Old 12-14-2006, 02:19 PM   #1
jordanderson
Member#: 134158
Default Help with headlight wiring with pics!
Ok, to start things off, I know I'm a noob, I just got an 02 wrx, and for an easy first mod I decided to get some new headlights, unfortunatly the new headlights have a different connector than the car for the driving lights. But they both have three wires, so I decided to cut off the car's connector, which went right into the bulb, strip the new headlight's wires and test out different configurations, none of them worked. So if anyone can help, it would be greatly appreciated. Also there are little led rings around the bottom lights(smaller red and black wires), where should I tap those in?
jordanderson is offline   Reply With Quote
Old 12-14-2006, 02:44 PM   #2
steverx05
Member#: 128269
I can't tell from the picture...is there another connector coming out of your new headlights that is for your turn signal?
steverx05 is offline   Reply With Quote
Old 12-14-2006, 03:25 PM   #3
jordanderson
Member#: 134158
yes, the turn signal plugs in fine though.
Old 12-14-2006, 03:27 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
well, first off, why did you cut off the cars conector? alwasys cut the aftermarket crap as then you can still return it to stock.
if you do a search for ebay headlight wiring, you will find how to wire it right.
Shane
PARANOID56 is offline   Reply With Quote
Old 12-14-2006, 05:32 PM   #5
jordanderson
Member#: 134158
I've been searching for a couple days without luck.
Old 12-14-2006, 07:11 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Two things you should not have done-
1- Cut off the factory headlight connectors.
2- Bought those lights.
A bit of reading on this board would have turned up many reviews on those lights and provided the rather useful information that they are crap. Sorry but this is true. If you ever do get them installed you won't be too thrilled with the beam pattern, even though they are projectors they are the worst ones going and your stock lights are far better.
Previous versions of those lights were wired incorrectly but at least they had the right connector on them so you could move some pins around and get them to work. The connector on your lights is an H4 vs. the 9007 in the car. The H4 means the lights could possibly be a version intended for use in Europe which also indicates the beam pattern could be RHD, in that case the lighting would be even worse than it already is with the LHD version of these lights. That's just a guess as I don't even know for sure that there are LHD/RHD versions of these, but the H4 plug is a hint.
If you bought these from a vendor you may want to contact them and find out if they sent you the wrong ones, or even better just try and get your money back.
Old 12-14-2006, 08:48 PM   #7
jordanderson
Member#: 134158
Well, they aren't going to take them back. I don't care that much about the visibility they'll provide. I think they look sweet, and just need them to work. If they break or something, I'll put the stock lights back in. I looked around for a 9007 to h4 converter, but couldn't find anything, do they exist? Any suggestions as far as getting these to work? Could I just get a 9007 plug, cut off the h4 and switch it with that?
02 wrx to 04 STi front end swap, help with headlight wiring Unlikely Hero Electrical & Lighting 12 03-25-2011 01:40 AM
HID help! and headlight wiring help! Speeding101 Electrical & Lighting 5 03-27-2009 05:42 PM
Need help with headlight wiring... Erexxx Electrical & Lighting 5 10-12-2005 02:11 AM
Need help...Burnt headlight wiring lawchang Bay Area Impreza Club Forum -- BAIC 2 08-17-2002 10:21 PM
Help on headlight wiring harness rallysquirrel Legacy Forum 23 01-27-2002 08:30 PM
