Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 12-16-2006, 06:51 PM   #1
scooby-stu
Member#: 52890
Default Hydra + engine install= no spark??
Afetr getting my project wrapped up i have been faceing issues starting the engine. First i thought it was a fuel pump problem but that was fine second i took one of the coil packs out attached the spark plug, cranked the engine and no spark?? Any ideas to what the problem could be? any other tests i could perform? i have checked the engine harness and it all looks good also i checked the ecu connections and the looks good.
Thanks Stu
scooby-stu is offline   Reply With Quote
Old 12-17-2006, 10:55 AM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Give us some details on the car, the engine, what map you are using etc. Hydras will not deliver spark unless the cam and the crank sensors sync up. Are you running an Element Hydra? If so you can email me the crank trigger test and I can look it over for you along with checking to make sure you have the best base map for your setup.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 12-17-2006, 02:17 PM   #3
scooby-stu
Member#: 52890
Phil this is Stuart in socal it was your hydra i bought with the red map. I found that the problem was the sensor in the front middle of the Engine. After that was connected right she fired up first time However the car is preety smokey. I guess this maybe because the engine got flooded with too many cranks about 15 or the crank enrichment is too high?
Old 12-17-2006, 02:34 PM   #4
youpers
Member#: 8988
2000 L GT
White & blue
im dealing with the same exact problem right now.
youpers is offline   Reply With Quote
Old 12-17-2006, 02:46 PM   #5
scooby-stu
Member#: 52890
yours is smokin? tell me more
Old 12-17-2006, 05:58 PM   #6
youpers
Member#: 8988
2000 L GT
White & blue
No, I haven't got it running yet. Based on crank trigger tests I have either the cam sensors or the AVCS sensors hooked up wrong, so the Hydra isn't firing the coils. A funny side note I changed the wiring on the cam sensors last night and now when it cranks, the tach bounces around. Do you have the 2.1 or 2.5?
Old 12-17-2006, 10:17 PM   #7
scooby-stu
Member#: 52890
i have both softwares as for the ecu it is used so it would be an older one i have fired the car up with little problems however the car is smoking bad. I cant stand it cause its smokin my garage out with the door open
Old 12-18-2006, 03:10 PM   #8
Element Tuning
Member#: 54918
673 WHP Element
That would be the crank sensor which is required to start the car
It's possible you filled the motor up with fuel during that experiment and it should clear itself out. I would recommend changing your oil if you feel a lot of fuel ran into the crankcase.
That map should be right in the ball park so I wouldn't look there for the problem unless you altered something. After speaking with you on the phone verify you have the correct spark plugs installed in your Hybrid.
Thanks,
Phil
Old 12-20-2006, 12:35 AM   #9
scooby-stu
Member#: 52890
My bad was the bad vacum connection at the BOV so i put it at the Fuel pressure reg nipple on the manifold
Cheers Phil motor is running strong i didn't push too hard but man 8cm red, nice low end torque, no lag, feels overall very strong. AFR are spot on too
Old 12-20-2006, 09:06 AM   #10
Element Tuning
Member#: 54918
673 WHP Element
I'm glad it was something simple.
Have fun.
Phil
Hydra fuel but no spark WickedRydaX Other Engine Management 23 04-04-2009 10:32 AM
Hydra 2.6, no spark White out Other Engine Management 8 12-31-2008 10:45 PM
Switched from Hydra to Utec and now no spark grofry UTEC 25 08-18-2008 07:18 PM
Hydra no spark? napphappy Other Engine Management 0 02-22-2008 01:39 AM
No spark in new engine!! PLEASE HELP! james_gt Subaru Conversions 6 07-25-2003 08:44 PM
