Old 12-11-2006, 10:44 PM   #1
sc00ter
Member#: 117767
2015 WRX
CWP
Default Water/meth injection on an N/A
I read through the FAQ but didn't read if water/methonal injection could be done on a non-turbo impreza?
If possible, would it be reasonable to assume a similar HP increase stated in the FAQ (i.e. 20-30whp)?
- Because if this is possible then this could be the best bang for the buck I have seen. Seems to good to be true.
sc00ter is offline   Reply With Quote
Old 12-11-2006, 11:00 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
The results of injection depends a lot on the car, the fuel, and the injection being used. The nice thing about turbo'd cars is that the boost can be raised. This along with the fact that turbo subarus naturally run rich makes it so injection on turbo subarus shows great results. I don't know how great the results would be if all you could do is lean out an a/f ratio that starts at 12 to 1, and advance timing. Ie-Some engines probably need more then a tune and a little water to get good results, and they might even end up losing power with injection.
peace
Old 12-11-2006, 11:06 PM   #3
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Like he said, N/A cars run at a high AFR anyway, kind of negating the increase in AFR seen on turbo cars when using this injection. Also the water/methanol injection cools heated turbo air also not a problem in N/A cars. My best guess would be an increase in octane rating if using 93 octane and 100% methanol and the increase would not be as significant as in forced induction.
El Gato is offline   Reply With Quote
Old 12-11-2006, 11:55 PM   #4
sc00ter
Member#: 117767
2015 WRX
CWP
Awesome, thanks for the input guys. Gonna go with other mods.
Old 12-12-2006, 12:17 AM   #5
El Gato
Member#: 110648
93oct 479whp 456tq
Get a turbo upgrade and you will be able to use the water/meth injection ???
Old 12-12-2006, 01:39 AM   #6
poormansporsche
Member#: 79798
You could probably, my guess anyawy, use it and gain about 15 ish HP. I think there it could be used however in as a supporting mod for other mods. Like you could probably run 12.5:1 or 13:1 compression pistons in the RS block and not detonate and on pump gas. It would require a tune however. All in all would be pretty costly.
cheers
garrett
poormansporsche is offline   Reply With Quote
Old 12-12-2006, 08:51 AM   #7
CMtech1
Member#: 122524
You will be very lucky if you gain 1 HP on a n/a car. We do offer N/A Controller kits, but they are typically designed for vehicles that want to eliminate race gas or want to advance timing past what the stock fuel system can handle. Well built n/a race cars and cars built with very high compression make good canditates. I would certainly look into something different in your situation. Its not likely do do much.
CMtech1 is offline   Reply With Quote
Water/meth injection water pump question atomic4877 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 09-24-2009 05:29 PM
Water Meth Injection pre-sale gb on new Gauge System Coolingmist Vendor 'Group Buy' Classifieds 1 02-27-2009 09:10 PM
Question on water/meth injection.. Fab's STI Newbies & FAQs 11 02-11-2007 10:02 PM
water/meth injection an alternative to oil cooler/bigger radiator? IllNastyImpreza Water/Methanol Injection, Nitrous & Intercooler Cooling 25 11-27-2006 02:21 AM
There is an n.a. viper with water/meth injection on ebay sumfoo1 Water/Methanol Injection, Nitrous & Intercooler Cooling 1 07-26-2006 03:05 PM
