Old 12-16-2006, 09:26 PM   #1
4pOwnag3
Member#: 53200
2005 LGT
Default SMC install help, positive wire has a fuse?
i just bought the kit used from a member here. No problems with the kit, everything there, it just doesn't come with the install manual. I got it installed, i just have 1 question left. The positive wire has a fuse on it, should i just put it in a blank slot in the fuse box or does it replace a fuse? please let me know, and if it replaces one, which one. - thank you in advance, MIKE
4pOwnag3 is offline   Reply With Quote
Old 12-17-2006, 12:27 AM   #2
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
If the cable is feeding from a direct power source, it should be fused as close to the power source as possible (battery in most cases). If the power source is a connection already fused, it should not be a problem, but if uncertain, always fuse it!
El Gato is offline   Reply With Quote
Old 12-17-2006, 08:51 AM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
It’s designed to replace the 30amp fuse for the windshield wiper circuit. A means of tapping into chassis power on a circuit which likely won’t be used in-conjunction with the alky system I suppose…
xcntrk75 is offline   Reply With Quote
Old 12-17-2006, 08:59 AM   #4
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
My instructions told me to put it where the rear defroster fuse goes..
PeteDucati is offline   Reply With Quote
Old 12-18-2006, 01:14 AM   #5
4pOwnag3
Member#: 53200
2005 LGT
ok, so basically either one of those fuses should be REPLACED, not just stick it in an empty slot? thanks guys, MIKE
Old 12-18-2006, 08:27 AM   #6
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Do you have a newer kit by chance? I dug up my original instructions and they do say to replace the windshield wiper fuse to tap in for power. Although my kit is an early rev so I wouldn’t be surprised if it’s been updated…
Old 12-18-2006, 11:55 AM   #7
4pOwnag3
Member#: 53200
2005 LGT
I'm not sure how new the kit is, the member i got it from never fully installed it, so its fairly new. thanks for the help guys!
Old 12-19-2006, 08:32 PM   #8
east milford wrx
Member#: 102301
yes replace the washer fuse
east milford wrx is offline   Reply With Quote
Old 12-21-2006, 03:43 PM   #9
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Crap.. I'm not sure now - I don't think I have the instructions anymore. I assume as long as it's a high amp circuit it's fine. I do prefer the rear defroster idea, though - even if it is wrong. The only time I use the rear defroster is when I first start the car - and I avoid spraying when the motor is still cold.
Old 12-21-2006, 04:06 PM   #10
east milford wrx
Member#: 102301
listen.. i have the same kit... replace the number 30 washer fuse...
My rs project rs420 Vancouver Impreza Club Forum -- VIC 31 06-07-2010 12:12 AM
2000 brighton wagon, tach instal HELP??? imperium Electrical & Lighting 3 06-04-2010 02:22 AM
SMC Install help.. David L. Water/Methanol Injection, Nitrous & Intercooler Cooling 7 04-14-2008 08:11 AM
Help....installing dtec bc....help with wiring gotti Engine Management & Tuning 1 05-15-2006 01:31 PM
Who has installed Perrin positive steering response kit? NORCAL STI Brakes, Steering & Suspension 13 12-07-2004 11:42 PM
