Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC > NESIC Private Classifieds
Old 12-15-2006, 04:39 PM   #1
Jack
Add Lightness
Member Sales Rating: (7)
Member#: 13699
2004 Outback, 13 XV
(From General)
Default Prepared Honda CRX racecar for sale
1987 Honda CRX-SI racecar
Modified to COM Prepared C specifications. Under 1600 pounds.
Previous life, the car was an SCCA ITA car. Been a racecar since 1997
SCCA Logbook from previous life, maintenance manual
Suspension:
OPM front adjustable camber spherical strut mounts
OPM 29mm torsion bars
OPM adjustable external rear sway bar
removed front sway bar
Koni front shortened ext double adjustable shocks
Koni rear shortened ext single adjustable shocks
500 pound/inch rear springs with adjustable height
Rear adjustable pan hard bar with spherical mounts
Brakes:
new 89 Integra master cylinder (no booster)
89 integra proportion valve
new 89 Integra front calipers and rotors (subject to change..ask)
89 Integra rear disk brakes and rotors (ebrake crap removed)
Stainless braided lines and adapters all around
3 inch duct from front directional light holes directed to rotor center
1.5 inch duct from front directional directed to calipers
duct from cowl into cockpit for driver cooling
Engine/tranny:
SCCA legal D15 Freshened with bearings, seals, new head, belt
header
resonator and Muffler with rear exit. (I believe 2.5" pipes) Meets Lime Rock noise
cold air intake with K&N cone filter
Canton oil pan with oil temp sensor (gauge is in spares list)
front mounted oil cooler with AN fittings
Limited Slip Differential
SCCA fuel test valve
Interior:
Lightweight fiberglas shell seat. No pass seat included
Stock tach, water temp, fuel gauge. VDO oil pressure gauge
Fire extinguisher
SCCA legal 2 circuit battery/alt kill switch
8 point welded in SCCA rollcage with NASCAR driver bars. (cost $1500 originally)
Wink mirror + stock outside mirrors
Body:
Extensive removal of non-required equipment.
Windshield still glass with wiper for rain days
Plexiglas hatch window w/2 aluminum supports and pass rear quarter window.
No door glass. Still a door slammer with hinges and door latches
Hatch gutted but still on hinges with 1 hood pin latching it. uses 1 gas tube to hold it up.
Wiring not used has been removed everywhere in the car.
Bumper beams removed with covers in place held with bolts and front tow loop
driver headlight is plexi panel, pass side screen allowing air direct to cone filter
Interior sound deadening and undercarriage undercoating mostly removed. Rear unibody has been re-enforced (these cars without this can pull out the subframes just like E36 M3's do). Sunroof and hardware removed. Sheet metal riveted in place. Radiator fan removed (connector/sensor/wiring still in place)
Spares:
CV axles, brake rotors and pads, doors with glass, front and rear bumper covers, glass pass quarter window, brake parts and lines, lots of boxes of stuff with "Honda" written on them. VDO Oil temp gauge, D16a1 bare block and crank (integra), 3" tach, several radiator fans.
Wheels: 4 integra 14's with junk tires and a couple diamond 13x6 steels with old track tires
Car can be delivered within 100 miles of Hopkinton, MA. Asking $5000
contact [email protected]
2006 pictures: go to any of the links:
http://www.tracktimephotos.com/large..._NHIS_INS_7441
http://www.tracktimephotos.com/large..._NHIS_INS_7881
http://www.tracktimephotos.com/large...12LRP_INS_7016
http://www.tracktimephotos.com/large..._NHIS_INS_7462
http://www.tracktimephotos.com/large..._NHIS_INS_7424
http://www.tracktimephotos.com/large...12LRP_INS_7042
http://www.tracktimephotos.com/large...12LRP_INS_7079
http://www.tracktimephotos.com/large...12LRP_INS_7080
http://www.tracktimephotos.com/large...12LRP_INS_7790
http://www.tracktimephotos.com/large...12LRP_INS_7794
http://www.tracktimephotos.com/large...24LRP_INS_2059
http://www.tracktimephotos.com/large...24LRP_INS_2079
http://www.tracktimephotos.com/large...24LRP_INS_2448
http://www.tracktimephotos.com/large...24LRP_INS_2970
http://www.tracktimephotos.com/large...24LRP_INS_2980
http://www.tracktimephotos.com/large...24LRP_INS_2993
http://www.tracktimephotos.com/large...3_LRP_INS_0825
http://www.tracktimephotos.com/large...3_LRP_INS_0850
http://www.tracktimephotos.com/large...3_LRP_INS_1286
http://www.tracktimephotos.com/large...3_LRP_INS_1342
http://www.tracktimephotos.com/large...3_LRP_INS_1363
http://www.tracktimephotos.com/large...3_LRP_INS_1936
http://www.tracktimephotos.com/large...3_LRP_INS_1963
http://www.tracktimephotos.com/large...3_LRP_INS_1977
http://www.tracktimephotos.com/large...3_LRP_INS_1995
http://www.tracktimephotos.com/large...3_LRP_INS_2002
Old 12-15-2006, 06:53 PM   #2
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
*runs off to buy a powerball ticket*
Best of luck Jack. I thought you were only allowed to buy cars. Now you're selling?
what's the replacement vehicle?
iamrazor is offline   Reply With Quote
Old 12-15-2006, 08:18 PM   #3
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Sold
jack
CRX Racecar For Sale (again) Jack NESIC Private Classifieds 10 05-25-2007 07:14 PM
H5/ITB Civic and CRX Si Racecars for sale Zephyr Tri-State Area Private Classifieds 2 11-29-2006 11:44 AM
Integra racecar for sale. SCCA ITA / Honda Challenge H4 elgorey MAIC Private Classifieds 14 10-30-2006 09:43 PM
USTCC Subaru WRX Racecar for Sale B Esquire Private 'For Sale' Classifieds 9 11-23-2005 03:37 PM
1991 Honda CRX Si FOR SALE PGT Private Vehicle 'For Sale' Classifieds 3 06-22-2004 07:15 PM
