Old 11-19-2001, 10:07 PM   #1
steppin16
Member#: 6010
Default keyless entry problem
I got in my car one day and broke off the button that resets the keyless... then the nut that holds the switch to the plastic fell out... Now that the switch is not being tied down at all it kept hitting my leg so I shoved it into the dash area. A couple of minutes after I did this the locks went crazy locking and unlocking i pulled the wire out and it stoped but the remote doesnt work anymore. I cant set my other remote in cause there is no button.
My questions are:
How have you fixed the prob if this happened to you?
Is there a fuse for keyless?
I know someone will tell me to buy the new button but the dealer wont replace just the button... He wants to replace the whole wireing which is $80 plus labor. I will use the key for that price!
THANKS
Jim
steppin16 is offline   Reply With Quote
Old 11-20-2001, 03:26 PM   #2
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
That button is a pretty simple off the shelf item. I'm sure you could find a replacement at RadioShack for less than 5 dollars. Bring it with you and make sure they match the specs.
skidplatez is offline   Reply With Quote
Old 11-22-2001, 01:16 PM   #3
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
This used to happen to me like once a week. I finally just put some Locktite on the threads and I've been fine since. Did you loose the nut? I sure you can buy another one!
LVSUBARU is offline   Reply With Quote
keyless entry problem XROLLER Car Audio, Video & Security 2 03-22-2006 05:33 PM
02 Keyless Entry Problem live2ridetahoe Car Audio, Video & Security 2 02-26-2006 02:54 PM
Keyless Entry Problem only1agam Car Audio, Video & Security 1 06-09-2004 09:45 PM
Keyless Entry problems jodathmorr Car Audio, Video & Security 4 10-07-2003 08:43 PM
Keyless entry problem... Purdue WRX Car Audio, Video & Security 11 01-07-2002 07:50 PM
