#1 |
Member#: 100590
SWIC
Vehicle:2002 bugeye red rock red |
well i bought some cobalt series autometer gauges, boost and oil temp. i have searched for sometime now on a good walkthrough on how to do them and was unable to find one.. some help would be greatly appreciated. i heard they are an easy install, i am just sligtly eletrically retarded. thanks
#2 |
Member#: 89071
SWIC
Vehicle:2000 Blue 2.5 RS 2004 Java WRX |
i had a question bout this too, i got an autometer boost guage. not sure where to insert the hoses to read boost pressure.
#3 |
Member#: 129395
SWIC
Vehicle:2006 WRX VF39 BLKOUTT |
Its fairly simple. You take a spilter and put it in between the vacume/boost line coming off the wastegate of the turbo. Run that split off line to the control module if electrical guage or directly to the guage if its a mechanical guage. Run a power and a ground wire to the guage and you are good to go.
#4 |
Member#: 108547
SWIC
Vehicle:2012 Tundra Crewmax 4x4 5.7l TRD AFE Stage II |
#5 |
Member#: 108547
SWIC
Oh, and for your oil temp, save yourself some time and headaches and buy the Process West sending block. Its only like $40 and works wonders
#6 | |
Member#: 100590
SWIC
oh, my gauges are all in and have power to them, my boost is mechanical so thats up and working. my temp gauge came with what seems to be a way to use the drain plug to read temp. will this work or should i just get the sending block? thanks for the help, much appreciated ![]() |
#7 |
Member#: 118474
SWIC
chris, if u still need some help, pm me you number and u can come over so we can knock em out
#8 |
Member#: 67335
RMIC
As far as the boost gauge do what v8eaterwrx shows tap into the BOV.For the oil temp remove oil galley plug under intercooler on the left of it and replace with subaru part # 11024-AA210 this plug has a threaded hole for the oil temp sending unit.DO NOT TAP INTO THE FUEL PRESSURE REGULATOR HOSE for the boost gauge.
#9 | |
Member#: 97642
SWIC
Vehicle:2002 Wrx Sedan MBP |
This is wrong information. You tap it where it is shown on the pic above. There is a T on the line coming out of the bypass valve. I will help you install them if you want. Give me a pm. |
#10 |
Member#: 97642
SWIC
In that pic that says (Tap right here?) That line you see coming off the T is the line for a boost gauge. If your car previously had a guage then you can just reuse that line.
#11 |
Member#: 129395
SWIC
Sorry i said waste gate, ment BOV.
#12 |
Member#: 132244
NWIC
Vehicle:2006 OBP WRX 2006 BMW 325i |
home depot brass t-fitting FTW
#13 | |
Member#: 129395
SWIC
How about for oil presure? where would I tap that for a suby(so much different than a dsm)
#14 |
Member#: 74753
SWIC
Vehicle:2003 Wrx 2.5Lw/gt30r Team Snail |
Remove the plug that the yellow arrow is pointing to with subaru part # 11024-AA210 so you can install your sending unit.
#15 |
Member#: 129395
SWIC
Thanks Trav
#16 |
Member#: 60976
SWIC
Vehicle:1969 LGT FATURBO |
Freakin Pik Made My Neck Hurt
#17 |
Member#: 129395
SWIC
Okay so then i would just get that part number plus a splitter and then I could hook up an oil temp and an oil press. cool
#18 |
Member#: 100590
SWIC
#19 |
Member#: 107497
Vehicle:2006 WRX TR CGM |
I have a 52mm omori gauge, and the t-fitting that came with it has this brass orifice on one end. This piece is to stabilize the reading on the gauge. However, the hose that's on the BOV is far too large for this t-fitting(4mm). Now I could just get a sturdy brass fitting, but it doesn't come with the orifice...
Will I have to special order this from Omori? How did everyone else install their Omori meter? |
#20 |
Member#: 71615
SWIC
Vehicle:2002 Bugeye PSM |
#21 |
Member#: 106318
SWIC
Vehicle:11 Zoom Zoom3 |
1/8 npt i think not 100% tho
#22 |
Member#: 118334
SWIC
Vehicle:#555 2006 / 2005 S-AWD+TT2 WRX / RS Daily |
holy old thread bump batman! |
| Thread Tools | |
| Display Modes | |
| help with gauge install | scoobynewbie1 | Electrical & Lighting | 5 | 06-26-2008 08:10 AM |
| Help with gauge install? | WRXSteye20008 | Mid Atlantic Impreza Club -- MAIC | 5 | 05-12-2008 07:49 AM |
| Anyone wanna help with gauge install? | AWD>FWD | North West Impreza Club Forum -- NWIC | 14 | 12-30-2006 09:51 PM |
| please help with gauge install.... | anthony_delprete84 | Electrical & Lighting | 1 | 10-01-2005 07:25 PM |
| Anybody need help with gauge install | Speedwagon | Mid Atlantic Impreza Club -- MAIC | 3 | 11-17-2003 07:44 AM |
