Old 12-17-2006, 08:15 AM   #1
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default can I use my 2000 RS powersteering pump and lines for a WRX swap?
Can i use my old PS pump and lines and alternator from my MY00 RS on a USDM WRX motor for the swap into the 2000 RS? Or do I need WRX PS and Alt.?
Thanks
Leor
WRC1 is offline   Reply With Quote
Old 12-17-2006, 12:23 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
no, you need a WRX power steering pump, lines, and resivior
Also the WRX alternator is a bit wider so get that as well
Old 12-17-2006, 02:02 PM   #3
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
Thanks
Old 12-18-2006, 10:01 AM   #4
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
if you're really hard up for cash though you can usually go to a local hydraulics shop and they can make hoses for you for a lot cheaper than Subaru sells them for.
You do need the wrx PS pump though...and alternator like hndatch said...
subydude is offline   Reply With Quote
Old 12-18-2006, 11:50 AM   #5
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
im doing the same swap into a 95 and i have the lines and everything, but my question is "how do i drain the old PS pump?" sorry for a dumb question but this is my first time doing anything more than an oil change on a car. this is the only thing left i have to drain before i can pull the old engine.
circaisdashiat is offline   Reply With Quote
Old 12-19-2006, 07:26 AM   #6
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
just disconnect the lines from the steering rack.. It'll be a mess, but it won't be all over the engine bay.
Oh, and you can retain the stock RS alternator with the wrx engine no problem.
subbyspeed is offline   Reply With Quote
Old 12-19-2006, 11:37 AM   #7
subenick
Member#: 48968
1999 impreza 2.5RS
what he said, RS alternator works and fits fine. (there are discrepancies between the 2 pin and 3 pin alternators though. My 99 RS was 3 pin and so was the jdm v7, so they work no problem. I believe some wrx are 2 pin. But not 100% sure which ones.
You need the wrx power steering pump though, having the lines makes for a clean swap though, the RS ones can be retrofitted by a shop.
subenick is offline   Reply With Quote
Old 12-19-2006, 12:54 PM   #8
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
i haven't seen any 2 pin wrx alternators, usdm that is. My 04 was a 3 pin, and all the others i've seen were also. the older impreza alternators used a 2 pin (at least my 95 does), when the ecu wasn't monitoring it.
Old 12-19-2006, 12:59 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Only older JDM WRX alternators will have different plugs. But they generally match some variant of USDM engine. I have roughly a dozen alternators in my possession and from what I remember there's probably 4 different connectors over the years.
As for draining the power steering pump? Get a turkey baster from the grocery store and use that to get most of the fluid out. It's far less messy that way...
Can I use a 2000 RS o2 sensor in my 99 ?(different plug) IllNastyImpreza Service & Maintenance 0 06-17-2009 05:06 PM
WTB: walbro fuel pump and kit for 02 wrx upjeeper Private 'Wanted' Classifieds 1 12-08-2007 10:04 PM
GA: STI Top Mount and parts for a wrx swap. blindsideair Engine/Power/Exhaust 17 01-18-2007 08:31 PM
2000 RS Front Seats and Tranny for sale Brood RMIC Private Classifieds 8 10-09-2006 07:13 PM
WTT: My '05 JSP STi Truck and Spoiler for Your WRX Trunk and Spoiler Kregg Tri-State Area Forum 3 08-31-2004 09:45 PM
