South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-13-2006, 12:10 AM   #1
Under_pressure
Member#: 132791
02 WRX wgn
Default 02-03 wrx stock ecu needed
I need to do some trouble shooting on my car and want to try a different ECU. If anyone has one I could borrow to check and see if this is my problem PM or post up. I live over in Surprise. If anyone is wondering my car is running lean I have changed and checked everything I can think of, Plugs, FPR, front o2, cleaned MAF, pressure checked the intake. Nothing is helping the problem. Thanks
Bryan
Under_pressure is offline   Reply With Quote
Old 12-13-2006, 09:35 AM   #2
Dangerviking
Member#: 124312
1998 2.5 RS
I've got an '03 ECU that I'm going to be using for my motor swap that's just sitting in a box right now, if you just need to borrow it to test. Let me know
Dangerviking is offline   Reply With Quote
Old 12-13-2006, 06:57 PM   #3
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Yeah man i know he will that will help us work out this problem
Poweredbysnail is offline   Reply With Quote
Old 12-13-2006, 10:57 PM   #4
Under_pressure
Member#: 132791
02 WRX wgn
http://www.scoobypedia.co.uk/index.p...patibilityList
Check this link. These numbers being different form year to year does this mean I can only use 02 ecu and a 03 will not work?
Old 12-14-2006, 11:21 AM   #5
borkjam
Member#: 56774
2002 WRX Sedan
I'm using an '03 ECU in my '02. Research I did a couple of years ago when I bought a spare (for Ecutek flashing) indicated the following are OK for use in an '02:
AF411, 420, 422, 423 & 424
AJ030, 031, 040 & 041
I ran the '03 AJ030 in my '02 (factory part was AF422) for about a month with no problems before getting it flashed.
borkjam is offline   Reply With Quote
Old 12-14-2006, 06:54 PM   #6
Under_pressure
Member#: 132791
02 WRX wgn
cool thanks for the info
FS: 02-03 Wrx stock ecu. StandardSti Engine/Power/Exhaust 7 08-03-2010 10:23 AM
02-03 WRX PSI3 ECU Monitor(PIC) BDR Engine/Power/Exhaust 17 05-07-2007 10:36 PM
WTB: 02-03 WRX MT ecu ICECREAM ///MAN Private 'Wanted' Classifieds 1 03-28-2007 08:30 PM
New service bulletin for 02-03 WRX ABS ECU file_id Southern California Impreza Club Forum -- SCIC 24 08-26-2005 03:01 AM
