Old 12-11-2006, 09:33 AM   #1
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
Default Anyone know anything about this turbo?
I'm trying to look into alternatives to the GT30r for my winter build. Anyone know anything about this turbo? http:
http://www.slowboyracing.com/more.php?id=5910&
It says 650cfm which might be a bit small for my goals.
I'm trying to find a turbo to make 400+ on pump and closer to 475 on race gas on my built EJ205.
japslapr is offline   Reply With Quote
Old 12-11-2006, 07:37 PM   #2
CarQz17
Member#: 101077
2004 FP Green STi
Java Black Pearl
there are plenty of alternatives, and cheaper too...... look elsewhere than the slowboyracing site!
http://forums.nasioc.com/forums/show....php?t=1141476
CarQz17 is offline   Reply With Quote
Old 12-11-2006, 07:44 PM   #3
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Ditto....Try Deadbolt turbo's, much better service IMO.
www.boostplanet.com
They sell and service them and are very knowledgeable on Subaru applications. Call them or check out their website.
I bought my turbo from SBR..... What do they say? If you can't say something nice about someone, don't say anything at all.... : - (
skimobile is offline   Reply With Quote
Old 12-12-2006, 11:22 AM   #4
japslapr
Member#: 100150
02 V9 STi 6spd
The problem I'm coming across is 90% of the "big turbo" information is strictly for 2.5's. It's hard to find spool up numbers or anything like that for a 2.0 with anything over 50lb min.
Old 12-12-2006, 11:25 AM   #5
josh04
Member#: 89288
2002 Rex
Cause if your going to build your engine it's going to change your spool characteristics. For example a higher compression ratio, or a bigger displacement. Things like that will change it. What I would do is go off the 2.5 and just guess around a few hundred rpms difference.
josh04 is offline   Reply With Quote
Old 12-12-2006, 11:27 AM   #6
Frshtrax
Member#: 84374
2005 WRX Wagon
Black Pearl
Frshtrax is offline   Reply With Quote
Old 12-12-2006, 11:50 AM   #7
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
www.boostplanet.com
just for grins, punch in the "business" address of Deadbolt in to google earth and zoom in.
I will also challenge your paradigm that he is knowledgeable on Subaru applications.
there are several 'manufactuers' out there that sell the EXACT same products, but for different prices, with different names.
a deadbolt SZ49 and a FPgreen have the same center housing, same compressor wheels, same hotside wheel and same housings!
a FP red and a SZ60 share a similar story.
the difference is in price and who you feel comfortable with.
Jerry@ deaadbolt builds turbos in his garage.
Rob @ Forced Performance has a degree in mechanical engineering and has worked on gas turbines and turbo chargers all his professional life. FP also has a dedicated factory.
i have no doubt that Deadbolt turns out a fine product at a fair price, but my money is going to be spent somewhere else.
banzai is offline   Reply With Quote
Old 12-12-2006, 11:57 AM   #8
banzai
Member#: 63926
deck EJ 20G stroker
Originally Posted by Frshtrax View Post
right...
know what that is?
it's a GT3071R stuffed in to a 20G compressor housing and mitsu 8 cm hotside.
call them up and ask them to pull one off the shelf and read you the garrett tag off the center housing.
go to www.turbobygarrett.com and look up the numbers.
also the 52 lb wheel is two generations old, as far as the technology goes.
Old 12-12-2006, 12:46 PM   #9
DFL2.5RS
Member#: 73228
2015 White STI
2013 WRX, 2003 Rally car
If you're considering going rotated you might want to check out some of (precision) PTE's turbos. You get a lot for your money
DFL2.5RS is offline   Reply With Quote
Anyone know anything about this TV? Anyone own one? you like it? tacomaprime Off-Topic 64 10-27-2008 11:49 PM
Does anyone have or know anything about this Turbo/Intercooler Ebay special? afterfire6942 Car Part Reviews 1 10-11-2008 11:42 PM
Anyone know anything about this kit sportysubby Interior & Exterior Modification 4 12-02-2001 07:32 PM
Anyone know anything about this place? Orion Texas Impreza Club Forum -- TXIC 4 10-05-2001 02:50 PM
Anyone know anything about this? Retsyn Normally Aspirated with bolt-on Forced Induction Powertrain 10 08-23-2001 05:18 PM
