 03:26 PM
