Old 12-14-2006, 10:58 PM   #1
HellBinder
Member#: 132385
94 RHD Legacy
w/wrx swap. White
OMGHi2U clutch advice on WRX conversion
Iam using an 01 legacy trans and i need a new clutch, pp, tob, ect.
Who has had experience with the different high performance clutches?
I'm running 225-260hp (depending on the bolt ons) and i need something i can run at the races on friday night and drive to work the next day, also ive got to move back to alaska next summer.
Would a stock clutch hold up or should i go aftermarket?
Note; iam a horrable driver, thats why i work on cars and not race them professioanlly, so my clutch skills are that of a 2nd level magic user in a fist fight with a Mountain Giant. (hahaha, dnd reference).
Anyway, i could go 9.6 to 12lbs on a flywheel so i'll always be on boost.
any help or input would be appriciated.
HellBinder is offline   Reply With Quote
Old 12-14-2006, 11:03 PM   #2
ten80
Member#: 53625
00 EJ205 LGT LTD
97 LGT Wagon
Exedy stage 1 clutch and ACT 14lb flywheel run $550ish from import image (see vendor forum). Unless you want an über beefy and stiff clutch stage 1 should hold your power just fine. Organic clutches like the stage 1 are also easy to drive, like the stock one. Keep in mind that a 9lb flywheel will not make the stock ECU happy unless you are tuned.
ten80 is offline   Reply With Quote
Old 12-15-2006, 12:59 AM   #3
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
Originally Posted by ten80 View Post
...Keep in mind that a 9lb flywheel will not make the stock ECU happy unless you are tuned.
seriously!!! I have a lightened flywheel and the computer goes nuts every time I reset the ecu. It idles like a yugo for the first few days until the computer learns that something is different...
janikphoto is offline   Reply With Quote
Old 12-15-2006, 07:53 AM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
+1…
No need to step away from an organic disc which will give you best drivability. Either Exedy street or stage-1 clutch would be my vote…
xcntrk75 is offline   Reply With Quote
Advice on WRX TyboJames Newbies & FAQs 13 12-17-2009 11:22 PM
06 wrx needs advice on a clutch raller Factory 2.5L Turbo Powertrain 11 09-23-2009 08:53 PM
advice on WRX standing starts needed please valueape Newbies & FAQs 17 02-27-2009 01:45 AM
Need advice on WRX wagon tires/wheels davesill Brakes, Steering & Suspension 22 10-31-2001 07:40 PM
muffler advice on WRX Samirr76 Factory 2.0L Turbo Powertrain 10 07-05-2001 09:41 AM
Message Board Statistics All times are GMT -4. The time now is 02:49 PM.
