Old 12-12-2006, 08:12 PM   #1
Hawke
Member#: 25777
Default What's Your Throttle Tip-In?
05 WRX basically a Stg2
Stock:
Code:
0.0	2.0	3.9	5.9	7.8	9.8	11.7	13.7	15.6	17.6	19.5	21.5	23.4	25.4	27.3	29.3	31.2	33.2
17	20	24	30	36	44	52	60	68	76	84	92	99	109	119	129	139	151
Protuned:
Code:
0	0	0	0	6	14	22	30	38	46	54	62	69	79	89	99	109	121
Why would my tuner have removed the initial throttle tip-in like that? My AFR is shooting up into the high 16's during tip-in.
What do others run?
Hawke is offline   Reply With Quote
Old 12-12-2006, 08:26 PM   #2
hondaeater69
Member#: 60324
Stock:
to conserve gas? ask him maybe....
Old 12-12-2006, 09:14 PM   #3
Gethin
Member#: 2998
Maybe to remove a rich bog while going hard WOT.....are you using the stock intake? Usually needed if you have a big FMIC too. I have also played around with the throttle delta maps to achieve the same thing.
Gethin is offline   Reply With Quote
Old 12-12-2006, 10:45 PM   #4
Hawke
Member#: 25777
Stock TMIC, stock intake.
Here is my current revision that I'm much happier with. Tip in feels better, AFR ratios look better and knock correction is better too.
Code:
11	15	19	24	29	36	42	49	55	61	68	74	80	88	95	103	111	120
Anyone else care to share tables?
Old 12-12-2006, 11:06 PM   #5
wall of tvs
Member#: 29716
2006 wrx wagon
booze powered e85 monster
Who tuned your car?!?
wall of tvs is offline   Reply With Quote
Old 12-13-2006, 10:17 AM   #6
Hawke
Member#: 25777
I'm not looking to make this about the tuner. Just trying to start a discussion about throttle tip tuning techniques. I can say it wasn't you though! I'm pretty happy with what I've got, but I'm always looking for improvements. I've seen some tables that start with zero, some like the stock start high. I'm somewhere in between. What are the benefits to a lower tip in value (quicker spool, better fuel economy, etc) and what are the benefits of a higher tip-in value (reduced chance of knock, etc)?
Old 12-13-2006, 10:21 AM   #7
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
Im thinking they were possibly trying for quicker spool, possibly? Along the lines of not bogging-rich like stated above. Thats the only reason I could think to run you as lean as 16.x:1.
SBW is offline   Reply With Quote
Old 12-13-2006, 10:39 AM   #8
TJRCS
Member#: 59199
2008 STI
how can you changed "Protuned" map??
TJRCS is offline   Reply With Quote
Old 12-13-2006, 11:06 AM   #9
Hawke
Member#: 25777
See this thread:
http://forums.nasioc.com/forums/show....php?t=1152941
stumble/bog/hesitation on throttle tip-in, sometimes - What could it be? winston856 Normally Aspirated Powertrain 71 06-29-2008 01:35 PM
Timing pulled at low loads & throttle tip in ronzogonzo Open Source Reflashes 9 06-10-2008 05:54 PM
Hesitation on throttle tip-in GTScoob Service & Maintenance 33 06-07-2008 08:35 PM
Throttle tip-in on my 2003 Legacy bobko Normally Aspirated Powertrain 4 09-17-2004 08:21 AM
Popping during throttle tip-in Kitt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-01-2004 06:59 PM
