Old 12-11-2006, 08:43 PM   #1
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Default Hydramist installed pics and dynoplot
Here is my Hydramist setup along with results.
Pump shoving meth and water to my junkie engine
The flow sensor
The High Speed Valve (HSV) controlling flow, controlled by the Hydra
A side view of the jets on my TXS FMIC
An upside down view
The nice resevoir installed by Subaru Technica International (factory TMIC sprayer)
And the Aquamist DD3 gage (With fuel pressure gage keeping company)
And the dynoplot
And soon to come JDM reservoir to feed the USDM reservoir for years and years of meth/water supply.
I am going tomorrow to the track to test it or breakit.
El Gato is offline   Reply With Quote
Old 12-11-2006, 09:39 PM   #2
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Awesome!!!!
djerickd is offline   Reply With Quote
Old 12-12-2006, 02:09 AM   #3
fastwrx25
Member#: 126441
03 bugeye
hahaah sweet setup
fastwrx25 is offline   Reply With Quote
Old 12-12-2006, 09:37 AM   #4
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Very impressive and I'm glad you are happy. Keep in mind it is optimal to stagger the jets in the charge pipe as the spray pattern "fans" out. By having them side to side you will condense the mist into droplets reducing the atomization of water and air. So optimally you should have one jet about 2 inches before or after the other jet.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 12-12-2006, 11:36 AM   #5
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Element,
how would u reccomend installing the twin jets with a TMIC?
Why 2 jets again?
Old 12-12-2006, 01:50 PM   #6
El Gato
Member#: 110648
93oct 479whp 456tq
Thanks,
Phil
Glad to know. I will relocate these ASAP.
Old 12-12-2006, 02:30 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Originally Posted by djerickd View Post
Element,
Why 2 jets again?
Just make sure one is in front of the other based on the direction of air flow. Looking at our installation instructions will show you the proper orientation with a TMIC. If you look how El Gato has his installed they are side by side in the direction of air flow and not one in front of the other. Trust me, doing it that way isn't the end of the world but the more evenly the water atomizes with the air the more evenly it will get distributed throughout the intake manifold.
Thanks,
Phil
Old 12-12-2006, 09:52 PM   #8
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
Lets see the whole car
THE-95-STi is offline   Reply With Quote
Old 12-13-2006, 12:05 AM   #9
El Gato
Member#: 110648
93oct 479whp 456tq
Its all factory looking crystal grey 2005 Sti, except for the SPT hood lip to protect against debris and the TXS FMIC and the Greedy SP2.
Plus its too dirty now to take pics.
Old 12-13-2006, 05:44 PM   #10
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Your installation is very efficient, no nonsense type. It will work forever.
Did you not use the special clips that came with the HSV?
How did you fix ther DDS3 gauge on the dash top?
Aquamist is offline   Reply With Quote
Old 12-13-2006, 05:46 PM   #11
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
special HSV clips?
Old 12-13-2006, 07:21 PM   #12
El Gato
Member#: 110648
93oct 479whp 456tq
Well, at the time I did the installation, I could not find a Greddy gage mount so I put some doble tape underneath and stuck it to the dash on the meanwhile. The thing is it looked good there as it is so it will stay as it is.
Special clips? So that is what those little thingies were for? Just kidding but the HSV does not really go anywhere there, I do not remember if I got them.
Do you think I should use them? Or could I secure it with another tie wrap? What could happen?
Old 12-13-2006, 08:13 PM   #13
Aquamist
NASIOC Manufacturer
Member#: 110029
NO, it is not necessary unless you drive like a rally driver everyday.
If the HSV vibrates, the hose on each end will be rubbing against the internal sealing disc and may cause small leakage. The surface of the nylon hose will get scratched eventually.
Old 12-14-2006, 01:11 PM   #14
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I swear... one of these days I am actually going to install mine. And it's going to be the sexiest install job you've ever seen.
jblaine is offline   Reply With Quote
Old 12-17-2006, 12:47 PM   #15
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
i have a gage installed on the dash of my mazda with double tape. every time it gets hot out the glue on the tape starts to melt and the gage moves around.
i'm actually looking at the glove box mount from autometer(for my subaru).
kharris4 is offline   Reply With Quote
Old 12-17-2006, 01:38 PM   #16
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
yeah you don't wanna run that for too long, I had some stuck down in the little area in front of the shifter
then I crashed the car... they went flying and put a nice dent in my greddy 52mm's (the car was a little worse off )
Old 12-21-2006, 12:38 AM   #17
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
looks nice.... i take it you don't carry a spare tire?
jigga is offline   Reply With Quote
Old 12-22-2006, 07:19 PM   #18
El Gato
Member#: 110648
93oct 479whp 456tq
No, but I added roadside assistance in my insurance policy .
Old 12-24-2006, 11:46 AM   #19
El Gato
Member#: 110648
93oct 479whp 456tq
Finished replacing my clutch with a 4 puck sprung hub and the old ACT plate plus repaired 2nd gear and the synchro hub. Taking off on 1st gear gets a little getting used too but managable. During hard shifting though, the clutch really engages, I do not hink I need to flat foot shift any more with this disk.
This STi tranny is amazing on the inside. All the grears are brutely constructed, internal oil pump, magnetic center diff. etc.
It finally works - Hydramist install pics jblaine Water/Methanol Injection, Nitrous & Intercooler Cooling 69 08-05-2010 03:38 AM
KW V1 Install Pics and Questions Xawn Brakes, Steering & Suspension 6 04-20-2010 02:32 AM
Hydramist pics and results El Gato Member's Car Gallery 15 12-12-2006 12:15 AM
Hydramist installed - up to 27 psi on 93 oct right after install El Gato Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 12-07-2006 10:56 PM
Hella install pic and couple of my baby willguidry New England Impreza Club Forum -- NESIC 17 02-17-2003 08:35 PM
