Old 11-19-2001, 02:35 AM   #1
blue
Member#: 2089
2001 Impreza 2.5RS
Blue Ridge Pearl
Question Spark plugs
Do anybody know how to tighten the spark plugs on a 2001 2.5rs?
Do i need to it torque the plugs or tighten it with wrenches?
thanks
blue is offline   Reply With Quote
Old 11-19-2001, 02:45 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Basically turn them until they get tight and don;t want ot turn anymore. Only use a 3/8 drive ratchet with a regular length handle and don;t try to over tighten them. Just go till they stop. It doesn;t take a lot. It's only about 17 lb/ft or so
Eric
Eric SS is offline   Reply With Quote
Old 11-19-2001, 02:49 AM   #3
blue
Member#: 2089
2001 Impreza 2.5RS
Blue Ridge Pearl
thanks i never touch the plugs so i didn't know
Old 11-19-2001, 10:38 AM   #4
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Aluminum heads; ALWAYS use a torque wrench. 12-18 ft/lbs depending of how many times they have been removed for cleaning.
Albert is offline   Reply With Quote
Old 11-19-2001, 10:52 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
huh alumnium heads?? they have steel inserts for the plug boss....i have never torque a spark plug but don't go cranking on it....turn it till it's snug then about a half turn after that.
jeremy
Old 11-19-2001, 06:07 PM   #6
Silverscooby27
Member#: 9124
2014 335i xDrive
I tighten them to 18 ft/lb with a torque wrench, but don't forget to hand-tighten first so you don't cross-thread! I found on my MY99 that using a 6 inch extension + 3 inch extension + the spark plug socket worked to hand-tighten.
Silverscooby27 is offline   Reply With Quote
Old 11-19-2001, 09:48 PM   #7
Imprezafan1
Member#: 4039
2015 WRX
Default what does better sparks do?
I was just wondering what does sparks do for a car? I heard i should get them because my exhaust backfires and they will help? What kind is the best? THanks
Imprezafan1 is offline   Reply With Quote
Old 11-19-2001, 10:11 PM   #8
Silverscooby27
Member#: 9124
2014 335i xDrive
And while we're on the subject, what about spark plug wires, like the Magnecors. What would those do?
BTW, Imprezafan, I installed NGK V-powers to replace the wonderful now-"Cajun-style" Champions that came in the car. I think they cost me a whopping $1.99 a piece from my local Pep Boys.
Old 11-19-2001, 10:15 PM   #9
Imprezafan1
Member#: 4039
2015 WRX
Default do they do anything in terms of performance?
what exactly does sparks do?
Old 11-20-2001, 12:09 AM   #10
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Default Re: do they do anything in terms of performance?
"sparks"-->sparkplugs ??
please rephrase what you are asking
Old 11-20-2001, 12:13 AM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
The wires on our cars are just fine. Tests have shown no performance gains from wires on our cars.
Eric
Old 11-20-2001, 05:40 PM   #12
Silverscooby27
Member#: 9124
2014 335i xDrive
Thanks for saving me some $$, eric
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 705 05-17-2016 10:30 PM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 03:05 AM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 04:17 AM
