Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 12-16-2006, 01:13 AM   #1
GDArex003
Member#: 122924
2011 sti
spark silver
Subaru Banner 03 wrx need help with brake pads!!
GDArex003 is offline   Reply With Quote
Old 12-16-2006, 06:58 AM   #2
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
http://forums.nasioc.com/forums/show....php?t=1066905
You need the later pad. You will have the same problem with the back. Check out the Stoptech link in the thread.
GDR is offline   Reply With Quote
Old 12-16-2006, 10:58 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 01-31-2007, 03:14 PM   #4
polarpreza
Member#: 71881
I have a 03 wrx and my car production date is 01/03 which rear pads should I get ? cos I am planning to buy it online and bring it to a shop to get it install, someone have information on which exact production batch they changed the pads ?
polarpreza is offline   Reply With Quote
Old 01-31-2007, 03:19 PM   #5
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
You have to measure the width of the ears on the brake pads. Some have 02 brakes, 02/03 mixed, or 03. Mine are 02/03. Post the width here in mm and somebody will tell you what you have.
WRX03 is offline   Reply With Quote
Old 01-31-2007, 03:33 PM   #6
REX8
Member#: 24038
Go to the stoptech link above, look at the the shape of the pads. Then look at yours, you probably have to pull a wheel. You SHOULD be the D929 size.
I was 9/02 IIRC and have the new fronts (929) but the old rears (770).
Old 01-31-2007, 05:06 PM   #7
MidRex
Member#: 32841
2007 STI (Sold)
03 WRX FP Green PPG (RIP)
I'm going through the exact same thing right now 9/02 and I have the same as above (new fronts, old rears)
MidRex is offline   Reply With Quote
Old 01-31-2007, 05:12 PM   #8
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Are we still having problems w/ this??
up to 06/02 or thereabouts - old fr/old rear (13mm tabs on both)
about 7/02 to 10/02 - new fronts/old rears (10mm tabs - 13 mm tabs - so a visual should confirm that the rear tabs are larger)
11/02-12/02 - new fronts/mix in rear so you must check
1/03 on - new fronts/new rears (10mm tabs/7 mm tabs)
Lets apply logic - if the rear tabs are smaller than the front tabs then you have NEW rear pads. (7 is less than either 10 or 13)
KNS Brakes is offline   Reply With Quote
Old 02-01-2007, 05:47 AM   #9
WRX03
Member#: 20744
05 Baja Regal Blue
I wish they would but the tap measurements in the sticky.
I didn't even have to pull the wheels off to measure them.
Old 02-08-2007, 04:38 AM   #10
polarpreza
Member#: 71881
mine is 01/03 and I called one of the dealership and check which pads do i have, and then they ask me for my VIN to look into the system. they told me i have the older style pads .. I am so confuse . i guess i will have to take off a wheel and measure it sometimes this weekend .
edit : just ran downstairs to measure . 7mm tab
Old 02-08-2007, 05:46 AM   #11
KNS Brakes
Member#: 125739
2015 WRB WRX
That doesn't agree with your dealer saying you have 'old style' pads
old pad in old bracket
new pad in old bracket
Old 02-08-2007, 06:35 AM   #12
polarpreza
Member#: 71881
oops , its 3 am and I read my ruler wrong ...... its 13mm .. thanks you wrxbrakes for helping btw
you got pm
Need help with brake pad change RR Service & Maintenance 5 01-19-2006 04:55 PM
Need some quick help with brake pad install... e11ys Brakes, Steering & Suspension 4 08-25-2005 05:09 PM
I Need Help Finding Brake Pads For Stop-tech Big Brake Kit! SNEEZER Brakes, Steering & Suspension 2 02-26-2004 02:29 PM
Need Help, with Brake Pads xtheviperx New England Impreza Club Forum -- NESIC 18 05-02-2003 09:15 AM
Need help with Brake pad/rotor issue? Jasno999 Mid Atlantic Impreza Club -- MAIC 11 04-30-2002 09:57 PM
