Old 12-18-2006, 03:09 PM   #1
big16gwrx
Member#: 129459
Default full throttle switch mounting please help
Does any one have any advice on mounting a full throttle switch. I have just hooked up the DEI CRY02 Kit and am trying to figgure out where i should install the switch. the switch looks kinda cheap.... does any one know of a better option to controll the selonid other than mounting this mechanical switch??? mabey a controller of sorts...
big16gwrx is offline   Reply With Quote
Old 12-18-2006, 08:04 PM   #2
big16gwrx
Member#: 129459
anyone????
Old 12-18-2006, 08:43 PM   #3
blazin sti
Member#: 84853
05 STI
aspen white
You have to look for where the cable to the throttlebody is .When you hit the gas it lifts up and down there should be a plate around there and you have to mount the wot switch to the point when you hit the gas all the way the cable rocks up and down so you have to have the switch move right before the rocker bottoms.That will activate the switch as soon as it pushes down all the way and it sends a signal to the relay. The bracket will have to be modified to work so youll have to do this with a friend.Let him hit the gas all the way or you can do it right there with your hand but you have to look close .Dont mean to write a book to ya but this is how i did it to my friends wrx. Good luck
blazin sti is offline   Reply With Quote
Old 12-18-2006, 09:32 PM   #4
big16gwrx
Member#: 129459
thanks for the info!!! got any pics???
Old 12-19-2006, 05:02 PM   #5
blazin sti
Member#: 84853
05 STI
aspen white
no i dont sorry. My friend that i did it for is no longer a subby driver and he sold the car.You could mount it under the gas pedel that was my second option but didnt like it.Did your kit come with a mounting bracket for the wot switch? If so it should be able to bend and twist so you get it perfect .If i find anything to show you i'll let you know.
Old 12-19-2006, 05:50 PM   #6
dibblejr
Member#: 94070
05 LGT
You could buy a ZEX (NOS) system switch, it works off the WOT voltage. Thats what I had on my 02 bugeye and it worked flawlessly. They will tell you the correct voltage to look for and you connect the hotside to that wire.
Jay-R
dibblejr is offline   Reply With Quote
Old 12-21-2006, 05:00 PM   #7
big16gwrx
Member#: 129459
i am think ing of adding a smc alky kit do you think this could be wired up to that controller???
Old 12-22-2006, 09:12 AM   #8
dibblejr
Member#: 94070
05 LGT
If you are asking me, I wouldnt see why not, sine the controller acts on a specific TB voltage that only occurs during WOT. You would have to get the WRX trigger switch from Zex, I cant remember if it was universal. Call Zex or a distributor like Summit Racing and ask.
Good luck.
Jay-R
sti throttle not working please help Bcoolsti Electrical & Lighting 3 07-20-2009 05:25 PM
Throttle Relay Probelm, Please help swap guru's! lots of info inside. snowcrzy Subaru Conversions 0 08-13-2007 07:53 PM
need information on mounts please help FromEvoToRS37 Brakes, Steering & Suspension 2 02-17-2006 02:21 PM
full throttle switch scooby_x Electrical & Lighting 7 08-09-2005 09:25 PM
Squeaking/creaking engine mount. Please help! fpa1974 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-10-2002 07:42 PM
