Old 12-14-2006, 09:21 AM   #1
JonM in MN
Member#: 133956
2004 WRX Sedan
WR Blue
Default Why is my clutch so heavy?
I noticed this when I drove an 06 TR awhile back --- the clutch seemed light as a feather. Getting back to my car, it took real effort to depress.
Is this common in 04 WRXs? I heard from someone with an 02 this might be an issue, but did a search and didn't see anything. Is it fixable?
JonM in MN is offline   Reply With Quote
Old 12-14-2006, 09:27 AM   #2
jasonallenross
Member#: 125978
2002 WRX Wagon
Start running (for endurance) and weights (for strength).
You clutch will feel much lighter over time
jasonallenross is offline   Reply With Quote
Old 12-14-2006, 09:36 AM   #3
pezman04wrx
Member#: 66558
The clutches are hydraulic, so I don't belive there is anything that could be done to fix the heavy/light feel ... Maybe the newer cars have modified the hydraulics slighty to get a lighter feel, really not sure if that's been done though ...
pezman04wrx is offline   Reply With Quote
Old 12-14-2006, 09:39 AM   #4
gte123v
Member#: 114481
2006 Sti
I believe they switched from a push type to a pull type in the 06.
gte123v is offline   Reply With Quote
Old 12-14-2006, 10:57 AM   #5
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Clutch pedal feel is generally a result of clutch pressure plate spring pressure. A high performance engine requires a pressure plate with stiffer springs so the clutch won't slip. Also the length of the lever (pedal) will affect the mechanical advantage you have when depressing the clutch. So if you have one car with a longer clutch pedal it may feel lighter than another car with a short pedal even though the pressure plate springs are the same.
Whether the clutch is actuated by a cable or a hydraulic cylinder shouldn't have any affect on how much pedal pressure you feel.
STirocket is offline   Reply With Quote
Old 12-14-2006, 11:01 AM   #6
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Another thing to consider is that the effort required to release a clutch changes as the clutch wears due to the non-linear nature of the pressure-plate spring. New clutches are almost always easier to press than worn clutches.
Old 12-14-2006, 11:10 AM   #7
Swordfish II
Member#: 95554
2007 The Surly Squad
+9854678
Swordfish II is offline   Reply With Quote
why is my clutch pedal so heavy??? subaru7717 Legacy Forum 13 11-09-2006 01:19 PM
Why is my clutch wierd? amolai Transmission (AT/MT) & Driveline 10 10-30-2005 01:46 PM
WHY is my car so heavy? how much does yours weigh?? Davenow Proven Power Bragging 100 06-20-2004 08:47 AM
Why is my car so loud..? typeRS Normally Aspirated Powertrain 18 02-06-2002 02:23 AM
('93-'01) Why is my shifter so loose? jImp Impreza Forum 2 06-23-2001 12:08 PM
