Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 12-14-2006, 10:43 AM   #1
epoth
Member#: 49667
2004 WRX 2.5 Hybrid
8cm18G - PPG Helical
Wink Turbo oil return tube on RHS head?
Does anyone know if there is an O-ring or gasket on this tube that goes to the right-hand side head? Or does it just press in there tight with no kind of seal?
I am pretty sure that this is the oil return tube for the turbo. There is no info about it that I can find in the service manual. It appears that the service manual guy didn't figure it was terribly important.
epoth is offline   Reply With Quote
Old 12-14-2006, 03:54 PM   #2
epoth
Member#: 49667
2004 WRX 2.5 Hybrid
bueller?
Old 12-14-2006, 03:56 PM   #3
marcymarc
Member#: 112861
2013 STi sedan
im not 100% sure, but i think there is no gasket for it.
if i remember correctly, it just slides in with the turbo.
marcymarc is offline   Reply With Quote
Old 12-15-2006, 03:43 PM   #4
epoth
Member#: 49667
2004 WRX 2.5 Hybrid
I'm actually wondering about on the side that goes into the head. I know that the hose just slides on with a little clamp on the turbo side. I just can't find whether there is any kind of seal on the end that goes into the head. It appears to just swage in there and be held on with that bolt. But who knows.
Old 12-15-2006, 04:28 PM   #5
epoth
Member#: 49667
2004 WRX 2.5 Hybrid
I have confirmed that there is no seal on the turbo oil return tube where it presses into the head. In case anyone is curous in the future.
How to Remove Turbo Oil Drain Tube on Head? SEEC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 11-18-2012 07:05 PM
how do you guys remove the oil drain tube on the head? ownnij Built Motor Discussion 14 12-10-2009 10:07 PM
liquid gasket on oil return tube blackrod punishment Built Motor Discussion 9 08-20-2009 02:05 AM
Oil return tube from Turbo paintbing Built Motor Discussion 5 04-22-2009 10:35 AM
Oil return tube to heads dwx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-01-2004 08:30 PM
