Old 12-14-2006, 11:19 PM   #1
plug1
Member#: 30230
07 Imprza 2.5i Wgn
newport blue
Default 1997 legcay L, question about interior lighting...
...In the picture below, are the little icons on the buttons supposed to light up? I've owned the car for a while, bought it used...and they've never lit up. I'm wondering if it's a blown fuse, a different problem...or if they just don't function this way? The little lights below the buttons light up...and the green part of the A/C button lights up...but none of the numbers around the fan speed dial or anything else lights up....?
plug1 is offline   Reply With Quote
Old 12-14-2006, 11:25 PM   #2
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
follow these directions
http://www.scoobymods.com/forums/showthread.php?t=91
the only tedious part is messing w/ the E-clips on the temperature cable. Everything else is pretty straight forward. I used the bulbs from radioshack
listed as Radio Shack bulb #7219, catalog number 272-1092.
You can get the light w/ the base from the dealer probably but just taking the old one out and putting the radioshack one in takes a minute. theres also a light behind the hazard button incase yours doesnt light up either. thats easy to take care of just take the button out and peel off the silver wrapping and you will see the bulb.
Good Luck!
legacy1907 is offline   Reply With Quote
Old 12-14-2006, 11:33 PM   #3
plug1
Member#: 30230
07 Imprza 2.5i Wgn
newport blue
awesome. thanks a bunch, especially for the quick reply. guess I'm headed to radio shack tomorrow!
Old 12-14-2006, 11:34 PM   #4
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
when you get to radioshack just look for the bulbs w/ those numbers on them and its just like rewiring a christmas light basically
Old 12-14-2006, 11:36 PM   #5
plug1
Member#: 30230
07 Imprza 2.5i Wgn
newport blue
sounds easy enough. shouldn't take me more than 20 mins I wouldn't think. Thanks again.
Old 12-14-2006, 11:40 PM   #6
Aczwild
Member#: 71721
'98 RS (Race Car)
'13 GMC Sierra (Tow Rig)
You can also find a write up here that I did with pics when mine went
http://www.legacygt.com/forums/showthread.php?t=26408
Aczwild is offline   Reply With Quote
Old 12-15-2006, 12:37 AM   #7
sha_zapple
Member#: 41012
1998 Legacy L
Jeeze, you need to post that in the DIY section at www.sl-i.net !
sha_zapple is offline   Reply With Quote
Old 12-15-2006, 08:00 AM   #8
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Okay, as usual I am still a little confused here...
On my '99 Legacy all the buttons light up as well as the green lights below (indicating which button you have pressed - the "defrost" is amber coloured), but on my '96 Legacy L all I get are the lights below the buttons. I just sort of assumed that is how the cheaper Legacys work. I have never seen the numbers on the fan speed control lighting up on either car.
What exactly does putting new bulbs in "fix" ???
Is there a reason why some bulbs burn out and others do not ???
Do I really need to yank those "E-clips" to disconnect the Heater control cable, or can I just swap out the bulbs with the cable mechanism still connected ??? I don't really want to loose my heat in the middle of winter.
Thanks !
Jonathan is offline   Reply With Quote
Old 12-15-2006, 09:27 AM   #9
plug1
Member#: 30230
07 Imprza 2.5i Wgn
newport blue
Now, the write up you posted lists two different types of bulbs, a short and a long one. Did you just use the bulb you listed above in all three places?
Old 12-15-2006, 09:30 AM   #10
plug1
Member#: 30230
07 Imprza 2.5i Wgn
newport blue
Originally Posted by Jonathan View Post
...but on my '96 Legacy L all I get are the lights below the buttons. I just sort of assumed that is how the cheaper Legacys work.
Did you buy this car new? or used? If used...maybe the bulbs had burnt out before you bought it?
For as little trouble as it it, I'm going to give it a shot today...if it works, great...if it doesn't, then I'll be in the same position I have been for the past 3 years with this car. no big deal.
Old 12-15-2006, 09:32 AM   #11
skunkfifty
Member#: 73102
1998 legacy outback
white
"easy" way around the E-clip situation is to unhook the cable from under the dash, near the passengers foot well. you have to get into a somewhat awkward position to do it, but it eliminates the need to remove the cable from the temp controls.
skunkfifty is offline   Reply With Quote
Old 12-15-2006, 10:07 AM   #12
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
the bulbs are the same its just the base that they are in one of them is longer so just remember which hole the longer base went into and you will be good. As far as the 96 L that you said none of the fan numbers worked nor did the option butttons, those are the exact ones that were out on mine when i changed the bulbs. The only lights that worked on mine were the lights under the option buttons like yours and the green AC light. Once i changed the bulbs everything lights up. Its probably either the bulbs or just the bulb connection is slightly loose but you might as well change the bulbs while you have it in peices. As far as the temp cable goes, either take out the E-clips or do as skunk says cause its a hell of a lot easier to do this on a workbench or something rather that attempting to do it still connected which im not even sure would be possible with the space given. But also if your hazard light is out you might as well take a look at that as well.
Old 12-22-2006, 10:34 AM   #13
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Thanks !
Old 12-22-2006, 03:40 PM   #14
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yes, on all models, all the buttons and lights are supposed to light up.
Wiscon_Mark is offline   Reply With Quote
Old 12-22-2006, 05:30 PM   #15
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
wow, I didn't know that I've had my 95 for 5 years now and everytime I drive it at night I swear at how stupid that is designed. I'll check into this, great write ups.
runninstrong is offline   Reply With Quote
Old 12-22-2006, 07:09 PM   #16
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
yea i just replaced all my bulbs recently, it makes a huge difference. Now i can see all the buttons
Old 12-22-2006, 07:39 PM   #17
dplacen
Member#: 117010
1997 Legacy GT
2006 Spec B #256
My bulbs were also blown when I first bought the car. I ended up replacing them good as new now.
dplacen is online now   Reply With Quote
Old 12-23-2006, 09:56 AM   #18
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Mine were out too, but I never replaced the bulbs. More often than not, it's a bad connection that caused your bulb to go out. Why? Rattling from driving, pushing those buttons, etc. Give it a wiggle, see if it doesn't light up again.
Old 12-24-2006, 11:24 AM   #19
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
I'm thinking a spilled coffee is the culprit of my lights being blown. I took it apart, and there's a very very old brown sticky substance everywhere, this could be why my CD player is acting up as well.
Old 12-24-2006, 11:38 AM   #20
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
yuck. I almost never use those cupholders because of that kind of thing...
questions about tail lights and head lights goose05 Interior & Exterior Modification 5 09-05-2006 09:38 AM
98 LGT wagon question on interior lighting boomsticks Legacy Forum 10 01-16-2006 01:51 PM
Questions about interior bulbs. antidote11 Interior & Exterior Modification 3 04-19-2005 03:48 PM
question about interior b0ym0nkey Car Audio, Video & Security 1 02-26-2002 03:03 PM
Question about Fog Lights Vigorous Interior & Exterior Modification 9 06-06-2001 08:23 AM
