Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 12-15-2006, 11:30 PM   #1
epson1
Member#: 122909
2003 Evo 8
Apex Silver
Default help with botched sensor install!!!
Well after my grueling install of my gauges i managed to mess somthing up. after attempting to tap the manifold i mis taped it and noe i can't thread it. or it would take an act of god to tap it. anyway i can fix the problem buy drilling the hole out and putting in a bigger bolt? i'd weld the sensor on but i have no cast iron welding skills
epson1 is offline   Reply With Quote
Old 12-15-2006, 11:31 PM   #2
X-Factor
Member#: 101720
2006 Evo IX GSR/SSL
Electric Blue
Professional shop FTW!
X-Factor is offline   Reply With Quote
Old 12-15-2006, 11:39 PM   #3
Brad Pittiful
Member#: 34931
sorry you cant use **** as a thread title...im sure they will lock this thread
Brad Pittiful is offline   Reply With Quote
Old 12-15-2006, 11:40 PM   #4
imaaaron
Member#: 74047
Find a local machine shop. Shouldn't be more than $50.
imaaaron is offline   Reply With Quote
Old 12-15-2006, 11:54 PM   #5
epson1
Member#: 122909
2003 Evo 8
Apex Silver
the title was "*****!" but i see someone changed the title and im glad it didn't get locked. but anyways i have a 800$ tapping kit i got from a mech. at a meat packing plant. i'd preferably not want to pay more money... but the threads are pretty messed up
Old 12-16-2006, 02:28 AM   #6
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I moved your thread out of the "newbie" forum to the engine tech forum with hopes you'd get more help...
to aid in getting that help, can you describe more fully what is messed up about the threads? Typically, if they are just "messed up", you can drive the tap in carefully to create new threads. You need to be sure and use tap cutting fluid (lots of it) and it helps to have the manifold clamped in a vise to keep it from moving while you use your T-handle to drive the tap in.
If the threads are bored out too much, you will likely need to go to the next bigger size and buy an appropriate plug for the threads, then drill/tap the other side (there is an identical casting button on the backside of the manifold that works just as well). Obviously be careful this time
nhluhr is offline   Reply With Quote
Old 12-16-2006, 01:49 PM   #7
epson1
Member#: 122909
2003 Evo 8
Apex Silver
How can i seal the hole i already made and use the other "button" on that opposite side?
Old 12-16-2006, 09:35 PM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Whatever you do, don't weld the probe in place. I sure hope you were joking about that part.
Can you post a pic of your carnage?
Old 12-17-2006, 05:08 AM   #9
epson1
Member#: 122909
2003 Evo 8
Apex Silver
What i've decieded to do so i don't completely screw it up is drill out the crapped hole, thread it and put a bolt with some thread lock on it and i'll take it to a machine shop to have the good side drilled and tapped so i can't mess it up.
Old 12-17-2006, 05:11 AM   #10
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
No commercially available threadlock I'm aware of will actually withstand the heat that the exhaust manifold sees. You just need to put in a fresh clean bolt and take it in as hard as it'll go to make sure it never falls out. You could safetywire the bolt to help make sure it doesn't come out over time.
help with map sensor install STiAlain Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-08-2009 05:01 PM
(MD) MoCo: Anyone want to help with roof vane install? (maybe host install day??) GreenLantern Mid Atlantic Impreza Club -- MAIC 25 11-11-2008 09:51 PM
LI/NYC: Can anyone help with EGT sensor install S1MPSONS Tri-State Area Forum 10 07-28-2006 03:04 PM
need help with O2 sensor SubaruLover Normally Aspirated Powertrain 6 08-21-2002 11:35 PM
Need help with o2 sensor signal please help ac_gohan Normally Aspirated Powertrain 1 01-16-2001 06:06 AM
