South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-14-2006, 12:25 AM   #1
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
Default RS to STI drivetrain question
http://forums.nasioc.com/forums/show....php?t=1157494
if anyone knows the answer let me know asap, thanks
SubeSTIle is offline   Reply With Quote
Old 12-14-2006, 12:27 AM   #2
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
i think you should just sell it to me and save yourself the trouble
v8eaterWRX is offline   Reply With Quote
Old 12-14-2006, 12:29 AM   #3
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
haha, nice try. i cant wait to get this done, my hub bearing are starting to worry me. they have started making noise...
Old 12-14-2006, 02:28 AM   #4
SubyRSdriver
Visiting NASIOC Timeout
Member#: 94839
2005 2.5 RS
that is a good question... but.. If you are getting a full STi swap.. shouldn't it come with the pedals?
SubyRSdriver is offline   Reply With Quote
Old 12-14-2006, 02:36 AM   #5
SubyRSdriver
Member#: 94839
2005 2.5 RS
the few STi engine tranny units for sale I have seen.. were out of wrecked cars.. and had the pedals strapped on still. Unless you are piecing it together.
Old 12-14-2006, 03:55 AM   #6
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
the person i am getting it from got a whole car, since i am getting just the drivetrain and not the engine as of right now i dont think im getting the pedals. but i think that mine should work. i dont think i could have use them anyways since my car has a cable throttle and the 04 STI is setup a little differently. but im going to try and get the pedals in case i can use them.
Old 12-14-2006, 04:02 AM   #7
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
You dont need the pedals if you are just doing the tranny. The only reason you would need them would be for the engines drive by wire.
Smoby is offline   Reply With Quote
Old 12-14-2006, 11:51 AM   #8
Member#: 112472
2004 PSM JDM WRX
ATS TWIN PLATE Stg 22.5/6
No the pedals arent part of the drive train and the deals I ve seen most people just us the ones in your car.
James@RPM is offline   Reply With Quote
Old 12-14-2006, 02:02 PM   #9
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
ok, thanks for clarifing, i dont think i can acutally use the pedals until i do the engine swap anyways because of the drive by wire on the STIs. will be sealing the deal with the guy today! so should be installing early january!
Old 12-14-2006, 02:56 PM   #10
SubyRSdriver
Member#: 94839
2005 2.5 RS
whoh.. okay now I have a question.. lol So are you just running an STi drivertrain with out the engine on an RS motor? Will the 6 speed actually work decently on the RS motor? that is an pretty interesting thought. I know it would be dumb if you were not going to use a turbo engine.
Old 12-14-2006, 03:07 PM   #11
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
He probably plans on the motor in the future so getting the tranny, r180, brembos, etc is good idea. I bet his car will be alot funner to drive. I put a 6speed into my nearly stock wrx and it made a big difference in driveability. You have to shift a little more, but if you like shifting then it is no big deal. You can even skip gears with no problem, I am not sure how bad that is on the syncros although.
Old 12-14-2006, 04:49 PM   #12
SubyRSdriver
Member#: 94839
2005 2.5 RS
yea that is pretty understandable but there is a big difference between an RS and a WRX power plant. I don't think I have ever heard the Sti 6spd and 2.5
n/a motor in the same sentence.. pretty interesting. I think it would hurt performance based on the ratios that is why I am just curious as well as bored a lot aha
Old 12-14-2006, 05:03 PM   #13
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
its not actually going to affect my drivability at all, if anything it will help for power as it wont drop the rpms as much, right now i loose about 1500 rpms with every shift. and with the 6 spd i should loose about 800 or so per shift. and yes i will be using the stock RS engine until i can fund a usdm 2.5 STI swap and have the time to rewire the whole car. i should have everything in about 2 weeks or so.. should be compleate after the first of the year and ill have a write up on how it drives. Thanks for all the info.
Old 12-14-2006, 05:41 PM   #14
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
O man this is going to be fun
Poweredbysnail is offline   Reply With Quote
Old 12-14-2006, 05:52 PM   #15
wagonmasta
Member#: 52880
GGA Rev.D
man i'm jealous of you and your sexy coupe
wagonmasta is offline   Reply With Quote
Old 12-14-2006, 06:54 PM   #16
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
Man, i dont know who is more excited about doing this, me or travis. we should start a poll
Old 12-14-2006, 06:56 PM   #17
racingfish
Member#: 60976
1969 LGT
FATURBO
i gota pole for errrRr never mind.
racingfish is offline   Reply With Quote
Old 12-14-2006, 07:55 PM   #18
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
"Hey all, i am going to be getting an 04 STI complete drivetrain and was wondering if i needed the pedal set to go with it for the hydrolic clutch or if the stock ones would work? Thanks for any help in this.
James"
To answer your question, you will need at least the slave cylinder for the 6 speed because the RS and STi cylinders are different and mount different as well. Also, I've already told you (FAT) but just reminding you that you will need a 6speed clutch w/ flywheel if you get the starter that goes with the 6 spd other wise, get a 5 spd clutch w/ flywheel (RS and WRX flywheels have same ring gear) so you can use your RS starter. And yes 5 spd clutches work with the 6 spds. 5 and 6 spds have same splindes on the input shaft. If you do use a 5speed clutch, make sure you have a 5 spd release fork. STi 6 speed's are stright and WRX 5 spds have a bend in them.
Anyways any other questions come by the shop and we'll help you out with anything you need.
Chris
icslowmo is offline   Reply With Quote
Old 12-14-2006, 08:54 PM   #19
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
Thanks chris, but i am getting absolutely everything i need including brembos and all the hydrolic equipment and lines. so everything but the engine now will be STI on my RS. I apprecaite all your info. i will also have a flywheel and clutch master and slave cylinder for the tranny as well as the master cylinder for the breaks. and all the crossmembers and stearing rack. basiclly i did liek you said and found a donner car with everything but the engine. im stoked to get this started!
Old 12-14-2006, 11:16 PM   #20
SubyRSdriver
Member#: 94839
2005 2.5 RS
Dude thats sick! good luck and keep us posted for sure.
Old 12-15-2006, 09:28 AM   #21
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
That's awsome man, glad to here you got a whole car will help alot. If you have any questions or need help, you know where to find me.
Chris
Old 12-15-2006, 02:48 PM   #22
Poweredbysnail
Member#: 74753
Team Snail
Ok i win Man its going to be sick when we get it all done
Old 12-15-2006, 03:28 PM   #23
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
yea trannys are fun travis! hardest part is getting the tranny to mate up evenly, which is cake!
szeny is offline   Reply With Quote
04 sti drivetrain question and abs question with sti trany wildacex187 Newbies & FAQs 3 09-19-2009 08:47 PM
MY01 RS + 06 STi drivetrain schultz Subaru Conversions 10 09-02-2009 08:54 AM
rs to sti questions leonwrx13 Subaru Conversions 21 12-28-2008 11:54 AM
RS > STI drivetrain question SubeSTIle Subaru Conversions 1 12-14-2006 07:34 AM
01 RS to STi 6 speed conversion question/info needed Texas25RS Transmission (AT/MT) & Driveline 2 05-17-2005 01:43 PM
