Old 12-14-2006, 01:23 AM   #1
unit10·wrbp
Member#: 107236
06 wrx wrb
tun'd · stg [?]
Default stage 1 ok to run tbe?
Mods, please close this thread.
Last edited by unit10·wrbp; 08-27-2007 at 05:47 PM. Reason: Moderator: Delete this thread please.
unit10·wrbp is offline   Reply With Quote
Old 12-14-2006, 01:29 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Depends on how the OpenSource map was tuned. Best bet is to reflash to Stage 2 at the same time you install the TBE.
Warning: Even flashing to stage 2 cannot fix boost creep. Can fix the spikes though. Boost creep is a mechanical issue.
Old 12-14-2006, 01:44 AM   #3
totalreborn
Member#: 105765
2007 WRX TR
Obsidian Black Pearl
^^ thats what i said. unit 10 never listens. tsk tsk ahha
unit 5 reporting
totalreborn is offline   Reply With Quote
Old 12-14-2006, 03:00 AM   #4
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Stage 2 exhaust setup with a Stage 1 tune (stock exhaust setup) will result in big boost spikes in most cases due to the aggressive wastegate duty cycles required for good boost with stock exhaust. Don't do it!
drees is offline   Reply With Quote
Old 12-15-2006, 10:23 AM   #5
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
If you have a catted dp, your boost creep problems with the stock turbo will be minimal at worst.
06rexwagon is offline   Reply With Quote
Old 12-15-2006, 10:36 AM   #6
littlewhitewagon
Member#: 103068
11 STI sedan
but the spike when coming on boost could ruin his day.
littlewhitewagon is offline   Reply With Quote
Gt spec headers ok to run on ap stage 2? tacokid789 AccessPort 4 02-26-2010 07:32 PM
Installed TBE; Tuner Says OK To Run AP Stage 1 Map sfflyfish AccessPort 1 09-24-2008 01:15 PM
Ok to run vf39 with stage 2 map? swiftwrx06 AccessPort 7 01-04-2007 01:07 PM
Is it ok to run without fender liners at the track? Also, how to remove them? ewright Motorsports 9 10-29-2005 10:36 PM
Ok to run K&N typhoon w/ Stage 2 Accessport? SoareS Newbies & FAQs 8 09-03-2005 11:33 PM
