Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 11-25-2006, 01:32 AM   #1
SpeedElement
Vendor Sales Rating: (61)
Member#: 18920
2004 WRX/STI
Default Perrin's New Product!! Just in time for X-Mas!!!
Perrin Performance Top Feed Fuel Rail Kit
The PERRIN Performance™ fuel rails represent a true advancement in boxer engine fuel delivery. The PERRIN Performance™ fuel rail kit is not just a replacement part. We have completely redesigned and redirected the fuel from the supply lines to the injectors, thus solving all fuel distribution problems insuring even fuel distribution to both banks of cylinders in the boxer engine. As clients continue to expand the HP in their vehicles this need for even fuel delivery is more critical. Failure to address this concern and your expensive motor will quickly require some major attention.
Our newest variant of this rail system is both easier to install and safer than ever before. To further prove our distinction as the industry leader in Fuel rail technology for Subaru applications, we now include genuine Goodyear® DOT approved fuel lines and PERRIN Pyroshield™! This fire retardant sleeve is placed over the fuel hose to protect the fuel lines from being subjected to extreme underhood heat created by high horsepower turbocharged monsters. This lowers the fuel temps, thus improving horsepower and increasing longevity. Available in both black and silver with aluminum PERRIN™ logo plates to suit any engine bay.
MSRP: $359.99
MPJ / Speed Element Special Introductory Offer: $324 shipped!(lower 48 states)
Perrin Performance Fuel System
Key to any high horsepower motor is fuel! Failure to supply enough to the hungry beast will certainly spell doom to even the most expensive motor build. PERRIN Performance™ has finally addressed this concern with fuel system designed and created specifically for the Subaru owner. Saves the installer from hours of making individual high pressure fittings to connect each section of the system. This comprehensive solution incorporates a digital brushless fuel pump irated to 1,000 horsepower, inline fuel pressure regulator, a 10-micronreplaceable fuel filter and Teflon®-lined stainless-steel fuel lines. Nothing is left other than a few hours of your time to complete the installation. All of the guesswork over pump selection, line size and fittings has been done for you.
MSRP: $1249.99
MPJ / Speed Element Special Introductory Offer: $1125 Shipped!! (lower 48 states)
Perrin Performance Progressive Water Injection System
The process of compressing air to create boost and power, has a nasty byproduct of heat. Heated air lacks the density to make higher horsepower, increases detonation and forces the ECU to pull timing. All of which reduce the power you are looking to create. In order to combat this heat, we manufacture air-to-air intercooler upgrades for nearly every vehicle we offer products for. But we are always restricted by the physical restraints of the vehicles size and by the fuel offered at the pump. Yet, high horsepower engines demand additional cooling and detonation control. This is where Water/methonol injection come into play.
History:
Water/Methonal injection is nothing new by any means. It was first used successfully in during WWII on tanks and fighter planes engines. The tradition started here and has been used in Formula 1 engines (1980s), It was supplied as an OE part on the SAAB 9-5, World Rally cars use it (1995 onwards), and now todays high powered, small displacement, forced induction engines.
PERRIN Performance (our co brand. find more infromation at www.perrinperformance.com) product developers sought out to create an easy to use and comprehensive system to add either water or water and methanol to the air charge. We went to the industry leader Aquamist™ to help with the development of this product, and together we created the amazing product you see before you on this page.
Education
The PERRIN PWI-1 water/methanol injection system is designed to suppress detonation caused by high intake charge temperatures and or when the effective compression ratio has been taken beyond the auto ignition point (of fuel) by increased boost from a turbo or a supercharger. To suppress Detonation, a fine mist of a mixture of water and methanol is injected into the intake charge. Water, with its high latent heat content, and methanol, with its high octane rating, are extremely effective at controlling the onset of detonation. From this you can gain power from increasing timing, or leaning the engine out, or simply add a large margin of safety to your engine.
By adding an extremely fine mist of water you can effectively add an additional intercooler to your vehicle. This lowers charge temperatures, reduces any tendency for detonation, and thus greatly improves horsepower and torque. Most clients will see gains in excess of 20WHP once tuned for! All while increasing safety and longevity of the engine.
To use the PWI system to its fullest, retuning of engine needs to be done. Doing nothing other than adding the PWI system to a properly tuned car will generally loose a slight amount of power but gain a high margin of safety. Some ECU’s constantly pull timing due to poor gas or very hot climates. In this type of situation, the car will gain power do to the suppressed Detonation, and the ECU adding ignition timing back into the car.
Cars that can benefit from the PWI are cars with poorly mounted, or small intercoolers, like the WRX, Legacy GT turbo, Mini cooper S, Mazdaspeed 6, Audi/VW 1.8T cars, Mitsubishi Eclipse or cars with turbo kits or supercharger kits with no intercoolers. But this does not limit the PWI-1’s ability to increase HP on cars with aftermarket intercoolers, where pump gas is being pushed to its limit of detonation.
The PERRIN™ Performance PWI-1 Water Injection System includes everything you need for a professional installation. Simply provide your own bucket of water! With a dash mounted control and display you can activate or deactivate the system as well as monitor the water level, flow and perform tests of the entire kit. Additionally, the PWI-1 brain uses trim pots to adjust flow, and injection start. The brain incorporates several safety functions, which can detect when the nozzle is blocked, or water is low in tank. If this happens the PWI-1 brain can be set to cut boost, switch to a different map (ECU dependent), or turn on a light or any number of things you can come up with. These are features simply not found on other water injection systems. Easy to assemble and install. Includes hoses, mounting hardware, instructions, and tuning tips.
Here's how it works:
Water is extracted from a water tank through the electromagnetic pump straight to the intake charge. The water vaporizes in the combustion chamber, drawing out unwanted heat. This in turn controls detonation, and slows the burn rate of fuel, basically turns your pump fuel into race fuel.
Features:
The Progressive part of the PWI-1
The idea of injecting water or a mixture of water/methonol have been around for a long. But what makes the PERRIN PWI-1 system stand out is how it delivers the water. The progressive part of our system refers to the mixture being delivered progressively as more fuel is being delivered. In order to make full use of a water injection system, a set percentage of water to fuel is needed. 10-20% of the fuel being delivered is the rule of thumb. Non-Progressive, less expensive systems have a fixed volume of water that can be delivered. These systems suffer from too much water at lower RPMS and not enough at higher. This causes a loss in power, at both lower RPMs(too much water) and high RPMS (no detonation control) The PWI-1 system uses Fuel Injector duty cycle to monitor the amount of fuel flow. From this we can ensure the 10-20% mixture of water vs. fuel. In the end this means more horsepower and a safer running engine!
High Pressure Pump
Working with the industry leader Aquamist, has the benefit of using the most tried and true pumps in the world. Since the Aquamist pump has been used in nearly every World Rally Championship car, and sold to thousands of car across the world, we thought it might be ok to use.
This pump is constructed very different than any other pump used for Water injection. The pump has no motor, or moving parts to wear out like all other water injection pumps use. The pump uses an electromagnet housed around a piston. On each side of the piston is a one way valve. When the electromagnet is energized, it pushes the piston to side forcing water out one end, and sucking in water on the other. A spring pushes the piston back into place, and is now ready for another pump. Imagine this happening many times a second, and you get water flow! This all sounds complicated, but is very simple and very reliable. The only thing we changed is the type of seals in the pump. Instead of the normal Butyl rubber seals, we changed them to Teflon seal to allow the pump to be used with nearly any chemical!
Nozzles
Included with the system are special precision nozzles designed to produce an ultra fine mist. In order to make the most of your water injection system, the atomization of water is an important feature. A poorly designed nozzle can cause a unequal mixture delivery to each cylinder, or worse hydro-lock your engine. The 3 sizes we include are 1.0mm, .8mm and .6mm nozzles. These nozzles cover flow rates needed to support 250-600 horsepower. (other nozzle sizes available) Included with system is a nozzle base. This base has a 18/NPT fitting on one end for easy installation into boost tubes.
Packaging
The PWI-1 system is made of of 4 main components. Pump assembly, Brain Box, Dash display, and Main harness. The pump assembly contains the pump, flow sensor, and mounting chassis. The chassis holds all the parts in a tight package, while offering many different methods of mounting. Threaded hole, and through allow for installation virtually anywhere.
The Brain Box, is where most of the magic happens. The Brain Box contains 3 trim pots for setting up when the injection starts, pump gain, and a trim pot for setting up the nozzles flow rate. Along with this, the box contains the wire harness terminal for connecting the Brain Box to the pump assembly. A terminal is also integrated for the dash display harness.
An important part of the system is the dash mounted display. This display gives the driver a heads up as to what is going on with the system. There are Ultrabrite LED's indicating when the system starts spraying, a system fault, and when the tank is low on water. There are 2 buttons located at the top of the display. One button turns the system on or off, and the other button a test button which turns the pump on at 100% for testing purposes.
Finally is the wire harness. This main harness is used to connect the system to the vehicles battery, and other sensors. Included with the harness are the 3 wires used to activate user setup items such as boost cut, map switching. This harness has a flying lead type connection for the Brain Box which allows for an even cleaner install.
All these pieces are designed as compact as possible to allow for easy integration to your vehicle.
Safety Features
Another feature the PWI-1 system offers above and beyond other systems is SAFTEY! When a highly strung engine is tuned to use Water Injection, there is a danger if for some reason the water stops getting delivered to the engine. If this happens, the cooling ability, and detonation suppression gained from injecting water goes away. This can put your engine is a very unsafe state. In order to combat this situation from happening (and it will happen at some point) we have incorporated safety features into the system.
The first system is the blocked nozzle detection. Using a flow sensor, we can determine the proper flow rate for a given nozzle (part of the setup). If the nozzle flow rate varies from this calculated flow rate plus or minus a small %, the PWI-1 brain throws up a "flag". This "flag" turns on a light on the dash mounted display indicating a fault in the system. Also this "flag" allows the user to setup their own system to help bring the engine back to a safe level. We include 3 wires that the end user can setup things like, boost cut, map switching, LED's, warning lamps, and anything the user desires. This is where the PWI-1 system goes above and beyond other systems.
The last system in place is the float switch. The float switch mounts in the tank and when mixture is low, a light on the dash mounted display lights up. This can be very helpful in keeping your tank full of water/methonal.
Included Items:
*PWI-1 Pump Assembly
*PWI-1 Brain Box
*PWI-1 Dash Display
*Main Wire Harness
*Brain Box Wire Harness
*Ring Terminals
*Float Switch
*4mm Hose
*6mm Hose
*Pre-Pump Filter
*Nozzles 1.0mm, .8mm, and .6mm sizes
*1/8NPT Nozzle Seat, and plug
*1/8NPT Tank Bung
*90 degree push-lock connector
MSRP: $749.99
MPJ / Speed Element Special Introdcutory Offer: $675 Shipped!!! (lower 48 states)
Perrin Performance Blow-Thru Boost Tube
Front Mount Intercooler users can now get a 100% accurate airflow temperature reading. Instead of measuring air temperature and volume before the turbo, the PERRIN PerformanceTM Blow Through Intercooler Hose moves the mass airflow sensor so that readings are taken just before the throttle body. Allows for proper use of a vent to atmosphere Blow Off Valve (part #PSP-INT-620).
MSRP: $229.99
MPJ / Speed Element Special Offer: $206.99 Shipped!! (lower 48 states)
CA sales tax will apply to CA residents.
Thank you
Calvin
510-226-8822
SpeedElement is offline
Old 11-26-2006, 02:23 AM   #2
Caballero_STi
Member Sales Rating: (11)
Member#: 122711
05 STi
Any pic when it's on car? I really want to know see.
Caballero_STi is offline
Old 11-26-2006, 02:42 AM   #3
GOUY STI
Member#: 66792
2005 Impreza Wrx STi
^^^^Me Too
GOUY STI is offline
Old 11-26-2006, 07:20 AM   #4
STi*guy.kiev
Member#: 117854
2003 spec c
VERY NICE!!! just a couple of questions, didn't perrin already have a topfeed rail system? or is this just an updated version? Fits the 06 wrx and euro spec sti, correct?
The fuel system looks very sweet but its big $$$! The pipe however is just awesome! That's a perfect piece which many were lacking. It allows you to take advantage of the perrin turbo kits without the intakes, so you can get custom cold air one made.. It fits only the perrin fmic correct?
Ah... If only perrin would use newer design exhuast housings on thier rotated turbo kits, that would be just great!!
BUMP for some great new products
STi*guy.kiev is offline
Old 11-27-2006, 02:25 AM   #5
SpeedElement
Member#: 18920
2004 WRX/STI
which part do you want to see it on the car?
Old 11-27-2006, 02:28 AM   #6
SpeedElement
Member#: 18920
2004 WRX/STI
Hello,
As far as I know, this is the updated version and will fit 06+ WRX and perhaps the EURO spec STi (need to confirm this again).
As for the Blow-Thru Pipe, it will work perfectly with the Perrin FMIC, and should work with other aftermarket ones too (a slight modification may required to match other brands FMIC).
Thank you!
Calvin
Old 11-27-2006, 04:59 AM   #7
Caballero_STi
Member#: 122711
05 STi
Old 11-28-2006, 08:55 PM   #8
SpeedElement
Member#: 18920
2004 WRX/STI
working on pix as we speak... we should have one installed soon!
thanks
Old 11-30-2006, 04:39 PM   #9
SpeedElement
Member#: 18920
2004 WRX/STI
shipment arrived today!!! All parts must go!! please give us a call to order!
thank you!
Old 11-30-2006, 04:48 PM   #10
InfamousDX
Member Sales Rating: (184)
Member#: 25413
Yes pics of blow through pipe on car... what side is this intended to go on... driver or pass. side?
InfamousDX is offline
Old 12-01-2006, 05:31 PM   #11
Forced Induction PG
Member Sales Rating: (1)
Member#: 132369
will the perrin fuel rail system work with the 04 wrx
Forced Induction PG is offline
Old 12-01-2006, 08:26 PM   #12
Capt Crunch
Member Sales Rating: (15)
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
from the looks of it, passenger side, post-intercooler like it's supposed to (for the perrin intercooler anyways).
Capt Crunch is offline
Old 12-02-2006, 12:15 PM   #13
InfamousDX
Member#: 25413
Oh yea... after visualizing more that does look like passenger side like the perrin IC.
Old 12-08-2006, 11:23 AM   #14
xchristensen
Member Sales Rating: (13)
Member#: 116562
2005 STi (PSM)
Does the car need to be tuned after this install of the Blow-thru Boost Tube? Or should i say after installation of this, can i run untuned and be fine?
also, pictures of this on a car would be awesome.
xchristensen is offline
Old 12-11-2006, 06:23 PM   #15
SpeedElement
Member#: 18920
2004 WRX/STI
yes the car will need to be retuned after the install. However you can run untuned for awhile as long as you don't go boost crazy and WOT all the time.
Pictures on a car would be great but this product is too new.. so someone needs to step up and post some pix!!
Old 12-18-2006, 04:14 PM   #16
SpeedElement
Member#: 18920
2004 WRX/STI
bump to the top
Closed Thread
finally some new shoes just in time for winter! '04 WRB dLo R6 Member's Car Gallery 10 12-16-2007 06:17 PM
A new intercooler just in time for Xmas! TurboRX Member's Car Gallery 25 12-25-2006 02:36 PM
Subaru Car Battery. As new. Just in time for winter! Redneck Ricer NESIC Private Classifieds 9 11-28-2006 06:19 PM
New Rims....just in time for Christmas! AAU Member's Car Gallery 66 01-14-2006 04:44 PM
sneak preview of my new mods! just in time for the WBM jpsimon Member's Car Gallery 16 06-12-2005 03:21 AM
