Old 12-14-2006, 09:56 PM   #1
KaBar6
Member#: 101881
Default using methanol in 2006 STi intercooler spray?
Is this possible? Thanks guys.
KaBar6 is offline   Reply With Quote
Old 12-14-2006, 10:32 PM   #2
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
If you mean the stock ic sprayer I would not recomend it due to its high corrositivity. Now with a high presure pump sprayed into the intake tract using the tank as a resevour, yes but I recomend using a controller from one of the many kits available.
Sinister redlines is offline   Reply With Quote
Old 12-19-2006, 08:41 PM   #3
east milford wrx
Member#: 102301
there is no reason to do that..
east milford wrx is offline   Reply With Quote
Old 12-21-2006, 12:58 AM   #4
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
how about just mixing in a small amount of methanol/ rubbin alcohol with mainly Distilled Water. I heard this will help lower the freezing temp a bit in case it gets cold at night?
WRXDriftR is offline   Reply With Quote
Old 12-21-2006, 06:01 PM   #5
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
^^^This would work, but if it is cold enough to freeze then you shouldn't need to worry about spraying the intercooler. I do not know if the pump/seals in the OEM pump are made to handle alcohol in the reservoir though, so it may be a better idea to just let it freeze.
Old 12-28-2006, 11:19 AM   #6
darktritium
Member#: 133073
1999 2.5RS
Almost WRB
I take it you are trying to get more cooling on the intercooler. I wouldn't recommend doing so. Methanol is flammable and you really don't want to spill that stuff on yourself when filling the bottle. Granted it may take a while, but you could eventually have eyesight problems from the methanol being absorbed through your skin if it happens again and again. I would stay away from spraying flammable solvents on your intercooler.
darktritium is offline   Reply With Quote
FS in Mass NX intercooler spray Brand new Mystic Engine/Power/Exhaust 1 11-30-2009 08:13 AM
JDM STI intercooler spray switch/V7 sti scoop rear windsheld spray pump spliter. subrandon Private 'Wanted' Classifieds 1 07-07-2006 12:45 AM
OEM Sti intercooler spray button- used with Nitrous? BillyC Electrical & Lighting 3 10-12-2005 06:43 PM
STI intercooler spray switch Bookmanx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-20-2003 10:47 PM
JDM STi Intercooler Spray Switch : vendor ? Bookmanx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-01-2003 11:10 AM
