Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Vancouver Impreza Club
Old 12-12-2006, 07:59 PM   #1
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
Default Misfire at start-up after 1 week storage....
So after the snow storm I washed my car and didn't drive it at all for a week (i waxed it meanwhile.. lol)
Then yesterday when I fired it up, the engine made some loud "ta-ta-ta" noise for like 5 seconds.. then it gradually died down.. CEL came on.. car drove fine..
Had my mechanic pull the code today and it's a misfire at #4.. he said it's possible when the car is really cold and water got into the spark plug or sth.. i remember water dripping into the engine bay when i opened the hood after the car wash.. anyways, now the CEL is cleared and i'm back to normal again.. lol.
any comments?..
btw which cylinder is #4? is it the driver side one close to the firewall?
KIMUTAKU is offline   Reply With Quote
Old 12-12-2006, 08:49 PM   #2
ghostfoot7
Member#: 61040
dead sexy blue!
well, you know you've got to cover the scoop when washing your car right? Otherwise water can get onto the engine!
Seriously though... I'm not expert, but how would water get into the spark plug area? Bizarre..
ghostfoot7 is offline   Reply With Quote
Old 12-12-2006, 10:28 PM   #3
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
There was this one story..some woman in Kelowna washed her car before winter and left it. She jsut washed it and put it in the garage i guess. Anyway, she gets into the car and the calipers were frozen to the rotors..totally different story kind of but you should always take your car for a drive after you wash it.
Ryan
007WRX is offline   Reply With Quote
Old 12-12-2006, 10:44 PM   #4
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
as far as i know, it's quite common for EJ25 (GC / GD NA 2.5) to have a leaky spark plug seals...did you mechanic pull out the coil to check? it will be a good idea if it has been more than 1/2 year since u last pulled it...
in general the coil / spark plug wire seal up with the valve cover pretty good, unless it's not installed properly?
5 Zigen is offline   Reply With Quote
Old 12-13-2006, 02:47 AM   #5
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
i had new coils and plugs installed last september when i upgraded the turbo..
so.. if they were the cause then i would be rather disappointed..
anyhow.. i'll get them checked later when i have time.. lol
Old 12-13-2006, 03:46 AM   #6
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
better to be safe rather than sorry
if u are lazy, at least check #4
Old 12-13-2006, 04:06 AM   #7
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
so is nubmer 4 the one right in front of the driver??
thanks for the help guys!
Old 12-13-2006, 11:32 PM   #8
patr
Member#: 97
the tabs on the coil packs on the coil on plug cars are notorious for bad connections. Also, the coil to spark plug can also get water in there. Especially if you spray the engine. also moisture can freeze in there (i.e. wash and no drive). I wouldn't be concerned about it unless it really is running on 3. If it is, just check the connector. Driving after wash dries out most of it.
-Pat
patr is offline   Reply With Quote
Old 12-14-2006, 02:36 AM   #9
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
awesome.. thanks pat.. =)
yea i don't it's running on 3 either.. at least it doesn't feel like it is.. lol
First start up after winter storage question Rallly2000 Newbies & FAQs 11 02-01-2010 06:16 PM
Hybrid misfire on start up gnarlyWRX Built Motor Discussion 6 05-03-2007 10:15 AM
02 RS misfire at start up DFL2.5RS Normally Aspirated Powertrain 5 11-23-2004 09:13 PM
My car took a long time on my 2nd start-up after installing HKS BOV samwY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-05-2004 11:41 AM
