Old 12-12-2006, 07:43 PM   #1
bopper
Member#: 134739
Legacy RWD Conversion
what needs tobe dont to convert a 89' legacy RS to RWD. and costs
bopper is offline   Reply With Quote
Old 12-12-2006, 07:57 PM   #2
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
$14,753.82
KD7000 is offline   Reply With Quote
Old 12-12-2006, 08:00 PM   #3
legacy99black
Member#: 52238
2001 Legacy GT LTD
Hummer Black
Originally Posted by KD7000 View Post
$14,753.82
hahaha, you're a jerk
legacy99black is offline   Reply With Quote
Old 12-12-2006, 08:15 PM   #4
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Wait, there was an error in my original estimate.
It will actually only cost $1,347.39
Old 12-12-2006, 08:31 PM   #5
legacy99black
Member#: 52238
2001 Legacy GT LTD
Hummer Black
Seriously though, there is someone over on sl-i.net that has done it to their old legacy.
actually on here i think mranlet has it done.
Old 12-12-2006, 08:33 PM   #6
rougeben83
Member#: 115154
2005 Outback XT
White on grey
there was a post about this not too long ago as well. do a search.
rougeben83 is offline   Reply With Quote
Old 12-12-2006, 09:05 PM   #7
bobbyjimmy
Member#: 114012
2002 Outback
Dunno what it does exactly, but it looks cool!!
http://www.rs25.com/classifieds/show...1&cat=7&page=1
bobbyjimmy is offline   Reply With Quote
Old 12-13-2006, 12:22 AM   #8
sha_zapple
Member#: 41012
1998 Legacy L
wouldnt work
A) made for the STi transmission
2) Your transmission is not built to handle all the power to the rear
III) probably an open rear differential in your car
sha_zapple is offline   Reply With Quote
Old 12-13-2006, 12:44 AM   #9
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
These two people you mentioned are the same person
Wiscon_Mark is offline   Reply With Quote
Old 12-13-2006, 12:54 AM   #10
Coaster
Member#: 88159
2002 WRX Wagon
Default 2wd
Rocket Rally has a solution.
Coaster is offline   Reply With Quote
Old 12-13-2006, 01:20 AM   #11
legacy99black
Member#: 52238
2001 Legacy GT LTD
Hummer Black
no, someone with early 90's (BC?) legacy, a black one...
Old 12-13-2006, 03:01 AM   #12
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Ah yes. The doom wagon. That car wasn't stock though. He was motor swapped with a turbo motor. And I don't know that the rear diff was a plain jane subie diff.
Mr. Anlet runs an S14 rear differential. Running in just rwd could work, I would probably get a tall gear ratio rear differential, because that would mean both gears are relatively large. Although larger doesn't always mean stronger.
Are the front diffs that much stronger than the rear? If they are pretty much the same, then you should have no problem running it in RWD since they did sell FWD imprezas and legacys in 94 and 95.
Plays_With_toys is offline   Reply With Quote
Old 12-13-2006, 11:50 PM   #13
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
With some labor time and someone on the TIG welder, you can fuse a center diff to work in RWD only for free (plus a case of beer for the welder).
But, to run reliably in RWD, you'll need a dedicated RWD transmission or straight cut stepper gears for the AWD transmission. To run reliably and still do the things you converted to RWD mode for (burnouts, drifting, etc), you'll also need something bigger than the stock R160 (STi R180, or R200 like I'm using) and a host of aftermarket bushings for the rear suspension.
There have been quite a few RWD Subarus owned by forum members, but just about all of them wind up breaking stuff sooner or later.
My final setup is almost complete and will consist of:
- Z33 G35 6-speed transmission with custom "MRanlet" mounts and clutch combination
- Hitachi R200 in S13 housing with S14 rear cover
- OEM Nissan Axles (for easy and inexpensive replacement)
- Custom "MRanlet" R200 uprights
- Custom "MRanlet" tubular rear subframe
- 1-piece aluminum driveshaft
I may put a sort of 'conversion package' together for those who seek Subaru RWD-ness, and hope to have it be reasonably priced ($1k-$2k).
I hope this helps, I'll be happy to do my best to field any RWD questions.
mranlet is offline   Reply With Quote
Old 12-14-2006, 07:58 AM   #14
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
^^^That’s awesome….
IIRC, PPG makes performance center-diff stepper/output gears…
xcntrk75 is offline   Reply With Quote
Old 07-03-2008, 05:19 PM   #15
Kansei
Member#: 173080
1997 Legacy 2.0 GT
Forest Green Metallic
so MRanlet... does that mean you would get all the parts for the conversion and sell them to anyone that is wanting to make their leg. RWD? cause I am wondering about that right there... but dont go doing it right away. I dont have that kinda money yet. just wondering if thats what you mean.
Kansei is offline   Reply With Quote
Old 07-07-2008, 07:57 AM   #16
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
probably very similar to sl-i.net link but try http://clubsub.org.nz/forums/index.php?topic=22329.0
we've been doing this for a while now (not me specifically - kiwi's)
JoKerNZ is offline   Reply With Quote
rwd conversion AntonioS Transmission (AT/MT) & Driveline 16 09-27-2005 06:04 PM
RWD conversion - will it help? dyswtric27 Transmission (AT/MT) & Driveline 0 06-30-2003 01:56 PM
Auto RWD Conversion ImprezedRS Transmission (AT/MT) & Driveline 4 03-26-2003 07:31 PM
Billet RWD Conversion centre diff chiraoka Transmission (AT/MT) & Driveline 14 01-08-2002 08:04 PM
Anyone done RWD Conversion? cdigerlando Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-25-2001 08:55 PM
