Alaskan Impreza Club
Old 12-18-2006, 12:00 AM   #1
Alaskan_awd
Member#: 117002
2010 >40psi, oh yes!
POWERSTROKE
Default Emissions, Catted vs. None DP
Hey guys, I want to go stage 2 before spring and I was wondering how many of you have catted or non catted DP's, have or havn't you had any problems with passing inspections, and what brand/type of DP do you have?
Alaskan_awd is offline   Reply With Quote
Old 12-18-2006, 12:04 AM   #2
AWDBST
Member#: 80085
11.8 117 Trap
Stock EJ205
Go catless. When the time comes swap the stock one back on. It will take like 30 mins every two years.
AWDBST is offline   Reply With Quote
Old 12-18-2006, 12:49 AM   #3
prometheum
Member#: 92003
04 TDI Passat
gut the stock ones ftw
prometheum is offline   Reply With Quote
Old 12-18-2006, 01:35 AM   #4
Alaskan_awd
Member#: 117002
POWERSTROKE
Other then emissions a reason to stick to a catted dp seems to be that the 06's have boost creep problems and getting a catted dp helps prevent it.
Old 12-18-2006, 02:01 AM   #5
AWDBST
Member#: 80085
11.8 117 Trap
Stock EJ205
Get engine management and port your wastegate. Problem solved.
Old 12-18-2006, 02:37 AM   #6
02redwagone
Member#: 87067
02 Old but tasty
SRP
x2 sleeper powah
02redwagone is offline   Reply With Quote
Old 12-18-2006, 03:07 AM   #7
Alaskan_awd
Member#: 117002
POWERSTROKE
I've been searching like crazy on here and keep coming up with new stuff . I would like to gut the stockers becuase that =$0.00, but from what I have read without 1 cat (and I would like it to be a high flow cat) I will likely get boost creep, yes I will have an AP when I change the DP but that is a bandaid and wont realy fix the problem (from what I have read), and I havnt done any research on it but having the wastegate ported doesnt sound very easy or cheap.
About the boost creep though, here is a quote taken from another post not sure how true it is, but interesting (I have a late model 06) "mostly found on early 06's and 05 sti's as it seems a batch of turbos were miss cast with an improper WG opening. Thats why some get creep and others dont."
So far it looks like the best option is a divorced wg full length catted DP.
The 06 exhaust is also different in the dp and midpipe are one piece, I could get a shorty dp but would have to use a midpipe section from an 02-05 wrx.
Old 12-18-2006, 03:58 AM   #8
00Maddog
Member#: 62410
2004 ra'd redrex in
8k w/ STI kit :) DASH
wrong, they look different buts that's it. all interchangeable. all downpipes are 2 piece, all the same except for 6mt's. all midpipes interchange, just different size resonators. all mufflers interchange. on wrx's anyhow.
00Maddog is offline   Reply With Quote
Old 12-18-2006, 01:27 PM   #9
MikeyMike
Member#: 112401
2012 Chevy
Cruze Eco Turbo
good thread. dumb question, but what is boost creep? i plan to go stage 2 very soon. i have heard of boost leaks.
MikeyMike is offline   Reply With Quote
Old 12-18-2006, 01:38 PM   #10
Alaskan_awd
Member#: 117002
POWERSTROKE
Everything you wanted to know about boost creep (it is new to me too) http://forums.nasioc.com/forums/showthread.php?t=477715
Old 12-18-2006, 01:42 PM   #11
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
Keep in mind new vehicles are every four years now instead of two.
Mavrik is offline   Reply With Quote
Old 12-18-2006, 03:28 PM   #12
ponamy
Member#: 115511
2005 wrx /w babyseat
2011 Forester 2.5x
thats 04 and up isnt it?
ponamy is offline   Reply With Quote
Old 12-18-2006, 03:36 PM   #13
Alaskan_awd
Member#: 117002
POWERSTROKE
I think its 06 and up, but maybe I missunderstood what he is saying.
Old 12-18-2006, 03:51 PM   #14
Alaskan_awd
Member#: 117002
POWERSTROKE
Taken from Unibombers Manifesto
I have an 06+ WRX, is the downpipe the same? No. The 2006+ WRX has a unique exhaust in that it's downpipe is both the downpipe and midpipe sections of the "older" exhaust. This means you must use a "long" downpipe to bolt up to the rest of your exhaust system. A full TBE will fit fine, but when replacing just the downpipe, you must use a long downpipe. Check with your Vendor for other possible fitment issues prior to ordering.
Diagram is fo 02-05
Old 12-18-2006, 04:31 PM   #15
Mavrik
Member#: 90347
Yamaha FZ8
2004 and newer have a four year extension.
Old 12-18-2006, 05:03 PM   #16
Alaskan_awd
Member#: 117002
POWERSTROKE
On the warrenty? I'm confused
Old 12-18-2006, 05:18 PM   #17
Mavrik
Member#: 90347
Yamaha FZ8
on your IM check
Old 12-18-2006, 05:24 PM   #18
Alaskan_awd
Member#: 117002
POWERSTROKE
on your IM check
wow I feal smart.
Old 12-18-2006, 07:41 PM   #19
MikeyMike
Member#: 112401
2012 Chevy
Cruze Eco Turbo
Wow, thats great. thanks for linking that up. So, i have a slightly lesser chance of boost creep if i get a catted dp?
Old 12-18-2006, 07:43 PM   #20
MikeyMike
Member#: 112401
2012 Chevy
Cruze Eco Turbo
Wow, where did you hear this? got it in black and white somewheres?
Old 12-18-2006, 07:48 PM   #21
Alaskan_awd
Member#: 117002
POWERSTROKE
It looks like it, at a loss of a few HP though.
Old 12-18-2006, 08:21 PM   #22
Mavrik
Member#: 90347
Yamaha FZ8
Its been in writing for quite some time Mike, you might be able to get a copy from the DMV or something. I had an "un-offical" print out from office staff here about a year ago when it took effect.
Old 12-18-2006, 09:51 PM   #23
MikeyMike
Member#: 112401
2012 Chevy
Cruze Eco Turbo
Well im sure its good news to all of us
Old 12-26-2006, 04:01 AM   #24
Alaskan_awd
Member#: 117002
POWERSTROKE
Bump, if I was to gut 1 stock cat, would that be enough flow for stage 2? If so, which should I gut, the first or last cat? Would there be any down falls to gutting one of the stock cats other then less flow, as apposed to getting a high-flow catted DP?
Old 12-26-2006, 04:10 AM   #25
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
were so bad...were the cause of global warming
EvolvedAK is offline   Reply With Quote
High flow cat VS No cats...none... lavid2002 Newbies & FAQs 32 11-09-2009 10:05 PM
DP Question: Performance of catted shorty DP w/ high flow 3rd Cat vs. catted full DP Worxman02 Factory 2.0L Turbo Powertrain 11 02-17-2007 11:52 PM
Catted vs non-catted emissions DigitalPunk Newbies & FAQs 76 02-16-2007 09:40 PM
Catted vs catless dp...with catless catback. SilverE2 General Community 25 05-15-2006 12:44 PM
helix catted vs catless dp Kaze Factory 2.0L Turbo Powertrain 8 04-19-2006 05:08 PM
Message Board Statistics All times are GMT -4. The time now is 11:51 AM.
