South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-13-2006, 03:12 AM   #1
boostedsti06
Member#: 128677
2006 Subaru WRX STI
obsidian black pearl
Question where to get 100+ octane
Anyone know where i can find 100+ Octane gas ??? i am located in Mesa
boostedsti06 is offline   Reply With Quote
Old 12-13-2006, 04:26 AM   #2
pajak
Member#: 95992
08 E92 335i
Grey
ray and 43rd? its ray and one of the streets off the 10 its where i go its called like quality fuels or something like that its 5.99 a gallon and only available on like 2 pumps with the blue handle way west of the station.
pajak is offline   Reply With Quote
Old 12-13-2006, 09:28 AM   #3
LegacyGt05
Member#: 80074
2007 BMW 335i
Sapphire Black Metallic
If you are up north, there is one on Cave Creek and Union Hills...
LegacyGt05 is offline   Reply With Quote
Old 12-13-2006, 12:40 PM   #4
Demok
Member#: 116611
2007 Cobalt SS/SC
"NOSPOOL"Stage 3.5 254whp
56st & Bell Rd. 100 or maybe it's 101 octane.
Demok is offline   Reply With Quote
Old 12-13-2006, 02:25 PM   #5
shemoves
Member#: 80663
2005 STi
What I know for sure....Cave Creek and Union is 101, 56th/Bell is 100, Speedworld is 109 (only available weekends, but works out to be the least expensive).
If you are stock, only put in four gallons (+/- 0.5 gals) of 100 in (reset ECU afterword). Your car will love it, but much more than that and you may actually see a slight decrease in butt-dyno performance.
shemoves is offline   Reply With Quote
Old 12-13-2006, 03:13 PM   #6
JasonF
Member#: 44725
2004 WRX wrb
A buddy of mine always goes to one of the airfields in Tempe or Mesa to get gas for his ATV... I think it's Falcon Field. You should just be able to pull right up and pump.
JasonF is offline   Reply With Quote
Old 12-13-2006, 03:38 PM   #7
pajak
Member#: 95992
08 E92 335i
Grey
navgas (airplane fuel) will clog your cat so make sure not to put it in your car unless your cattless.
Old 12-13-2006, 04:50 PM   #8
superblkwrx
Member#: 129395
2006 OBPWRX VF39 E85
333WHP 385WTQ 21PSI SD
how much is this navgas and what octane rating is it.
superblkwrx is offline   Reply With Quote
Old 12-13-2006, 08:46 PM   #9
BrianH82
Member#: 118695
isn't navgas leaded?
I know an airport that sells 120 octane leaded gas.
theres one on chandler west of I-10 where I always go. It's 100 octane for $5.99 gallon. I'm planing on getting some tomm for my friday touge run.
BrianH82 is offline   Reply With Quote
Old 12-14-2006, 12:29 AM   #10
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
what station is that?
v8eaterWRX is offline   Reply With Quote
Old 12-14-2006, 03:47 AM   #11
YOitsDUCE
Member#: 116120
2006 Subaru WRX STI
Cave creek and the 101.. exit make a right its at a gas station =] they sell 101 or 103 i cant remeber.. but theres a sign that says race gas here haha
YOitsDUCE is offline   Reply With Quote
Old 12-14-2006, 04:32 AM   #12
pajak
Member#: 95992
08 E92 335i
Grey
its the one on chandler or ray off the 10 right next to a checker i go the back way frommy friends house on ray so thats why i think it is ray. quality fuels or something like that
Old 12-14-2006, 05:59 AM   #13
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
its on chandler and i think 42nd street. next to the checkers and sonic
taerron is offline   Reply With Quote
Old 12-15-2006, 04:01 AM   #14
GoldBBS
Member#: 120845
Come on guys, Chandler blvd and 44th street. Head west on Chandler blvd and turn right on 44th street. It is the one pump that is located furthest to the southwest of the station. Blue pump is VP101 @ 5.99.
There you go.
GoldBBS is offline   Reply With Quote
Old 12-15-2006, 06:00 AM   #15
SubyRSdriver
Visiting NASIOC Timeout
Member#: 94839
2005 2.5 RS
yes (avgas) aviation gas is leaded.. it is 100 octane and is prob not the greatest thing to run in your car since it is different from stuff at gas stations. There are two basic types which are dyed two different colors one is green one is blue.. for identification and pre flight purposes. 100/130 avgas is used primarily for older planes with older style engines that require higher octane.. the stuff is very, very saturated with lead. and highly toxic as it contains TEL which is uber damaging to the environment. The newer type is 100LL which stands for low lead.. it is still far more toxic than gas for cars and still does contain lead and other chemicals not found in gas for cars. hope that helps a bit.
EDIT: just looked at my flight charts and figured I'd throw this up if anyone is interested.
100/130 avgas the highest octane grade.. it contains 4 grams of lead per US gallon. green dye
100LL low lead 100 octane contains a special lead based anti knock agent, but is less than the above ..... blue
there is also an 80/87 avgas which contains .05 grams of lead per gallon.. it is dyed red.
just be aware these fuel are specifically designed to run in aircraft not cars.. I know a lot of people use them.. but the purpose is to make a fuel far less volatile, evaporate MUCH slower ( for high altitude purposes) and burn at a totally different. ect... many have dual ratings like 100/130 one is under lean conditions.. and the other is under rich flight conditions. for high revving supercharged, turbo engines.. upto 30,000 RPMS
you can not compare the octane rating to a motor vehicle. 100LL avgas is not the same as 100 motor vehicle gas as the testing method is different based on different conditions of operation and the formula ((R+M)/2)
SubyRSdriver is offline   Reply With Quote
Old 12-15-2006, 01:20 PM   #16
BrianH82
Member#: 118695
There you go.
yes yes, thats where it is at. I just filled my empty tank with 4 gallons of that, the car PULLS!!
Old 12-15-2006, 01:30 PM   #17
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
I just buy Torco 5 gallons at a time and put a new set of NGK Iridiums in every year.
5 gallons is 640 ounces. I run a strong 91 octane map for daily driving and use a full 32 oz in each tank on track days. 32 oz of torco in 15.5 gallons = 98 octane. When bought in 5 gallon cans, it works out to about 28 cents an ounce. $8.69 per tank in addition to the actual price of fuel. That would only buy you a gallon and a half of 100 octane, if that. A 5 gallon drum is good for 20 tanks of gas, or for me 10 track weekends.
75K miles on the engine and sensors, only thing I have had to change are plugs. Torco is my best friend for racing on a budget. I can add a poound of boost on my street map and have to do no other tuning. Once done, I dial back the boost and run 91 octane fuel.
Valhakar is offline   Reply With Quote
Old 12-16-2006, 12:28 PM   #18
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
check out the FAQ sticky yo
MrMcCrackin is offline   Reply With Quote
Old 07-21-2007, 03:41 PM   #19
Sawyerscooby
Member#: 149122
2006 WRX Stage II
Black w/ scratches
falcon field has a pump its right next to the control tower, its 6.59 / gallon and its 100 oct leaded, would it hurt my sensors and cat if i mixed the 100 oct leaded with regular 91 oct unleaded?
Sawyerscooby is offline   Reply With Quote
Old 07-21-2007, 08:48 PM   #20
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
negative ghost rider
havgas has just a little lead in it - plus you mixing it with yet more unleaded to reduce the concentration
hopefully you dont have a cat - otherwise you will be gold!
Old 07-22-2007, 03:41 PM   #21
07BlUEbaru
Member#: 154054
2010 WRX Sedan
chandler 44th at valero blue pump westside back pump 5.99 a gallon
101 and chapparal 1/4 mile west on chapparal at the chevron station 109 110 etc
07BlUEbaru is offline   Reply With Quote
Old 07-22-2007, 04:21 PM   #22
AZMike
Member#: 136470
2003 JDM STi swap
World Rally Blue
You can get 110 octane at the Pavilions 76 station right off the 101.. I think it is $7 a gallon.
AZMike is offline   Reply With Quote
Old 07-22-2007, 04:42 PM   #23
P_town_WRX
Member#: 154145
2007 WRX
red garnet pearl
i heard that you can get it at 67th and glendale and for sure at 35th and southern at the mexican race track that should be a lil better for west side guys. im not sure what the gas station is called but it shouldnt be to hard.
P_town_WRX is offline   Reply With Quote
Old 07-22-2007, 07:56 PM   #24
07BlUEbaru
Member#: 154054
2010 WRX Sedan
forget the chapparal and 101 i meant the chevron at the pavillions. which is indian bend sorry
Old 07-23-2007, 01:51 PM   #25
SpankySuby
Member#: 122305
2002 wrx half breed
Its actually on chandler blvd. and i also think its 43rd or 40th something like that but i think its called in the zone fuel next to an autozone but yeah its 6 bucks a gallon they clame 101 but one of my buddies here at ntcnaz some you may know Braddy Dorhman has tested it 3 times over the course of a couple months and has gotten only 98 oct. so who knows if its all good there but i aint goin there anymore the luvs station on wild horse passe east of the 10 has 110 and 100 the 110 is 25cents cheaper and the 100 is 12cents cheaper than that.
SpankySuby is offline   Reply With Quote
where to get 100 octane unleaded portland? warpspeedwrx North West Impreza Club Forum -- NWIC 13 02-26-2008 01:47 AM
where to get 100 octane in OC? ewright Southern California Impreza Club Forum -- SCIC 9 08-01-2005 03:18 PM
WHere to get High Octane gas (93+) or Tuolene in East Bay WRXinEffect Bay Area Impreza Club Forum -- BAIC 19 09-20-2004 02:55 AM
Where to buy 100 octane in Chicago? Kegger Mid West Subaru Owners Club Forum -- MWSOC 9 03-24-2004 09:06 AM
