Old 12-15-2006, 08:36 PM   #1
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Default Two sets of pads and rotors
I know it's "best" to resurface rotors and rebed pads whenever the pads are changed. Some have said that's "it's ok" to switch between pads of similar compounds.
My car is my everything car. I need to daily drive it, drive it to the event, participate, then drive it home. I don't get to events often so I want the pleasantness, no noise, lowlow dust nice pads. But when I do, I want to avoid fade as I see that as a safety item.
If I keep a set of rotors for my nice pads, and a separate set of rotors for my HawkHP+ or whatever pads (both of which have been properly bedded with their respective mate), then would this be ok and get something closer to "ideal"?
I understand that the mating processes will be a little off as the remounted rotor/pads will be different than previously; but I'm guessing not by enough to really matter that much.
I'm also planning to just keep Motul600 or whatever as fluid 100% of the time as other that price, I don't know of any daily drive drawbacks.
Is this a reasonable plan? Please let me know/correct me.
chimchimm5 is online now   Reply With Quote
Old 12-15-2006, 10:02 PM   #2
import111
Member#: 24447
2010 Evo GSR
GG
That is an expensive, but very good plan.
import111 is offline   Reply With Quote
Old 12-15-2006, 10:32 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
That'll work just fine, and is the technique that a lot of people who open track their daily driver use.
And FWIW, you don't need to resurface your rotors when you switch pads. A quick pass with a 3M Scotchbrite pad to remove the bedded pad material and you're good to go. Takes all of 2min. I haven't resurfaced a set of rotors on either of my cars in I think 6 years.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 12-15-2006, 10:32 PM   #4
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Is it really though? I figure in the long run, it's actually cheaper.
If I only used one set of rotors, I'd have to keep having them turned. Do this enough, and you've paid for another set. Since I would have two sets, then theoretically there is the same or more use out of the two sets than buying one set at a time sequentially, especially since material is always wasted when turning.
Higher cost upfront, lower cost in the long run.
Old 12-15-2006, 10:34 PM   #5
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Pat Olsen
Oh cool.. forget the extra rotor, I'm just gonna cheap out with a scotchbrite.
Old 12-16-2006, 08:55 PM   #6
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
if you're doing track... why not go for a more agressive track pad? rather than using the HP+....
btw, i do this too..... change pads / usually rotors at the track.... my 04-06 solo2 pads are crap at the track.... so I didn't have a choice.... I use porterfield R4 for track (once they're done, probably switch to hawk black/ht10).
Robin2 is offline   Reply With Quote
Old 12-17-2006, 12:53 AM   #7
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Yeah... I'd go for any pad. I just said HP+ because that's what I was thinking before this 2 rotor idea.
Old 12-17-2006, 10:16 AM   #8
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I've done both, but if you can swing it, and don't mind the swapping each time, get a dedicated set of rotors and pads for the track. You're street rotors and pads will last MUCH longer, and you'll have a well bedded set of rotors and pads for the track. I did this with my Stoptechs on the old wagon. I haven't done it on the STI because I don't drive it on the street much, but eventually I will go that route.
wtb full set of brakes and rotors kingpin89 MAIC Private Classifieds 12 06-16-2009 05:52 PM
2006 / 2007 4 pistons WRX front calipers complete w/ hardware and two set of pads Bala Suspension/Brakes/Handling 19 01-26-2008 08:28 PM
FS Two sets of HotBits coilovers new and used one set of F/R HotBits camber plates MD biknman Suspension/Brakes/Handling 14 01-11-2008 01:18 AM
FS: (NJ) Two sets of OEM Style rear brake pads for STI Brembo's 2005AspenWhiteSTI_NJ Suspension/Brakes/Handling 5 08-24-2007 09:39 PM
