Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 12-11-2006, 08:42 PM   #1
Richard1296
Member#: 128403
2000 Impreza Outback
Default Idle Question on 2000 OBS
My idle speed seems (to me) to be a little high both cold and hot.
When cold the speed will drop to 1200-1400 rpm after just a minute
or so of running. Then it slowly works it way down to 700 rpm but takes
several minutes to do so after warming up completely.
When warm the engine seems to want to hang around 1000 rpm
when pulling up to a stop and takes a few seconds of sitting still to
finally drop to 700. It pulls hard enough (its an automatic) that
extra brake pedal effort is needed and I would expect it to affect
the braking in snow and ice.
Shouldn't it return to 700 rpm almost immediately at a stop.
I've cleaned the throttle body and IACV, maybe it needs a better cleaning.
Anyone with ideas as why it would be slow returning to idle.
No hoses off, new PCV valve, new air filter, new fuel filter, and no idea
how to make it return to idle faster. How do I reset the idle ?
On my Fords you disconnect the IACV and set the idle speed then
reconnect the IACV....is Subaru the same ( I bet not with my luck).
It runs great no problems except the high idle.
2000 Impreza Outback Sport w/135K
2.2L E4AT
Thanks
Richard
Richard1296 is offline   Reply With Quote
Questions on Rough idle on 06 STI with the following mods... origonalp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-07-2006 12:34 PM
('93-'01) Safety Question on 98 OBS Jejunum Impreza Forum 4 09-09-2003 01:29 PM
front diffential question on 2002 OBS rogeryung Service & Maintenance 1 09-05-2003 09:52 AM
Idle question on my MY90 legacy sedan L BajaNut Legacy Forum 2 06-18-2003 07:17 PM
questions on brake upgrade for OBS jobs Brakes, Steering & Suspension 4 05-21-2002 01:40 PM
