Old 12-11-2006, 07:09 AM   #1
subjfd
Member#: 106854
Default Time for new alternator I assume...
For the last year, noticed that my light were dimming slightly while idling. Then lately, all my electrical such as wipers would slow down as I would slow down as well.
Today, my radio turned off as my rpm went down, and back on as my rpm went up while idle or running.
Turned my car off, and it would not start again.
My battery is exactly 1 year old (a 5 year warranty one).
AM I correct in assuming time for a new alternator ?
BTW,
93 Legacy 4WD wagon, 5 speed, no air.
Thanks
JF
subjfd is offline   Reply With Quote
Old 12-11-2006, 07:23 AM   #2
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
Sounds like that's the case to me. Are you over 150k miles?
MYfirst00 is offline   Reply With Quote
Old 12-11-2006, 07:54 AM   #3
subjfd
Member#: 106854
Around 200 000 miles !
Old 12-11-2006, 08:41 AM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Do you have a multimeter?
It’s easy to test. Throw the meter on the battery with the car off, voltage should read around 12 volts. Take this number as a baseline. Start the car, measure voltage at the battery again, should be in the 14 range showing a charge from the alternator. If there’s no increase from the baseline then your alternator is not providing sufficient power.
xcntrk75 is offline   Reply With Quote
Old 12-11-2006, 09:48 AM   #5
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
Wow, yeah you're due. While you're at it, you might as well replace your positive and ground battery wires.
Old 12-11-2006, 10:01 PM   #6
ivwarrior
Member#: 100610
MBP
I just did a alternator on my '97 Outback, and believe it or not, a Genuine Subaru Reman was far cheaper than aftermarket remans. Like $78 compared to over $170 for the aftermarket units I'd priced. They're incredibly easy to replace, so I did mine myself, don't know what labor charges would be to install one.....
ivwarrior is offline   Reply With Quote
Old 12-11-2006, 10:04 PM   #7
subjfd
Member#: 106854
Where did you buy it from ?
Old 12-11-2006, 10:12 PM   #8
ivwarrior
Member#: 100610
MBP
I got mine from my local dealer, Calkins Subaru in Lewistown, Pa.
Time for new Rotors and Pads for Wilwood setup striker525 Brakes, Steering & Suspension 5 06-22-2008 07:07 PM
time for new coil overs - want a setup for gravel KevinG Brakes, Steering & Suspension 6 11-08-2007 01:13 PM
time for new wires and new coil cudaeh Engine Management & Tuning 0 12-21-2004 06:20 PM
Time for new wheels for the bimmer. wyn525i Off-Topic 34 07-06-2004 04:28 PM
EVO mag times for new impreza matt7184 General Forum Archive 7 12-05-2000 03:38 PM
